Rear Sway Bar Installed
Discussion in '2nd Gen Tundras (2007-2013)' started by CM2007, Nov 1, 2021.
  1. Jan 7, 2022 at 5:41 PM
    #61
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    SouthWestGA likes this.
  2. Feb 13, 2022 at 1:56 PM
    #62
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    The bright red did not look right for my truck so I bought a random can of grey paint from lowes and it turned out to almost match my wheels..
    I'm thinking it would be a good idea to re-torque everything after a few hundred miles..
  3. Feb 13, 2022 at 2:49 PM
    #63
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    What are your thoughts on how it drives after the installation?
    AircareTundra likes this.
  4. Feb 13, 2022 at 4:00 PM
    #64
    AircareTundra
    AircareTundra New Member
    JT
    Having thrown out all the install instructions for mine already........do you still have the torque settings? Good idea on retorques after a bit.
    Thanks in advance!
  5. Feb 13, 2022 at 4:31 PM
    #65
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Drop link top-to-frame = 84 lb-ft
    Drop link bottom-to-sway bar = 48 lb-ft
    U-bolt bolts = 48 lb-ft
    AircareTundra[QUOTED] likes this.
  6. Feb 13, 2022 at 4:42 PM
    #66
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    My honest opinion is it was the biggest waste of money as far as mods go. Very little difference. Others definitely have different opinions. Granted I’m already on toytec suspension and airbags. Might not be the best person for product review
  7. Feb 13, 2022 at 4:44 PM
    #67
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I thought it did alot for driveability. The truck feels lighter and corners feel much more planted.
    Danny3737 and Mike59 like this.
  8. Feb 13, 2022 at 6:14 PM
    #68
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    I can honestly say it is a tremendous upgrade. I had a 2012 Platinum and bought the sway bar kit and installed it with 5100 shocks all the way around. So much better in the turns, flat and less body roll. I drive to the mountains a lot on twisty roads and the truck was much more planted.
    Traded it in and bought a 2020 Limited Crewmax. I pulled the rear sway bar off the 2012 and installed it yesterday on the 2020. I have only driven around town a little, so can't say much better, but I did take a corner kind of fast to see and felt like less body roll. I feel it is a very easy and good upgrade. If you don't like it, someone will buy it. I recommend it highly.
    Mike59 likes this.
  9. Feb 14, 2022 at 6:17 AM
    #69
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I have not driven it yet. Roads here are an icy mess.
  10. Feb 14, 2022 at 6:44 AM
    #70
    Eze915
    Eze915 New Member
    Edgar
    2013 Black Tundra CM 4x4
    I am very interested in adding a sway bar to my 2013 Tundra. I recently purchased the truck with a rough country lift already installed on it. I youtube'd install videos and came across this picture of an install. The guy didn’t attach the sway bar to the bottom of the axle due to his lift. I believe I will probably encounter the same issue. He ended up attaching the sway bar to the back of the axle. I’m attaching picture for reference. My question is, if it is attached this way would it still function properly?
  11. Feb 14, 2022 at 9:38 AM
    #71
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I’m guessing there is a reason Toyota designed it to go under the axle. I can see in that photo that mounting it that way will push the end link bars back. Ideally you want those bars as plumb as possible. My guess is very small difference if any in performance.
  12. Feb 14, 2022 at 9:47 AM
    #72
    SouthWestGA
    SouthWestGA New Member
    I believe you can get longer custom rear sway linkage bars
    Retroboy1989 likes this.
