Rear end noise, lemon?!?!?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by RedBarca19, Jan 22, 2020.
  1. Jan 29, 2020 at 4:24 PM
    RedBarca19
    RedBarca19 [OP] New Member
    2019 4x2 CM SR5
    Got my truck back today, finally, they replaced both rear axle shafts, bearings, calipers, rotors, pads, everything in the rear just about except for the rear diferential, 4500 worth of work. I hope this is the end of the ordeal and i hope this thread helps anyone that is having this issue.
    GODZILLA and ryandv like this.
  2. Jan 29, 2020 at 4:26 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    this.....my rear axle was replaced 500 miles in because the axle was out of specs
  3. Jan 29, 2020 at 5:13 PM
    RedBarca19
    2019 4x2 CM SR5
    You are the third to one i know of with a 2019 that has had this issue.... wonder if a recall will happen
  4. Feb 3, 2020 at 11:59 AM
    Mojoe
    Mojoe New Member
    MD
    2019 TRD Pro
    My 2019 Pro had to have the axles replaced for the same reason, at less than 3,000 miles on the truck. Got it all sorted out after 2 or 3 trips to the dealer.
  5. Feb 3, 2020 at 12:06 PM
    RedBarca19
    2019 4x2 CM SR5
    That is great news... did you feelthe truck any different, im feeling some vibration inside the truck after i picked it up but could be me being paranoid or just never noticed since i was so darn focused on the noise. Not to mention i got new aftermarket wheels installed three days before it went in for a week for the final fix.
  6. Feb 3, 2020 at 1:08 PM
    Mojoe
    Mojoe New Member
    MD
    2019 TRD Pro
    For me it road flawlessly after the fix. I’ve put about 8k miles on it since then without issue! I’m on the stock pro wheels and tires for now for what that’s worth.
  7. Feb 3, 2020 at 2:51 PM
    RedBarca19
    2019 4x2 CM SR5
    Im glad yours is working so great.
  8. Feb 4, 2020 at 3:45 AM
    Mojoe
    Mojoe New Member
    MD
    2019 TRD Pro
    Best of luck with yours! Here’s to hoping you just need a tire balanced to solve your vibration.
  9. Jun 13, 2021 at 1:44 PM
    BPilk18
    BPilk18 New Member
    19 tundra crew max
    Well I’m glad I finally food this thread! Mine is doing the exact same thing!
  10. Sep 25, 2021 at 7:35 PM
    PugsTundra
    PugsTundra New Member
    2021 Platinum Wind Chill Pearl
    bought a 2021 Platinum with 3 miles at 34 miles (you read that right only 34 miles) driver's side rear axle shaft is bent! Is this a common issue?
  11. Oct 10, 2021 at 12:58 PM
    FauxTRD
    FauxTRD New Member
    Matthew
    16 Tundra SR5
    I have a 16 SR5 CM 4x4 with 61k on it, and just started noticing a noise from the rear end, if it’s a bent axel/s and Toyota doesn’t cover it I’ll never buy a Toyota ever again.
