Rear leafs are flat
Discussion in '2.5 Gen Tundras (2014-2021)' started by Porkchop Express, Feb 1, 2023.
  1. Feb 3, 2023 at 6:45 PM
    #61
    blenton
    blenton New Member
    Ahh. Just curious. People always tell me people die when I do stuff like that.. I thought maybe I might be a cereal killer but it turns out I’d prolly be classified as a mass murderer instead… Or maybe that’s PETA..
  2. Feb 5, 2023 at 10:21 AM
    #62
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    (Responding to, … “Of course, you are looking at downtime for your truck.”)
    How long is the downtime? That depends on the business’ schedule.
    What is the cost of having downtime? That is for the vehicle owner to determine.
    The idea is to support a local business and prevent waste by recycling. This may not always be feasible. I was throwing out the idea for consideration.
  3. Feb 5, 2023 at 10:57 AM
    #63
    2mchfun
    I like that you want to try and prevent waste, but you might as well throw that idea aside on this site. Folks around here replace pristine parts all day everyday just to color match and such. Not to mention driving v8 lifted trucks to take the kids to school and go to work. Just a reminder.
  4. Feb 7, 2023 at 10:17 AM
    #64
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    What I wanted to know was the cost of getting springs rearched, and how long it took... a day, week, month? If they cold set them, you should be able to make an appointment and have it done in a day. If they heat treat them, it would take longer.
  5. Feb 7, 2023 at 10:25 AM
    #65
    Vizsla
    Vizsla 2 = 2.5
    I’ve had springs re-arched/modified a few times. Cost was $500-$600, dropped off vehicle and picked up same day. Last time was 2 years ago, so the price of steel and everything else has gone up, would expect price to reflect that.
    rruff[QUOTED] likes this.
  6. Feb 7, 2023 at 10:26 AM
    #66
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If it's much more than that, might as well buy a new pack.
  7. Feb 7, 2023 at 10:41 AM
    #67
    rruff
    rruff New Member
  8. Feb 7, 2023 at 10:47 AM
    #68
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  9. Feb 7, 2023 at 10:50 AM
    #69
    2mchfun
    Went a different route here, put on the RAS HD kit and the Yellow Sumo springs to prevent my Dobinson's springs from getting flattened to begin with. So far, working well, and I think it will last for a long time.
  10. Feb 7, 2023 at 10:55 AM
    #70
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    How tall are the Sumos?
  11. Feb 7, 2023 at 11:01 AM
    #71
    2mchfun
    Depends on how much weight you add! JK, about 6.5" from the top of the leaf pack to the weight bearing surface. From there, they are easily cut with a hand wood saw like a stiff back miter saw or even a bread knife would work.
  12. Feb 7, 2023 at 11:19 AM
    #72
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I doubt I'd need to cut it lol
    2mchfun[QUOTED] likes this.
  13. Feb 7, 2023 at 4:17 PM
    #73
    Porkchop Express
    Porkchop Express [OP] Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    I think I will end up using these “newer” OEM leafs with rubicon greaseable bushings and then set my Toytec shackles for the 1.5” lift.
    I don’t think I will benefit from a set of Timbren or Sumo Springs - right now - but may upgrade in the future.
    Terndrerrr likes this.
  14. Feb 7, 2023 at 4:39 PM
    #74
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    That's WAY over the GVW! :annoyed: You can't do that! LOL.............
    Leo's first likes this.
  15. Feb 7, 2023 at 4:50 PM
    #75
    2mchfun
    I had a flat on the front and my jack was too short!
  16. Feb 8, 2023 at 6:09 AM
    #76
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    The only thing I would be concerned about—as a fellow OEM spring pack user—is the longer distance from your frame to your bump stops due to the Toytec shackles. Extra travel means extra inverting of the spring pack which leads to faster wear. I would at least do some kind of extended bump stop to make up for the added height from the Toytecs. Bump stops are cheap.
    rruff and 2mchfun like this.
  17. Feb 8, 2023 at 9:20 AM
    #77
    rruff
    rruff New Member
    ^^^ This. Wish it was more universally known. Spring packs have a limited range where they can flex and still last a long time.
    2mchfun likes this.
  18. Feb 20, 2023 at 9:24 PM
    #78
    Porkchop Express
    Cody
    2017 Tundra CM
    Will do , thanks for all the input
