Rear leaf springs question
Discussion in '1st Gen Tundras (2000-2006)' started by Tundyfan, Jul 25, 2018.
  1. Jul 25, 2018 at 6:53 PM
    Tundyfan
    Tundyfan [OP] New Member
    Doug
    2006 DC Salsa Red
    What are our options? Does OME actually make a full pack for our Gen? I'm curious to know what people run and what are your opinions if if you have it. Looking to upgrade mine to make towing a 4500lb trailer a better experience as well as some better off-road performance.
  2. Jul 25, 2018 at 7:25 PM
    OME Dakar rear leafs. Replaces OEM and gets you 2.5" lift.
    LaaMahTundra likes this.
  3. Jul 25, 2018 at 8:01 PM
    Casper421
    In the woods
    06 DC
  4. Jul 25, 2018 at 9:56 PM
    Tundyfan
    Doug
    2006 DC Salsa Red
    Any chance you have a link to these?
  5. Jul 25, 2018 at 9:57 PM
    Tundyfan
    Doug
    2006 DC Salsa Red
  6. Jul 25, 2018 at 10:08 PM
    Casper421
    In the woods
    06 DC
    He mentioned springs for 07+. Won’t fit our 1st gens.
  7. Jul 25, 2018 at 11:19 PM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    I had ome on my Tacoma with Dakar rear leaf pack and loved it. I didn’t do much towing with it just light towing with a quad and an enclosed trail and some gear every once in a while, I’d say 5k max and it handled well enough for me. So I just ordered the same set up for my tundra. Again I don’t tow much so I’m not too worried about weight and sagging, I’m sure it’ll handle it fine when need be.
    With that said I’ve seen a few post on the forum that don’t highly recommend Dakar for towing (https://www.tundras.com/threads/ome-dakar-leaf-springs-help.22095/) There are other options out there but better options usually mean more overtime so
    Tundyfan[OP] likes this.
  8. Jul 26, 2018 at 3:58 AM
    I just now realized you have a 2006 1st Gen. Call David at Toytec. He may have a few options for you.
    Tundyfan[QUOTED][OP] likes this.
  9. Jul 26, 2018 at 4:02 AM
    Yep. Wrong Gen.
  10. Jul 26, 2018 at 6:12 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm running Alcan, they build to order. You can even go through wheelers to order them like I did.
    When mine arrived the smallest 2 or 3 springs on one pack was on backwards. Called old Bob at Alcan and he sent me a new center pin so I could unbolt and correct the pack. Wasn't a big deal, no problems since and they've been on for maybe 6 years. The do run maybe 3 mm skinnier than stock at the eyelets, I ran a slim washer between the hangers and the bushing sleeve.
    Maybe doesn't sound like a great experience but they've been good other than that :rofl:
    mtntop and Tundyfan[OP] like this.
  11. Jul 27, 2018 at 4:23 AM
    Professional Hand Model
    Hand Protectors
    Maybe yours were made on a Monday morning?
  12. Jul 27, 2018 at 6:17 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah either that or 4pm on Friday :cheers:
  13. Jul 31, 2018 at 12:55 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I will second Alcan, I put them on my 2004 and they were a tremendous improvement, I carry a lot of weight and tow a boat and unloaded they seem to accommodate our rocky trails well and smooth the ride out.
  14. Jul 31, 2018 at 1:06 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  15. Jul 31, 2018 at 1:41 PM
    Tundyfan
    Doug
    2006 DC Salsa Red
  16. Jul 31, 2018 at 2:02 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Most of that is not related to Gen 1.
    As far as I am aware, Alcan can make anything you ask for in terms of how much weight do you want to carry vs how much lift do you need. Softness depends on the first part of that calculation, but mine are much softer than stock.
    Deaver has a few pre determined packages which work well but can be overcome by weight. I have heard they will make custom packs when asked, but never tried it.
    Don't know about any others, most 3 leaf add-on packs work as advertised to give lift but take away from weight capacity unless you retain the overload spring (I have seen some do this).
    Don't use blocks lol.
    01erionracing likes this.
  17. Jul 31, 2018 at 2:10 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I know @01erionracing is running a Deaver pack, I forget which one.
  18. Jul 31, 2018 at 2:14 PM
    Tundyfan
    Doug
    2006 DC Salsa Red
    I figured .I just submitted the form to Alcan with my specs .How much did Alcan set you back if don't mind me asking?
  19. Jul 31, 2018 at 2:51 PM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    It is Deaver U512 (light medium) and also size specific because I asked them .5 -1" taller on the driver side.
    I had Alcan HD pack (800 lbs) built on my Jeep before, they are well build as well.
  20. Jul 31, 2018 at 2:58 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I can't recall, it's been about 6 years since I bought them.
    Tried checking for the sale slip but couldn't find it. I wanna say just under 800 shipped, and I went with the black long life bushings. Didn't want to use red squeaky ones since there is no zero fitting.
  21. Aug 17, 2018 at 11:15 AM
    Edit.....my goof...for 2007+
