Rear seat removal on 2019 crewmax
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tipster, Mar 11, 2019.
  1. Mar 11, 2019 at 2:58 PM
    Tipster
    Tipster [OP] New Member
    2019 Tundra 1794 2x4 TRD
    Bed Topper
    I don't know yet how to search for posted articles but has anyone ran into a problem removing the rear seat in the new crewmax. Besides the front and rear mounting bolts I have found a center bolt coming from the bottom up threading into the seat. I want to remove the seats temporarily to install a storage system beneath.
  2. Mar 11, 2019 at 3:12 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    It should just be the front and rear mounting bolts. There is an alignment tab that may be giving you some trouble? Remove the bolts and rock the seat forwards or backwards to loosen the alignment tab. The whole seat will pull up and out. Make sure you are careful to keep track of the one bolt with different threads. Also, the alignment tab has been known to puncture the carpet/ floor mats so an extra pair of hands is extremely helpful.
  3. Mar 11, 2019 at 3:13 PM
    KnuckleHD
    Also, just an FYI. There is a small magnifying glass icon in the top right corner of the page. That’s your “search” function. You can search for individual posts or thread titles. It’s actually super helpful!
  4. Mar 11, 2019 at 3:17 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Just an FYI depending on the storage item. If you are using the ESP storage container there is no need to remove the seats.
  5. Mar 11, 2019 at 3:17 PM
    Tipster
    Bed Topper
    Screenshot_20190311-181115_Google.jpg Thanks, this is a picture I found that might help.
  6. Mar 11, 2019 at 3:39 PM
    Radioclash75
    Radioclash75 New Member
    Hooper
    Chicago area
    2018 Tundra Sport 5.7FlexFuel. Black-Beauty
    Was looking at the esp, didn’t know you can do it with seats in! Doesn’t the storage unit bolt in to the seat bolts?
  7. Mar 12, 2019 at 12:38 PM
    token2k6
    token2k6 New Member
    2021 Tundra CM SR5
    Hey! The ESP does not bolt to anything. You use fabric crayon to draw the outline from the box it ships in, then a sharp knife to cut it up. I am not a DIYer at all, my wife was skeptical as hell I was cutting up a 3 month old truck..but it all worked out! I love the ESP standard storage I bought a year ago. There is no increase in road noise whatsoever.
    And yeah, I removed the back bench seat when I got my Wet Okole seat covers in. Then bench removed easily when all the bolts on the top were removed. I did not see anything coming up from the bottom threading in. This is a 17 SR5 CM I have. When you pull the screws, get two cups, b/c they aren't the same size! I have one screw that I could never get back down all the way, so it's sticking up, but figure it will be OK with all the other bolts being good.
  8. Mar 12, 2019 at 1:03 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    If he got the locking metal esp box, it DOES require removal of the seats, and like someone else said, remember which bolt was the different one, it will make your life much easier.
  9. Mar 12, 2019 at 2:12 PM
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    In addtion to that, you can get a good search return on multiple words if you use the pipe command between them.
    Toyota|camry|hybrid would give you returns on Toyota Camry Hybrid. It allows you to narrow the search to those three words inclusive if I remember correctly.
  10. Sep 9, 2019 at 7:20 PM
    Willy224
    Willy224 New Member
    Andy
    2019 Cav Blu Tundra TRD Off-Road
    I just ordered a set of Wet Okole seat covers for my 19 Tundra, were they hard to put in? How did you get the seat backs off to secure them around those?
  11. Sep 9, 2019 at 10:15 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I installed Katzkin leather back in June.
    Remove the head rests. Hinge the seats up. Remove the 6 prominent bolts that are holding the seat frames to the floor. You’ll also need to remove the bolt holding the center shoulder belt to the floor. Leave the seats folded and lift them out carefully. Install is the reverse, and there are locator pins on the floor brackets to help you position the seats back in the truck.
    Astom22 and Willy224 like this.
