Rear license plate hardware stripped out
Discussion in '2.5 Gen Tundras (2014-2021)' started by Heath423, Aug 20, 2020.
  1. Aug 20, 2020 at 9:34 AM
    Heath423
    Heath423 [OP] New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Got my new license plate in the mail. Went to remove the drive out tag and found that the left screw was stripped out and only the right one was holding it on. After investigation the tag screws only thread into a piece of plastic. Is that normal or did the dealer perhaps not install the correct hardware?
  2. Aug 20, 2020 at 9:44 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Not unusual you will have to get some bolts, washers, lock washers, and nuts. Pretty easy fix. I just told the wife last night one of mine are strip and I’m going to the store today or tomorrow.
  3. Aug 20, 2020 at 9:57 AM
    Heath423
    Heath
    Chattanooga, TN
    Yeah, there is a good piece of steel with manufactured holes for that purpose it looks. You would think it would come with something different or a welded nut on the back side.
  4. Aug 20, 2020 at 10:18 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Exactly what I did with my 2nd gen Tundra. However, I didn't use lock washers on mine. I have a washer and nut on the backside and was rather tough to hold them in place with the spare tire in the way.
  5. Aug 20, 2020 at 10:20 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Aug 20, 2020 at 10:23 AM
    Black@Blue19
    Ken
    SE Texas
    Mine is in plastic up front and back. Not a good setup for what the trucks are for sure.
  7. Sep 17, 2020 at 6:38 AM
    RitcheyRch
    Richard
    Santa Clarita, CA
    Could also try and find some u-shaped spring nuts like pictured.
    Heath423[OP] and Jim LE 1301 like this.
  8. Sep 17, 2020 at 6:48 AM
  9. Sep 17, 2020 at 7:34 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    Dont know what the previous owner used to hold his plate on with, but the holes were too big. Had a toilet install kit laying around so thats what is holding mine on.......brass bolts threaded from the backside and trimmed right at the nut. It works so I never even considered replacing.
    RitcheyRch likes this.
  10. Sep 17, 2020 at 8:08 AM
    Tisoy281
    Tisoy281 New Member
    Same happened with mine, front and back. I got some zip ties and cut them into short strips and held them in the holes while I tightened the screws. Held up good so far.
  11. Sep 18, 2020 at 5:07 AM
    RitcheyRch
    Richard
    Santa Clarita, CA
