Rear Shock Mounting Bracket Question
Discussion in 'Suspension' started by Rvick82, Jun 29, 2020.
  1. Jun 29, 2020 at 8:07 AM
    Rvick82
    Rvick82 [OP] New Member
    Ryan
    Hey all,
    Just installed my new Fox 2.0 rear shocks. The steel braided tube that leads from the shock to the reservoir rubs against the bottom of the rear shock mounting bracket. I resolved this by rotating the rear shock so the tube is at the 6 o’clock position when facing the wheel.
    I would really like to place the tube at the 9 o’clock position but would need to trim some material off the bottom of the mounting bracket.
    Is it ok to trim about 1/4 to 1/2 inch of material off the bottom left side of the rear shock mounting bracket to allow clearance for the tube? I just want to make sure that will not compromise the stability of the bracket.
    georgiey22 likes this.
  2. Jun 30, 2020 at 5:30 PM
    Me personally I wouldn't trim it. I'm sure others with that same setup can post pics of how theirs is installed.
    Rvick82[QUOTED][OP] likes this.
  3. Jun 30, 2020 at 7:02 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I had the same issue before with my old kings before I got bypasses, to the point where it was wearing thru the hose fitting. I notched it out about an inch or so with a cut off wheel. I run my truck pretty hard off road and never had issues with it being trimmed
    SC_TRD and Rvick82[OP] like this.
  4. Jun 30, 2020 at 7:07 PM
    Rvick82
    Ryan
    I’d guess 1/4 to 1/2 inch should be fine. Thanks for the replies. I really appreciate it.
    TG705 likes this.
  5. Jun 30, 2020 at 7:11 PM
    taco supreme
    taco supreme New Member
    16 white CM 1794
    9BC0D761-348C-49C4-B29D-3AE15E79AF1E.jpg When did fox change the fitting? I have the 90 degree fitting on my fox 2.0 resi
    Rvick82[OP] likes this.
  6. Jul 5, 2020 at 8:18 AM
    Rvick82
    Ryan
    Don’t think they changed the fitting. My truck is lifted and they didn’t make the shock for the Tundra with the travel that I needed. I had to purchase a universal shock to fit my application. So the universal shock was adapted to fit my truck. They said I might need a little modification to make it fit well. I think that is why the 90 degree fitting is not on that shock. It would have made it fit much better though.
    SC_TRD likes this.
  7. Jul 5, 2020 at 8:23 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Rotate the shock body so the fitting is facing the front on passenger side and rear on driver side.
  8. Jul 5, 2020 at 8:47 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Maybe cause I have literally the exact same shocks and installed them with @TG705 o_O... but did the same thing on my truck. And have seen multiple other people make this modification on their trucks as well. @Trdwillie14 :thumbsup:
    TG705[QUOTED] likes this.
  9. Jul 6, 2020 at 10:49 AM
    Rvick82
    Ryan
    Thanks! I’ll give it a try.
