Rear view mirror/camera
Discussion in 'Audio & Video' started by FFSLJ, Jun 7, 2020.
  1. Jun 7, 2020 at 9:56 AM
    FFSLJ
    FFSLJ [OP] New Member
    2016 Super White Tundra CrewMax 5.5 bed SR5
    Spyder Head lights, Spyder Tail lights, TRD grill/hood scoop, Rigid Industries Fog lights , and more to come/
    Has anyone installed this camera and/or how do you like it? Have you used another camera?
    VanTop H610 10" 2.5K Mirror Dash Cam for Cars with Full Touch Screen, Waterproof Backup Camera Rear View Mirror Camera, Enhanced Night Vision with Sony Starvis Sensor, Parking Assistance https://www.amazon.com/dp/B07XZ1D226/ref=cm_sw_r_cp_api_i_LVr3Eb6H5DTYQ
    Look to use while driving and while parked for security accidents recording Etc
    Mountun Goat likes this.
  2. Feb 5, 2021 at 12:33 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I installed the Vantop H612T 12". It's a great unit. Very happy with it.
  3. Feb 6, 2021 at 1:42 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    The 2021 Camaro comes with a mirror like that. I really liked it when I took one for a test drive.
  4. Feb 22, 2021 at 11:26 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    where did you install the rear camera????
  5. Feb 25, 2021 at 9:48 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Ran into this post the other day and had been thinking about how poorly my rearview mirror was going to work after my topper gets installed next week. So I picked one of these up on Amazon and it came in yesterday. Got their hardwire kit as well and that was nice and easy to connect in using the drivers side footwell fuse box. Turns out there are a few empty spots in the fuse panel that have constant & switched 12v power (well at least on my 2018 1794) so didn't have to splice any wires!
    Won't be able to run the rear camera until the topper is on but damn this is a sweet little unit! I did have to replace my autodim/compass/homelink mirror since the VanTop wouldn't mount correctly and I broke off a tab trying. Had to fix that with some superglue and a longer screw but ended up pulling the factory mirror and getting a cheap normal mirror from Advanced Auto for like $12.
  6. Feb 25, 2021 at 9:09 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    i got the mirror but it wont fit over my stock one...are u saying u removed ur mirror and replaced it totally?
  7. Feb 25, 2021 at 9:11 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    also was trying to figure out how u mounted the camera...is it inside the cab? was thinking of making an L bracket
  8. Feb 26, 2021 at 6:14 AM
    abomb60
    Massachusetts
    Yup exactly. Pull the plug on the back of the stock mirror and there is then a single torx screw that attached the mirror to the windshield. Undo that and the stock mirror will slide off. I replaced mine with a basic rearview from the autoparts store.
    I wasn't going to until I mounted the topper next week but I ended up putting it temporarily on the ceiling inside the rear window. I mounted it using 2 of the short screws that it came with. Not sure how permanent a solution that would be so you might want to get a small bolt through the headliner to make it sturdier.
  9. Feb 26, 2021 at 7:27 AM
    abomb60
    Massachusetts
    Here’s a few pics I took of the camera mounted. This is just temporary so I can use the mirror until my topper is installed next week. Once the topper is on I'm thinking this will go top center by the inside of the back glass or up top by the topper third brake light.
    74285AA7-A8EA-4368-ADB5-40BCB0D1E81B.jpg 5285E609-818B-4CA3-9DA7-9C66A1580537.jpg
  10. Jan 22, 2022 at 12:11 PM
    Gass_Passer
    Gass_Passer New Member
    Rich
    2021 Lunar Rock Tundra TRD
    Did you ever install this camera after you got your topper on? I'm interested because I have a topper with tinted windows all the way around. This combined with my tinted cab windows makes it almost impossible to see anything in rear view mirror
    Thanks
    AggiePhil likes this.
  11. Jan 22, 2022 at 12:37 PM
    abomb60
    Massachusetts
    Yup I installed it with the topper once that went on. I put it on the inside of the rear topper glass to protect it.
    Gass_Passer[QUOTED] likes this.
  12. Jan 23, 2022 at 2:30 PM
    Gass_Passer
    Rich
    Have any pics? Do you like it?? How did you run the wire? Sorry, so many questions, but I am very interested in this set up.
    This is my rig
  13. Jan 23, 2022 at 3:20 PM
    abomb60
    Massachusetts
    Don’t have any pics handy just mounted it to the top back inside by the dome light. It’s been working great so far and the view works well. I ran the wire from the mirror under the headliner to the passenger rear corner then out the factory hole in the floor then into the bad through one of the holes between the bed and cab.
