Rear Shackles - What You Running
Discussion in 'Wheels & Tires' started by LiftMeUp, Jul 6, 2019.
  1. Jul 8, 2019 at 9:26 AM
    LiftMeUp
    LiftMeUp [OP] New Member
    I may. Was going that route since only needed the inch and didn't want to spend that much on shackles, but now leaning back towards shackles as the better of the two options especially if I can get either the Maxtrac or the Pro Form Fab ones. I should make a decision this week though. Thanks.
    Inquiringone[QUOTED] likes this.
  2. Jul 8, 2019 at 9:27 AM
    LiftMeUp
    Sounds like we're in the same boat. People swear by changing out the bushings, hard as it sounds.
    Any issues or problems with the Maxtrac? How do you like?
  3. Jul 8, 2019 at 9:51 AM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Maxtrac is being shipped right now and I'm currently looking into the bushings. Did you go with the fat Bob's garage set up for the front. If u did how you like them?
    LiftMeUp[QUOTED][OP] likes this.
  4. Jul 8, 2019 at 10:53 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Your right the best way is shackles, not blocks. One of my mistakes when ordering parts, but sometimes it's what you can afford. :anonymous: Now I gotta rally my son to help put them on... We'll see how that goes.
  5. Jul 8, 2019 at 11:01 AM
    ricsha
    ricsha One is none, two is one.
    Rich
    Oregon Coast
    2019 Tundra Limited TRD
    Coachbuilder +1". Expensive, yes. Worth it, absolutely. They are massive, and hold the rear end steady with no side play. Bushings on a new '19 Limited came right out with no issues using cheapo ball joint press, but truck is only a couple of months old, so no rust issues. I can see where it would be an issue on an older truck. Great improvement in ride and handling.
    I'd never go with blocks, but that's me. I'm a firm believer in "Buy once, Cry once".
    Inquiringone likes this.
  6. Jul 8, 2019 at 11:07 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Coach builder all the way. You won’t regret the invest in ride quality, and durability.
    texasrho83 likes this.
  7. Jul 8, 2019 at 1:22 PM
    LiftMeUp
    I did go with Fat Bob's for the front. I went with their shocks and not the Bilstein since every pointed me in that direction. Love the look. It actually gave me a little over 3", like 3.25 after install. I knew it would but couldn't believe the difference in looks. The whole truck looks bigger. Actually haven't drove it except from the shop to home and it's only 5 miles or so. I didn't get the alignment yet, wanted to get it home, make sure I was sitting level left to right which I am, not Tundra lean on this one. Plus, my tires are at almost 60K and have to get new ones in the next couple of weeks, so figured, what harm. Probably get dropped off tomorrow or one day this week to align.
    But anyway, back on the subject, where did you order the Maxtrac from, Fat Bob's?
  8. Jul 8, 2019 at 1:25 PM
    LiftMeUp
    Contacted them and they were quick to reply. They can build a 1" but won't have the middle support but both said the same thing, so beefy, wouldn't be an issue. I wish I had both the 1" and 1.5" and install to see the difference. So many decisions......
  9. Jul 8, 2019 at 1:39 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    How high are you lifting the front?
  10. Jul 8, 2019 at 1:43 PM
    EAK
    EAK New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    Last I looked, there were a few members on here that had shackles for sale.
    LiftMeUp[OP] likes this.
  11. Jul 8, 2019 at 2:03 PM
    These will be going on my new to me tunny. Same as what I had on my 07. ToyTec adjustable shackles. Buy once, cry once just as with CB's
  12. Jul 8, 2019 at 2:08 PM
    Rubberdown
    Had the block on it when I bought it. It rides the exact same as the shackles do as far as I can tell. If I were romping it off-road I’d throw some shackles on it because they are inherently stronger than the block, but that’s about the only reason I’d ever worry about it.
  13. Jul 8, 2019 at 2:09 PM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I also went with Toytec and poly bushings from Energy Suspension. Ride quality has improved for sure, though some of that is because of new shocks as well. I have developed a terrible squeak, however, that I believe is coming from the bushings. I greased and installed one, and had a shop install the other, and they greased that one, too. So, I'm not sure what to tell anyone on how to avoid that, and it is awful. Truck sounds like it's a hundred years old driving through my parking garage at work.
    Black Wolf likes this.
  14. Jul 8, 2019 at 2:12 PM
    Those poly bushings shouldn't squeak, especially when greased.
