Rear window molding removal
Discussion in '1st Gen Tundras (2000-2006)' started by stevechumo, May 11, 2020.
  1. May 11, 2020 at 2:54 PM
    stevechumo
    stevechumo [OP] New Member
    The rubber on my Tundra's rear window molding got cracked and looks ugly. I don't know how to remove that piece to strip off the old rubber and spray with new rubber. Can anyone please show me how to remove that molding?
  2. May 11, 2020 at 2:58 PM
    browntundra77
    browntundra77 New Member
    Devon
    DMV
    2017 SBM Tundra Platinum CM
    I have the same problem, where did you purchase the new liner?
  3. May 11, 2020 at 3:01 PM
    stevechumo
    That's not my truck. That picture is from the internet.
    I fixed the molding on the side windows. I bought bumper spray cans from Autozone and sprayed them.
    However, removing all old rubber is a PITA. I got to use the heat gun to soften the old rubber, then use razor blades to scrape off. Use sandpaper to roughen the chrome coating. Spray primer on. Then finally is spraying the rubber can on.
  4. May 11, 2020 at 3:09 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Given there are decent instructions in FSM's, it would help knowing what year/model Tundra and even actual pic would help. FSM instructions for your veh could possibly then be provided !
  5. May 11, 2020 at 3:12 PM
    Professional Hand Model
    Hand Protectors
    You’d probably net less time by taping off the glass and body and using plastic to cover for overspray.
    1) Blue tape/plastic sheet cover everything.
    2) Rough sand.
    3) Wipe with alcohol.
    4) Spray primer/rubber paint. Pull tape.
  6. May 11, 2020 at 8:54 PM
    stevechumo
    The toughest part is removing the old rubber coating. That's why it'll be easier to remove that molding if it's outside.
