Rear shock advice
Discussion in 'Suspension' started by BullyKnuckled, Feb 16, 2017.
  1. Feb 16, 2017 at 8:13 PM
    BullyKnuckled
    BullyKnuckled [OP] New Member
    Brandon
    South Louisiana
    2017 MGM 5.7L CM SR5 TSS Off-Road 4x4
    I put 3" BDS spacers up front and 3" Coachworks shackles in the rear. Do I need to, or should I replace the rear factory shocks since I added height? If I should replace, with what. Not terribly interested in reservoir shocks bc of the price, unless they are absolutely worth it. I did see where Toytec sells a Boss shock for 1-3" of rear lift. Thanks for any input. 2017 CM SR5 TSS 4x4
    ColoradoTJ likes this.
  2. Feb 16, 2017 at 10:55 PM
    Toytec is a good option and a site sponsor. There is a good selection of quality vendors on this site.
    To answer your question, yes you do need to swap out the rear shocks. You will top those out pretty quick.
    I installed the Bilstein 5160 shocks on my Tundra and was happy with that purchase. Not sure if the 165.00 x 2 is in the budget right now.
    Keep us posted on what you decide.
  3. Feb 16, 2017 at 11:54 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Look at OME rear shocks also. They are also rated for 1-3 inches and they are as bullet-proof as they come.
  4. Feb 17, 2017 at 2:18 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Agree with above, I'd get ahold of Toytec. Call them and tell them what you have.
  5. Feb 17, 2017 at 7:56 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Thanks for the love guys!!! :thumbsup:
    @BullyKnuckled Feel free to shoot me a PM and we can chat about the different options we have that will fit your needs perfectly!
    -David
  6. Feb 17, 2017 at 7:59 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    As stated above yes you will want new rear shocks. The shocks will be extended 1-3" at ride height with the shackles. This means that they will end up at their limit before full droop. This leads to a not so comfortable ride as your range is limited.
    BullyKnuckled[OP] likes this.
  7. Feb 17, 2017 at 8:16 AM
    showtime240
    showtime240 New Member
    +10 on installing the rear shocks.
    I also have the OME 614s and installed the rear OMEs
  8. Feb 17, 2017 at 8:45 AM
    BullyKnuckled
    Brandon
    South Louisiana
    Just made an online order. I trust these guys on here!!!
