Help lining up rear shocks
Discussion in 'Suspension' started by newguy209, Jun 10, 2018.
  1. Jun 10, 2018 at 11:09 AM
    newguy209
    newguy209 [OP] New Member
    Central CA
    Hey guys any tips on trying to line up the rear shocks to the holes. They are not compressed and being a pain in the butt, I’ve been trying to jack it up but it never lines up. Thanks 08ECE842-AA45-47A5-93F6-3230FC75B4AE.jpg
  2. Jun 10, 2018 at 11:20 AM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    let the rear come down to where it meets the lower shock.
    TheBeast and newguy209[OP] like this.
  3. Jun 10, 2018 at 11:23 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    Claw hammer and large standard screwdriver helped me line it up. Good luck. D
    newguy209[OP] and 15whtrd like this.
  4. Jun 10, 2018 at 11:25 AM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Jack the truck up on the frame. The jack under the pumpkin needs to be lowered to extend the rear leafs all the way down. Should line up after that.
  5. Jun 10, 2018 at 11:28 AM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Giant screwdriver or small pry bar. Put the end inside the mount with the shaft under the very bottom is the shock. Should give you the leverage to compress the shock while it slides into the mount.
    newguy209[OP], 040Tundra and 15whtrd like this.
  6. Jun 10, 2018 at 11:51 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  7. Jun 10, 2018 at 11:59 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I haven't changed my rears yet, but this advice seems legit!
  8. Jun 10, 2018 at 12:13 PM
    LML 3500HD
    Jack stand
    Floor jack
    Tire chock under rear wheel that isn’t being worked on.
    Put parking brake on.
    Jack up side your having issues with, place jack stand under frame. Truck should not be level, maybe 3” higher than normal ride hieght.
    Remove rear tire using floor jack under axle.
    Lower jack until suspension is at full droop. Check to see how close the shock eye is to the shock mount on axle. Adjust up as necessary. No prying, gouging or struggle. Slide on mount and torque to specs.
    Boom goes the dynamite.
  9. Jun 10, 2018 at 12:24 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^[​IMG]
  10. Jun 10, 2018 at 4:06 PM
    newguy209
    Central CA
    Thanks, sent a text to my mechanic friend he said the same. Worked!
    Took me Saturday and Sunday to install these. I left my 1” block for now. I don’t think I can do the leafs.
    F5C9C24A-0E16-4AF8-B51C-4976EC390C69.jpg E17DB9FA-EAF6-4804-95DF-ED29A0443027.jpg
    Dilsky and Black Wolf like this.
  11. Jun 10, 2018 at 4:09 PM
    newguy209[OP] likes this.
  12. Jun 10, 2018 at 4:13 PM
    newguy209
    Central CA
    Thanks for all the replies guys, I’ll definelty do this next time.
    Black Wolf likes this.
  13. Jun 10, 2018 at 4:15 PM
    Aurora CO
    You did quite well actually!
    newguy209[QUOTED][OP] likes this.
  14. Jun 10, 2018 at 4:23 PM
    15whtrd
    15whtrd Mr. Blonde
    I did it the hard way because I was lazy. I did it with the truck on the ground and the wheels on. I really don’t know why I insisted on doing it this way. But I knocked it out quick!
    I pushed them up into place and got them to sit in the lower amount with the top nut loosely spun on. Then my oversized flathead screwdriver wrapped in a rag as I pried it up and slid the bolt in.
    Glad you got it handled!
  15. Jun 10, 2018 at 5:06 PM
    Sterlinglwood
    Sterling
    Newbury Park, CA
    Nice setup!
