Rear passenger Axle will not go into the differential, Help!
Discussion in '1st Gen Tundras (2000-2006)' started by TeagueExpeditionary, May 25, 2023.
  1. May 26, 2023 at 3:27 PM
    TeagueExpeditionary
    TeagueExpeditionary [OP] New Member
    2001 Tundra Limited TRD 4wd
    full camper drawer system, 33" Skinnies, steelies, 2.5" OME front, 1.5" ICON aal rear, Midland GMRS, hard mounted scanguage, pioneer headunit,
    I just hit it with a file and it definetly went in further, it got stuck actually maybe a 1/4in deeper?? but still did not go in all the way. I'm gonna keep going and hit every spline again and see if it's any easier.
    2mchfun likes this.
  2. May 26, 2023 at 3:29 PM
    2mchfun
    I almost think you could simply bolt a box end of a wrench over a lug stud to help you easily gain some leverage to lift the end easier
  3. May 26, 2023 at 4:04 PM
    TeagueExpeditionary
    Slowly filing the end seems to be making progress incredibly slowly
    2mchfun likes this.
  4. May 26, 2023 at 6:26 PM
    TeagueExpeditionary
    Hell yeah, got the axle in. Now I just pray to god it doesn't leak lol
    FirstGenVol, DZ_, des2mtn and 3 others like this.
  5. May 26, 2023 at 6:59 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Hell fuckin yeah! I went to check my phone and was about to ping you for status. :thumbsup:
  6. May 26, 2023 at 7:02 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I fuckin hate it when you’re wrenching on the truck and shit goes sideways for no fucking reason at all. Cheers time! :cheers:
  7. May 26, 2023 at 8:51 PM
    TeagueExpeditionary
    Cheers!! and now I go to install my new drums and there is a huge chunk out of them, I should have inspected them more thoroughly ffs. Gonna try to reuse my old drums by soaking them in brake clean, heating them, and soaking them some more.
    sometimes these things are really annoying lol
  8. May 26, 2023 at 8:51 PM
    TeagueExpeditionary
    seriously the amount of help I've gotten on this forum is staggering thanks y'all for all the support!!
    MD0811, DZ_, 2mchfun and 1 other person like this.
  9. May 26, 2023 at 8:55 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Help, you want help ?
    Convert that thing to rear discs while you have it apart since your drums are bad anyway. You're welcome. lol
  10. May 26, 2023 at 9:03 PM
    TeagueExpeditionary
    Lmao honestly at this point I'm a step away from going that route, I hate this lmao
  11. May 27, 2023 at 6:03 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm telling you, it's because it wasn't lubed up. It's a bitch to get them in if you don't lather them in diff juice.
    FrenchToasty likes this.
  12. May 27, 2023 at 11:39 AM
    TeagueExpeditionary
    Definitely factored in, filing and lubing was the trick
    2mchfun likes this.
  13. May 27, 2023 at 1:00 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Dang I just ordered the parts to do my axle seals, this thread makes me wanna pay a mechanic to do it :rofl:
    glad you got it back together
  14. May 27, 2023 at 11:18 PM
    Aerindel
    Aerindel New Member
    Montana
    The OP was just unlucky. Usually it's a none issue.
  15. May 28, 2023 at 3:04 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Like everything in life, lube is the key. You can do it!
  16. May 28, 2023 at 11:54 AM
    TeagueExpeditionary
    Everything is almost done, went and bought new drums gonna get the broken pair refunded. Spidertrax spacers are on to eliminate the frame rub from the 33s. Now we just need to bleed the brakes and bed them in and all will be done for now.
    bmf4069 and NewImprovedRon like this.
  17. May 28, 2023 at 1:33 PM
    Aerindel
    Aerindel New Member
    Montana
    Make sure your parking brakes is adjusted and functional. Replacing axle seals is how I ended learning how to make our rear drum brakes work properly. It wasn't as straight forward as I thought.
  18. May 28, 2023 at 2:44 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I had a hard time getting mine back in until I tried twisting them as I smacked them with my dead blow. That did the trick. Glad you got it sorted out.
  19. Oct 6, 2024 at 10:08 PM
    #49
    Eddihotness
    Eddihotness New Member
    Soo hitting it with a file and lubbing it did the trick?
    I’m also stuck 1/2 gap and it won’t go in
  20. Oct 7, 2024 at 5:45 AM
    #50
    shifty` Waving My Dick In The Wind
    Tagging @bmf4069 so he sees this and knows he needs to respond to it.
    bmf4069 likes this.
  21. Oct 7, 2024 at 9:57 AM
    #51
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You have to lube the shaft before you put it in. No, seriously. Take that gear oil and cover the axle in a light coat.
    shifty`[QUOTED] likes this.
