Rear sway bar...worth it?
Discussion in 'Performance and Tuning' started by Pudge, Jun 20, 2018.
  1. Jul 23, 2018 at 7:33 PM
    #91
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Nope, not standard at least
  2. Jul 23, 2018 at 8:06 PM
    #92
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    Any issues getting those forward hitch bolts out? Tundra Dude over on you tube seemed to have a problem... I plan to use the Tekton torque wrench to remove them... bad idea?
  3. Jul 23, 2018 at 8:09 PM
    #93
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    Idk what his issues were but I had none. I used an air gun to remove. Was much faster plus I live in a salt/rust state so I know they'll be tough to remove. I could have used a ratchet but it would have taken longer. I installed new ones with torque wrench. Installation is pretty straight forward and simple.
  4. Jul 23, 2018 at 8:10 PM
    #94
    belanger9
    Edmonton, AB
    A bunch
    None whatsover - I've had my truck almost 2 years. I couldn't get any impact guns in there, if you have a 12" extension it may work, so I had to use the torque wrench as well. ~80 ft lbs is nothing on one of the big 1/2" drive torque wrenches.
    Pudge[OP] likes this.
  5. Jul 23, 2018 at 8:11 PM
    #95
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Thanks! No air gun here.. but no salt either. Only a year old so I’m not expecting too many problems... we’ll see on Thursday though :D
    Pudge[QUOTED][OP] likes this.
  6. Jul 23, 2018 at 8:12 PM
    #96
    Pudge
    CT
    You'll be fine
  7. Jul 23, 2018 at 8:14 PM
    #97
    You should never use a torque wrench to remove a bolt. Use a breaker bar or ratchet your torque wrench will stay more accurate.
  8. Jul 23, 2018 at 8:21 PM
    #98
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    That’s what I figured. I’ll have to locate a better option....
  9. Jul 23, 2018 at 8:24 PM
    #99
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    The TRD bar will fit, just needs rotated. If you remove the block with a new leaf pack, the extended links will need to be made.
    jeremyd[QUOTED] likes this.
  10. Jul 23, 2018 at 9:00 PM
    #100
    Pudge
    CT
    A ratched or wrench ot breaker bar will be just fine for removing the bolt. Dont need anything too special
    landphil likes this.
  11. Jul 23, 2018 at 10:12 PM
    #101
    ZPMAN
    Minnesota
    All you have to do is take one of the bolts out of the link bar to the swaybar and zip tie the bar to the frame.
    Sas[QUOTED] likes this.
  12. Jul 23, 2018 at 10:28 PM
    #102
    ZPMAN
    Minnesota
    You could have mounted your SB on top of the axel.
  13. Jul 24, 2018 at 7:29 AM
    #103
    Pudge
    CT
    I'd want some kind of protection on the end link bushings and end of sway bar where they bolt on though.
    Prostar 190 likes this.
  14. Jul 24, 2018 at 8:27 AM
    #104
    ZPMAN
    Minnesota
    You can eather swing the link bar up near the frame and zip tie it or just remove the link.
  15. Jul 24, 2018 at 8:34 AM
    #105
    ZPMAN
    Minnesota
    With a 4" block i would mount the SB on top or middle of axel at least. If mounted on top you may just have to do a little reroute of break lines.
  16. Jul 24, 2018 at 9:01 AM
    #106
    Pudge
    CT
    I wouldn't shift the mounting location as long as the end links are close to vertical. I could see doing it if they weren't but I wouldn't change mounting location especially if that would throw them further out of vertical
  17. Jul 26, 2018 at 7:27 PM
    #107
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Ok. It’s on but I gotta fix it :S
    The hitch bolts came out just fine. I used a breaker bar, but really didn’t have to apply a ton of pressure... I mean it was on there, but I didn’t have to gather all my strength to break it off lol
    First. It’s not far enough in on the drivers side... it didn’t fit easily and I didn’t want to force it... looking at their pics (in color here ) it’s clearly under that triangle shaped bracket.
    Also, on the u bolt configuration, they weren’t clear about the use of washers. They referred to a diagram, but in the black and white print out I couldn’t see what the hell they were talking about! The color one wasn’t much better, I guess just a washer under the nut that holds it all together... the other “bolting” instructions were better: “#1 washer, endlink, rsb, nut”
    Before tightening it all in... snapped a quick pic cause it was about dark. The ubolt on the left isn’t nearly as crooked.
    Doesn’t quite want to clear the bracket on the drivers side.
