Rear Shock help! Breaker bar needed?
Discussion in 'Suspension' started by pschiller86, Feb 17, 2018.
  1. Feb 17, 2018 at 10:47 AM
    pschiller86
    pschiller86 [OP] 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I am install 5100s in the rear and the top 17mm bolt comes out no problem. The bottom bolts are extremely tight. I don’t necessarily have the best tools in the garage but a standard ratchet wrench was not doing the job on the lower 17mm bolt.
    Do I need a breaker bar?
  2. Feb 17, 2018 at 11:02 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Breaker bar or air wrench.
  3. Feb 17, 2018 at 11:06 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Get an air pipe from Home Depot that fits over your wrench. Works great for a breaker bar.
  4. Feb 17, 2018 at 1:59 PM
    pschiller86
    Paul
    Temecula, CA
    I bought a 15” breaker bar on Amazon. Guess I’m trying my install again on Monday lol.
  5. Feb 17, 2018 at 5:14 PM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    Harbor freight for a cheap priced breaker bar
    UTTundra and ColoradoTJ like this.
  6. Feb 17, 2018 at 5:32 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    This, I used a 1/2" pneumatic impact wrench. Or use a box end with a pipe over it and a small maul.
    DaBoro54 likes this.
  7. Feb 22, 2018 at 6:26 PM
    tacomawv
    tacomawv New Member
    Richard
    I just did mine. I used a 1/2 inch air gun. No problem. My problem was the top not on the passenger side. I had to cut it off. Doing the front?
  8. Feb 22, 2018 at 6:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You might want to spray some penetrating lube on it right away. Then when you come back to it the lube will have had some time to work its magic.
    It it's still a problem, you can carefully try heat.
    UTTundra likes this.
  9. Feb 22, 2018 at 6:42 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Twist a large closed end wrench around the ratchet handle. Its a Quick breaker bar to give you more leverage.
    NewImprovedRon likes this.
  10. Feb 22, 2018 at 7:18 PM
    pschiller86
    Paul
    Temecula, CA
    I used a 1/2” breaker bar and the bottom bolt was no problem. The top bolt was easy, just not a lot of room there to get your hand to maneuver a ratchet.
    JMB likes this.
