Rear Seat removal to fit Sub box with 2 12's?
Discussion in 'Audio & Video' started by e_murda, Jul 7, 2021.
  1. Jul 7, 2021 at 8:24 PM
    e_murda
    e_murda [OP] New Member
    Eric
    19 Super White Tundra
    Rough Country Level kit Hard rock off road 20" wheels -19 offset Bushwacker Fender flares Recon lighting smoked tail lights and third brake light
    Hey not sure if this is the right place to post this, but I'm needing some guidance. In my 19 Tundra crew max Im wondering if i could take out the Drivers rear seat and replace it with a bucket seat so I can have two bucket seats in the back, Then put a box with 2 12 in subs in the center of the two rear seats. Has anyone done this? Was wondering if i could possibly find another front passenger seat and replace the drivers rear seat with it.
  2. Jul 7, 2021 at 8:59 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Could you do it?
    Sure, with a ton of custom modification..
    The front and rear seat mounts have nothing in common..
    Trade that Tundra in for a Sequoia..
    Plenty of room for 2 12s..:thumbsup:
    Welcome to the forum..:D
  3. Jul 7, 2021 at 9:06 PM
    e_murda
    Eric
    Yeah I figured as much. Was hoping there would be a simpler solution I wasn’t seeing. The new sequoias are pretty nice though ngl lol
  4. Jul 7, 2021 at 9:19 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Pull the 60 seat out and purchase another 40 and mounting hardware identical to the rear passenger side seat. May take some fab work but it should be possible. Should have about a little over a foot between them. Could also fab the top of the box into a center console of sorts.
    Also, for what it's worth.. they make dual 12 sub boxes that fit behind the rear seat, shallow mount subs.. but the 12 inch JL TW3s hit hard
    1lowlife and e_murda[OP] like this.
  5. Jul 7, 2021 at 9:38 PM
    e_murda
    Eric
    I been having trouble finding a box that will fit 2 12’s behind the seat. Could you give me some names? The only ones I can really find are taco tunes and fox acoustics
  6. Jul 7, 2021 at 9:51 PM
    YotaMan
    Colorado Springs
    2021 Platinum
  7. Jul 7, 2021 at 9:51 PM
    Tundra@AZ
    Tundra@AZ New Member
    2021 MG Tundra
  8. Jul 7, 2021 at 9:53 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    Throw 2 12 inch JJ Audio TW3s and a 1000 watt amp and that thing will slam. May add some polyfill as well
  9. Jul 10, 2021 at 5:14 AM
    Bronco Ken
    Bronco Ken New Member
    Ken
    MGM 1794
    I purchased my 2 12" box from Amazon. The only thing you have to do is elevate it about an inch so the seat will lower correctly. I put dual Infinity shallow 12" subs in. Much better even with stock JBL system.
  10. Aug 19, 2021 at 12:32 PM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    I’ve done it on a Chevy Silverado. Used two captains seats out of a Chevy conversion van. You should be able to use the rear single seat out of a double cab. Might have to fabricate your own mounting brackets but it’s definitely do able
  11. Aug 19, 2021 at 12:42 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    James at tech12volt makes boxes (ported or sealed) for the 10 or 12 JL tw3's
    https://shop.tech12volts.com/product.sc?productId=335&categoryId=125
    shoot him an email tech12volt@gmail.com and he can set you up. he also has really good prices (better than what i was able to find online) on just about everything.
  12. Aug 25, 2021 at 6:34 AM
    KingKong
    KingKong New Member
    Asher
    2008 Super White Double Cab Long Bed 4x4
    Definitely do this. James is the man and can make you a behind the seat box that maximizes available airspace as well as recommend what subs work best for that box.
  13. Aug 25, 2021 at 6:55 AM
    Danimal86
    Daniel
    Sacramento, CA
    this is what OP needs. lol
    23215528_10155814444177528_5545631810883_e9e81202620f8226b5c52160a067d9c6b8a22a70.jpg
  14. Aug 25, 2021 at 8:00 AM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
  15. Aug 25, 2021 at 8:21 AM
    Danimal86
    Daniel
    Sacramento, CA
  16. Aug 25, 2021 at 8:30 AM
    KingKong
    KingKong New Member
    Asher
    That's what I'll probably end up going with in the future in one of James's ported under-seat boxes for the double cab. But right now I've got 2 12" Polks in a sealed box a buddy gave me and just having fun trying to kill them with a RF Prime 750 (birth sheet says 955 at 1% THD).
  17. Aug 25, 2021 at 8:31 AM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    When you're old and married, subs aren't really an option. Every time you turn up the music, wife will tell you it's too loud and as you to turn it down.
  18. Aug 25, 2021 at 8:56 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    No wife - yes subs!!!
  19. Aug 25, 2021 at 9:04 AM
    FirstTruck
    Stock, for now
    Build yr own box. 16 h x 7 bottom / 3 top x ? L. The L will be determined by the cuft needed. Max angle is 15 degrees. I was able to fit 2 JL 10w1v3’s.
  20. Oct 7, 2021 at 10:56 AM
    KingKong
    KingKong New Member
    Asher
  21. Oct 7, 2021 at 4:41 PM
    Danimal86
    Daniel
    Sacramento, CA