    Passengers side looked ok I think... just missing washers:
    Sas and Prostar 190 like this.
  18. Jul 26, 2018 at 7:48 PM
    #108
    Can you just loosen the bolt that holds the bracket on the driver side slightly and rocket to the right so you have clearance?
    NewImprovedRon likes this.
  19. Jul 26, 2018 at 7:56 PM
    #109
    Pudge
    CT
    I'd just loosen those nuts on the u bolts and tap it to the right. It should go under that bracket pretty easily with a few taps.
    Looks good. Can't wait to hear some feed back. I'm really liking mine. Really helped the body roll alot which allows me to take corners a bit more aggressively now and I feel safe
    HecticEnergy and Prostar 190 like this.
  20. Jul 26, 2018 at 7:57 PM
    #110
    Rica25
    Ricardo
    Tulare
    Front one makes a huge difference also
  21. Jul 26, 2018 at 9:13 PM
    #111
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Looking good feeling good :D
    Report more later. Long story short: awesome!
    D3ACCF3A-0B48-4B1C-BF63-30B755533DDD.jpg 56B6F50E-71DD-4A60-8F50-46A097E3A7B6.jpg
  22. Jul 26, 2018 at 11:40 PM
    #112
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Longer version:
    Took it for a 30 min drive around some 180 25mph on/off ramps I’ve got near me. I usually take them at 30-35 mph and feel like I’m going to roll the truck. Tonight it felt solid and planted. The front end felt like it was trying to get away from me a little, but I suppose that’s what the FSB is for :). I’m excited for the wife to feel the cornering in this thing now!! She usually grabs the cup to make sure they don’t go flying out of the center console... like the cup wells aren’t deep enough.. I usually come into the neighborhood at 25mph... I usually get the “geeze babe!” But I think there will be a lot less of that now... or at least I’ll be going faster to get it LOL
    Figure I’ll check the torque settings in 100mi, after the next several full ups (250-350 mi) then again at each oil change for a while. That’s probably over kill. But better safe than sorry IMO
    Thank you all for your input! It’s been a great help!
  23. Jul 26, 2018 at 11:43 PM
    #113
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    You do it w/the Tow/Haul off and traction control off yet?
  24. Jul 26, 2018 at 11:43 PM
    #114
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Tow haul on, yes, trace off, no... I’ve been up since 4am... seemed like a bad decision lol
    NewImprovedRon and Prostar 190 like this.
  25. Jul 26, 2018 at 11:59 PM
    #115
    Sas
    OKC, OK
    Lol, I hear ya. I'm about to take a shower and rack out. Feel like I've been thru a taffy puller the last few hours after getting some more upgrades done. Found out I'm not nearly as bendy as I used to be.
  26. Jul 27, 2018 at 2:40 AM
    #116
    Looking good TJ!
    HecticEnergy[QUOTED] likes this.
  27. Jul 27, 2018 at 11:40 AM
    #117
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Answering the post Title:
    It depends on how you use/drive the truck.
    If a TRD Sport would make sense for you (mostly road driving, maybe a little aggressively) but you dont have a TRD Sport, get a sway bar. SO MUCH BETTER HANDLING!
    I obviously just installed it, so i'm not sure how it effects towing.
    If you're planning on rock crawling or mudding where you require the articulation of your rear shocks, Dont get a RSB... or get one that can easily be pulled off (I hear there are options out there, TRD RSB isnt one).
    I'm defiantly more of the "TRD Sport" driver. If it goes off road, its flat dirt roads or the beach.
    JoshuaA, Rex Kramer and Sas like this.
  28. Aug 5, 2018 at 6:03 AM
    #118
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Has anyone painted their sway bar? If so what steps did you take? TIA!
  29. Aug 13, 2018 at 3:30 PM
    #119
    jaredmillerdvm
    Anderson, SC
    So I got my sway bar installed. I have 4 of the 6 bolts torqued to specs! The U bolts are scaring me, I don’t want to keep tightening and brake them! I keep inching along but my torque wrench won’t click like the other 4. Anyone else have this issue? What should I do?
    Rica25 likes this.
  30. Aug 13, 2018 at 4:17 PM
    #120
    jaredmillerdvm
    Anderson, SC
    Man I did, it clicks on the end links and sway bar part. I even got the 1/2 inch with adapter and got a click with that one on the other 4 also. I am just scared to strip the u bolt. I feel like I’m torquing the hell out of them.