  15. Jul 8, 2019 at 2:14 PM
    BlackSheep
    Scott
    Kansas City, MO
    That's what I thought. I used the grease included with the shackles, the shop used their own. Perhaps I'm wrong, maybe it's coming from the bolt and the metal sleeve, I can't tell. I know I've sprayed the hell out of both with WD40, PB Blaster, and a graphite lube designed for bushings, all to no avail.
  16. Jul 8, 2019 at 2:18 PM
    Could be the bolt and sleeve.
  17. Jul 8, 2019 at 2:23 PM
    BlackSheep
    Scott
    Kansas City, MO
    Nice new truck btw. Just checked out your build thread. Can't believe it, I didn't check in for only like a week and when I came back, you had changed colors!
  18. Jul 8, 2019 at 2:29 PM
    Yeah...I got a deal I couldn't refuse. I've got some things in mind for it already. The fun begins again!
  19. Jul 8, 2019 at 2:39 PM
    #49
    BlackSheep
    Scott
    Kansas City, MO
    I'll be watching your thread. My truck has a lot of the same 'character' your does, which I've never been too mindful of, but if you have good success making it look new again, I'll try the same on mine. :)
  20. Jul 8, 2019 at 2:53 PM
    #50
    Iowa12tundra
    2012 tundra crew
    https://maxtracstore.com/2007-2019-toyota-tundra-2wd-4wd-1-rear-lift-shackle-maxtrac-716710/
    I used this site. Go on website and give your email address to them and they give an extra 5 percent off.
  21. Jul 9, 2019 at 11:20 AM
    #51
    LiftMeUp
    Honestly, never even crossed my mind. I've searched for just about everything else for sale and never thought for this. Thanks, definitely check out.
  22. Jul 9, 2019 at 11:22 AM
    #52
    LiftMeUp
    I installed 3" lift coilovers. they actually gave me about 3.25" of added height. My truck had odd measurements, my rear was just about 3" higher then the front so with the coilovers I was looking to level. But now the front is about .25 higher. Which I have to buy some shackles now, but at the same time, I get to lift the rear as well, so not bad. From talking to a couple of people, my fronts were lower than normal and rear higher which made the 3" difference.
  23. Jul 9, 2019 at 11:22 AM
    #53
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The squeaking is coming from the shackle hitting a bed bolt. Known issue with shackles in the 1” position.
  24. Jul 9, 2019 at 11:23 AM
    #54
    xtyfighterx
    Ty
    North Idaho
    Go 1.5 in the rear that’s the best combo I have just over 3” on my truck and 1in didnt look right I now have a canopy so I did 2” shackles. 1.5 will be perfect with your lift
  25. Jul 9, 2019 at 11:23 AM
    #55
    LiftMeUp
    Yeah, after asking and talking to others, they are all pretty much level or like .25 or .5 inch higher in rear. 1", a true 1" would give me a difference of .75 in rear which would be just fine. Afraid if I go with 1.5" shackles, too much rake for my liking.
  26. Jul 9, 2019 at 11:24 AM
    #56
    LiftMeUp
    Yeah, I'm not totally anti block. No offroading so don't need the extreme. But I know shackles are the better route and turns out they should run close to same if not a tad cheaper, so just about set on shackles.
  27. Jul 9, 2019 at 11:25 AM
    #57
    LiftMeUp
    Rica25 likes this.
  28. Jul 9, 2019 at 11:27 AM
    #58
    LiftMeUp
    Man, just when I thought I was set, now you've got me thinking again!
  29. Jul 9, 2019 at 1:20 PM
    #59
    xtyfighterx
    Ty
    North Idaho
    Trust me 1.5 on a 3” lift is a perfect stance. If you go 1” anything in the bed will put you nose high. And even making it that level to the eye it stick looks nose high even if the tape says different these trucks are just designed to where the front looks higher when leveled and for $60 you can’t lose much I have a 1” block I’ll even send you for free if you don’t like the look of 1.5 shackles
  30. Jul 10, 2019 at 10:16 AM
    #60
    BlackSheep
    Scott
    Kansas City, MO
    I've searched every rear end squeak thread i can find on this forum, and have not heard of this until now. I crawled under my truck this morning, though, and sure enough, the bolt is rubbing the top of the shackle! It's most visible viewed from the angle where the spare tire mounts. I didn't notice it at all when I installed the shackles. The only lube I had left is that graphite stuff, so I sprayed it down, and that made a noticeable difference on the way to work today. I think I'll crawl under there again with a grinder and take care of that bolt for good, though.
    Thanks for pointing this out! I love this forum.
