Rear Window Rattle
Discussion in '3rd Gen Tundras (2022+)' started by Hextorm, Feb 22, 2022.
  1. Feb 8, 2024 at 11:35 AM
    Harrison9299
    Harrison9299 New Member
    2024 Tundra TRD Pro
    315/70/17 BF Goodrich KO2 with 17” Method Race Wheels. Westcott Designs 3/1 lift kit Custom “TRD” door puddle lights
    I have a 24 pro with the same issue. When I put the back window down I get crazy rattle. I found a fix though: play loud music anyway, a buddy of mine owns a 23 pro with the same issue.
    Chomponthis likes this.
  2. Feb 8, 2024 at 3:44 PM
    Chomponthis
    Chomponthis New Member
    Billings, MT
    2023 Tundra Limited Cremax 4x4, TRD OR
    The dealership said its "normal", it sure as heck doesn't sound normal to me.
  3. Feb 9, 2024 at 8:35 PM
    Swanie80
    Swanie80 New Member
    B
    2023 Tundra 1794 TRD OR
    3" Lift, 35" Tires, Fuel Rims
    I have the same issue. Was driving with my brother in the back seat and he stuck his whole body out the back window and said it was from the back of the bed. He then got in the bed and confirmed it was in the corners of the tailgate. When we stopped and looked further into it also noticed it made the same rattle when the back door is closed, which was the tailgate support cables rattling. With the tail gate half open you can see how much play is in these cables. At least for my truck is the cables, so much slop causing the rattle.
  4. Mar 14, 2024 at 6:00 AM
    TRD L Power
    TRD L Power New Member
    2023 SR5 XP TRD Off-Road Army Green
    My two rear passenger windows rattle pretty badly when slightly open. Grabbing them with my hand (parked) I can replicate the sound easily and there is about a .5 - 1cm amount of movement while very lightly shaking them.
    I noticed this driving when I have my dog in the back, letting her catch some sniffs.
    It feels like the window is too small for the track, or, much better tract support and insulation should have been used.
    Mine is also impacted by the wind noise from the front driver and a little by the front pass.
  5. Mar 14, 2024 at 6:33 AM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    I've got the same back seat window(s) rattle. Dealership looked at a few new models on the lot and they all did it. Resolution: Same song and dance..."Characteristic of these trucks. No issue."
  6. Mar 14, 2024 at 6:38 AM
    fat_marshmallow
    fat_marshmallow New Member
    my 22 drove me nuts with the rattles when the rear window was down over ever bump at low speeds. I found the problem to be the bed and mounts instead. Whenever I stepped on the bed I would hear a creak. I isolated the noise down to the bed mount nearest to the driver side. Took out the bolt, Lifted the bed a little, slid a thin rubber washer under the mounting points and put the bolt back. no more creaks and no more rattles with the rear windows down. So in my case it was a creaky bed that made it sound like it was rattling over bumps. Hope this helps solve some problems.
    wxman91 and Tundrastruck91 like this.
  7. Jul 21, 2025 at 1:01 PM
    JHRanch
    JHRanch New Member
    2024 Tundra 1794
    None
    Hi. Just joined this forum. This issue caught my eye as mine has this same rattle. I read as much as I could about it. Finally had time to take it to the dealer to address. Service advisor said all the new ones do it but that Toyota had not issued a fix. So, I called corporate number for such issues to let Toyota know. I’d recommend the more calls they get the more likely they’ll fix. It’s a bad engineering job - much like the radio knob. If your rear window rattles - call Toyota Brand Engagement Center at 1-800-331-4331. Let them know!!!
