Rear Shackles - What You Running
Discussion in 'Wheels & Tires' started by LiftMeUp, Jul 6, 2019.
  1. Jul 10, 2019 at 10:55 AM
    #61
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Glad it worked out. I was able to knock the edge off with my dremel while everything was in place.
  2. Jul 10, 2019 at 11:20 AM
    #62
    LiftMeUp
    LiftMeUp [OP] New Member
    Good luck.
  3. Jul 10, 2019 at 11:23 AM
    #63
    LiftMeUp
    Wow, you are very convincing. I must say was leaning back towards the 1" because was doing this to level and then didn't want to put a rake back with 1.5" But now I think i'm sold on the 1.5" because worse than the rake would be nose high.
    You have any side pics?
  4. Jul 10, 2019 at 11:52 AM
    #64
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    My rear shackles squeak too and i greased the new bushings before installing. When you say "the bolt is rubbing"...which bolt? The top bolt in the shackles?
  5. Jul 10, 2019 at 11:59 AM
    #65
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I'll post pics of the bolt in question when I go to trim it off. For now, words will have to do.
    It's not the shackle bolt. It's part of the truck, maybe a bed bolt. It protrudes down from the truck bed into the top flange of the frame, directly above the inside arm of the shackle, and makes contact with the rounded top of the shackle. You can't see it by sticking your head in the wheel well, or under the rear bumper. You have to be in between the leaf packs to really get a good view of it.
    monaco730[QUOTED] likes this.
  6. Jul 10, 2019 at 12:05 PM
    #66
    LiftMeUp
    Did you order new hardware with the shackles or use the existing bolts, nuts, lock washers, etc.?
    #66
  7. Jul 10, 2019 at 12:19 PM
    #67
    Danman34
    Danman34 New Member
    Danny
    BlackSheep likes this.
  8. Jul 10, 2019 at 12:25 PM
    #68
    monaco730
    16 Inferno Tundra
    Awesome, thank you. I will check this out tonight.
  9. Jul 10, 2019 at 1:49 PM
    #69
    monaco730
    16 Inferno Tundra
    Not even close to that bolt. You are because you are in the low setting on your shackles. If you were in top hole you would think have that problem.
    4E17CF04-1392-44B0-82DD-43E821D187D4.jpg EBF0E79E-CC24-4F34-B6A8-9745517D95F7.jpg
  10. Jul 10, 2019 at 2:10 PM
    #70
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Old school "hot wrench" fixes most. I've taken them out of muscle cars before with the torch method and a 2lb sledge. It's a good workout.
    LiftMeUp[QUOTED][OP] likes this.
  11. Jul 10, 2019 at 3:04 PM
    #71
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Got new hardware down at the local hardware store....pics are on my build page
  12. Jul 15, 2019 at 3:15 PM
    #72
    BlackSheep
    Scott
    Kansas City, MO
    So, my graphite lube only lasted the short 4 mile drive to work, then it was back to incessant squeaking again. Yesterday, I got out the Dremel and took care of both bolts. The ends were worn off pretty good; a wear spot about 1/4" long on each had been created by the shackles. I don't even know how I got the shackles installed correctly given how much rubbing there was! But the difference was immediate after cutting the ends off. I hopped up and down in the bed and the suspension made nary a sound! Thanks again, @Danman34 for the tip!
  13. Jul 16, 2019 at 8:40 AM
    #73
    LiftMeUp
    Crazy. I'm like you, how did you even get them on.
    Rica25 likes this.
  14. Apr 20, 2024 at 7:08 AM
    #74
    gsprenger
    gsprenger New Member
    Garrett
    2014 tundra SR5
    I recently received a full OME tundra lift kit without rear shackles. It is the budget OME kit with dakars in the rear. I did not order shackles simply to save money. But I’m worried about installing the dakars with the OEM shackles. If I have to use heat to remove them will it destroy the stock bushings? I just don’t want to get partway through the rear suspension and realize I needed the shackles. Let me know what you think! Btw still trying to save money!
    Black Wolf likes this.
  15. Apr 20, 2024 at 7:41 AM
    #75
    Did you consider getting the OME greasable shackles for just in case?
  16. Apr 21, 2024 at 6:08 AM
    #76
    gsprenger
    Garrett
    2014 tundra SR5
    I did yes consider it they are just so darn expensive. Mr wolf if you think I should then i probably will. Maybe if everything goes super smooth i can just return them. Thanks!
  17. Apr 21, 2024 at 6:14 AM
    #77
    Install everything you currently have and see how it works out. Shackles are easy to add if needed.
  18. Apr 22, 2024 at 6:50 AM
    #78
    gsprenger
    Garrett
    2014 tundra SR5
    Do you think I will have issues with the shackles after removing the old leaf's and installing the new ones? with the bushings or bolts being seized?
  19. Apr 22, 2024 at 9:47 AM
    #79
    Hard to tell if you will have issues. I've done something similar like this before and about to do this again. Both times with new poly bushings and new adjustable shackles. Your new Dakars should have new bushings. Did you order the Dakars with poly bushings?
