Rear end shudder....
Discussion in 'Suspension' started by HBdirtbag, Feb 25, 2018.
  1. Feb 28, 2018 at 10:46 AM
    HBdirtbag
    HBdirtbag [OP] New Member
    Walnut Creek, CA
    2017 limited cm
    100%, i've been a gear head for a long time......and always had the philosophy, you aren't having fun if shit doesn't break.......and be prepared to pay to play :). That said, I'd be pretty disappointed if my diagnosis of a blown shock is correct. But, I did give it a good work out. Go big or go home.....
  2. Feb 28, 2018 at 10:49 AM
    I have blown some shocks from getting all four wheels off the ground before. However, they were sport quads and I was barking at the moon.
    I'm actually hoping it is a blown shock. That is cheap(ish) to fix.
    Its kinda like with my Jeep parts. I do have a weak link in my drivetrain. Some of my buddies like installing 300M axle shafts and high dollar shit like that. Then they explode lockers and gear sets. When I break a 14B shaft, I just get one of the 25.00 spares and say, "well that sucked" and continue wheeling. To date, I haven't broken one shaft.
    HBdirtbag[QUOTED][OP] likes this.
  3. Feb 28, 2018 at 11:00 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    now...where I do get pissed, i had a heater malfunction in an aquarium where I was on my 8th generation of selective breeding.....lost about $500 worth of shrimp and 3.5 years.......
    TheBeast likes this.
  4. Feb 28, 2018 at 11:04 AM
    Your getting the bunny sir.
    TheBeast and BlueBottle like this.
  5. Feb 28, 2018 at 11:16 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    dang
  6. Feb 28, 2018 at 11:31 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    yea, it's one of those things I try not to admit in public.............i basically have an obsession with .5" ornamental chinese dwarf shrimp..........
  7. Feb 28, 2018 at 11:37 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    show us
    ColoradoTJ and BlueBottle like this.
  8. Feb 28, 2018 at 11:52 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
  9. Feb 28, 2018 at 11:54 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    No need for a cb drop for 1” lift in my experience. I’m well over that with no shudder. Not sure what ur issue is but I doubt it’s the driveline or anything. I’ve got stupid in my truck. They can take a nasty beating. And even when I blew my Kings in the rear it didn’t give a noticeable shaky ride. Curious about what u find out
    831Tun likes this.
  10. Feb 28, 2018 at 11:57 AM
    speckmon
    Thornton, CO
    ya freak
    jk, nice setup
    BlueBottle likes this.
  11. Feb 28, 2018 at 2:52 PM
    Damn. That’s pretty cool.
    How do they taste? :D
    Jk
    BlueBottle, 15whtrd and 831Tun like this.
  12. Feb 28, 2018 at 2:57 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe a good time to change your diff fluid and see how it looks.
    ColoradoTJ and 831Tun like this.
  13. Feb 28, 2018 at 4:21 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Truck only has like 6,000 miles on it...
  14. Feb 28, 2018 at 4:49 PM
    15whtrd
    15whtrd Mr. Blonde
    Anything could happen. I’m sure I overdid it but I changed my fluids in both difs and transfer case at 5 K I think. I felt like I just wanted all the break in stuff out of it. Sounds like you’re pretty hard on your truck. And although these trucks are pretty stout there could’ve been discrepancies in the assembly of the rear end from the get-go.
  15. Feb 28, 2018 at 5:16 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Have you done your diff relocate @HBdirtbag ? If not you better do that if you do any water crossings!
    15whtrd likes this.
  16. Feb 28, 2018 at 5:20 PM
    I changed my diff, xcase, motor 2nd time by 5k. I’m glad I did the diffs. That oil looked like crap.
    15whtrd likes this.
  17. Mar 2, 2018 at 10:03 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    After driving it down to a shop to look at it. I’m 90% sure it’s the passenger side rear shock I blew. Will let them confirm
    ColoradoTJ likes this.
  18. Mar 3, 2018 at 7:27 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Update. Turns out the shackles were binding from either being over torqued in the air or getting mud/sand stuck in them. Was causing the leaf springs to not have any give. All solved :)
  19. Mar 3, 2018 at 7:45 AM
    #49
    15whtrd
    15whtrd Mr. Blonde
    Glad you got it fixed!
  20. Mar 3, 2018 at 8:02 AM
    #50
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Well that was anticlimactic. Good news for you.
    15whtrd likes this.
  21. Mar 3, 2018 at 8:03 AM
    #51
    15whtrd
    15whtrd Mr. Blonde
    :rofl::rofl:
  22. Mar 3, 2018 at 8:09 AM
    #52
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You were expecting triple bypasses from this huh.
    831Tun[QUOTED] likes this.
  23. Mar 3, 2018 at 8:09 AM
    #53
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :thumbsup:
  24. Mar 5, 2018 at 5:52 AM
    #54
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    2.5's on the rear will still probably happen lol
    831Tun likes this.
