Rear Differential Skid for 07+ Tundra - CAD Drawings and Feeler
Discussion in 'Deals & Group Buys' started by boardude, Apr 19, 2018.
Thread Status:
Not open for further replies.
  1. Apr 30, 2018 at 8:54 PM
    #151
    Vizsla
    Vizsla 2 = 2.5
    Be careful, the lock(nylon) part of the lock nuts does not engage the stud, and they can fall off:anonymous:. I ended up shimming above the skid with washers and using thread locker with the oe nuts to reduce the protrusion some. The description seems to have changed...
  2. Apr 30, 2018 at 9:06 PM
    #152
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    For your truck all their skids are great. Mine have taken some good hits and done their job quite well. I'd buy 'em again but I'd never buy the tank skid for my 38 gal. tank. I'm not sure what I'm gonna do about that. I'll probably try to reinvent the wheel.
  3. May 1, 2018 at 3:57 AM
    #153
    RCI was at the FJ event at ToyTec last Sunday. I lifted up a front skid for an FJ. Very beefy.
    831Tun[QUOTED] and GodlessPro like this.
  4. May 2, 2018 at 10:41 AM
    #154
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Terrible design for a diff skid. That thing will cause more problems than just running without a skid. :der:
    831Tun likes this.
  5. May 2, 2018 at 11:28 AM
    #155
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    carriage bolts work. that's how my budbuilts are mounted.
  6. May 2, 2018 at 11:36 AM
    #156
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I had to switch my carriage bolts out. they are ss and they kept galling so I switched to grade 8 yellow zinc hex heads.
    Black Wolf and smslavin[QUOTED] like this.
  7. May 2, 2018 at 11:37 AM
    #157
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    might wind up doing that myself
  8. May 2, 2018 at 1:04 PM
    #158
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    I quintuple these concerns. If this dude does CAD work, is he an engineer? If so, he should know better. The concern itself is not the bolts. They will be in shear to what I presume to be 1/8” to 1/4” plate. At least I hope it is.... Anyway, the shear point of those bolts is probably really high. I can probably calculate it, but it would be unnecessary. The issue becomes the base material these studs are in. With this design, the bolts will be affected by a moment in the direction they aren’t designed to take a load, so my concern would be diff side failure. At minimum, leaks from these bolts moving or possibly shearing with a really hard hit.
    When I posted earlier and said these needed to be supported in the L direction, this is exactly what I meant. The skid needs to take hard hits while moving forward and completely distributing the load to the tubes/pumpkin. This design concentrates it on those studs and that’s asking for them to fail.
    If he wants more advice, tell him to create a clamshell design that datums off of the tubes and pumpkin. This is possible without attaching something to the diff bolts.
    Just my .02 cents.
    boardude[OP], Sunnier, 831Tun and 2 others like this.
  9. May 2, 2018 at 1:15 PM
    #159
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You know how much i have been wanting this rear diff skid and i can say i am out with that design. Really wanting a design similar to those that currently manufacture for the Tacoma, 4Runner and FJ Cruiser.
  10. May 2, 2018 at 1:31 PM
    #160
    osidepunker
    Alex
    2013 Tundra DC 4x4
    More like a whole dollar! But I totally agree everything you said
    Those are proper diff skids right there. That's what I'm interested in if I decide I need a skid. I'm still not convinced it's needed
  11. May 2, 2018 at 1:35 PM
    #161
    csuviper
    Broomfield, CO
    What we are looking for:
    • 3/16" or 1/4" steel - BAMF, Boztec and RCI all use 1/4" steel.
    • Tight to the diff
    • Cutout for the drain plug
    • No hanging bolts/nuts
    • Pinion and axle clamps
    • U-Joint and pinion protection.
  12. May 2, 2018 at 2:07 PM
    #162
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The last photo looks good. One thing I've heard is that the skid rattles and becomes such a nuisance that it just gets removed. The RCI at the top looks great but after a while I can imagine that you won't be able to tighten it to keep it tight. The bottom photo looks like there are plenty of threads so you should always be able to snug it up.
    Nice pics Brian. I hope you're feeling better these days.
  13. May 2, 2018 at 2:54 PM
    #163
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Sorry for the delay - Been traveling for work.
    I just talked to Doug and expressed all these concerns. I made a point that we want to stear clear of mounting to the carrier assembly and would like to see something attached to the axle. He was open for a redesign and is going to look at it again to see if he can address the concerns. In the early talks of all this I did send him pics from rci and boztec but sounds like he was trying to come up with his own design. He has these examples so we'll see what he comes up with. I did stress that the goal was to hug the diff as tightly as possible.
    Once we have a good quality design that everyone (most) are happy with then we can move on to material, thickness, finish, etc.
    jc153, csuviper, GodlessPro and 6 others like this.
  14. May 2, 2018 at 3:00 PM
    #164
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nice work, thanks for all your effort Kris!
    joonbug, GodlessPro and Sunnier like this.
  15. May 2, 2018 at 3:09 PM
    #165
    I have the 26er tank so i guess that won't be an issue except the missing additional 10 gallons.....for now...
  16. May 3, 2018 at 8:56 AM
    #166
    the_midwesterner
    Luis
    None, yet....
    This is the clamshell design I was referring to. I hadn’t even seen these things before.
    Can we add rotational protection in the longitudinal direction to prevent from catching the pinion shovel and ripping the thing off.
    I could see this as a problem, but a through design in between the clamp engagement would resolve this. So would shaving a couple thousand off the interfacing faces of the clamps and technically making the clamp ID slightly smaller than the tube, to address the rattle issues.
    Also, I want to retract my commitment on this. Unless I see a prototype that satisfies the requests above, I’m out. Another thing that is concerning, if this guy is designing stuff like this, who will be producing them? Do we need to validate the integrity of the welds, structure, etc?
    My plasma table will be here in June. I’ll start playing with drawings to see what I can come up with on my own.
    Black Wolf and Sunnier like this.
  17. May 3, 2018 at 9:26 AM
    #167
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah I haven't seen anything for the tundra that I like. If I ever decide I really need one, I'll just have one custom made. There are lots of shops that will make a one off for a reasonable price.
    dcsleeper408 likes this.
  18. May 27, 2018 at 9:42 PM
    #168
    csuviper
    Broomfield, CO
    Any updates???
    Sunnier likes this.
  19. Jun 12, 2018 at 10:29 PM
    #169
    csuviper
    Broomfield, CO
  20. Jun 13, 2018 at 4:17 AM
    #170
    osidepunker
    Alex
    2013 Tundra DC 4x4
    vaporware...
  21. Jul 27, 2018 at 8:33 AM
    #171
    Overland_Mike
    Overland_Mike New Member
    2001 Tundra, Gen2 build plan in progress
    Cash in hand. Count me in.
  22. Aug 16, 2018 at 6:20 PM
    #172
    the_midwesterner
    Luis
    None, yet....
    @Datin Metal Fab 6 pages of interest on diff skids. You guys should make one.
  23. Feb 1, 2019 at 5:07 PM
    #173
    csuviper
    Broomfield, CO
  24. Sep 18, 2022 at 12:46 PM
    #174
    coTony
    Tony
    Montrose, CO
    I read that most everyone has complained about the figment of the Victory skids like many that have been developed for the Tundra. Has there ever been a good kid made for the rear Tundra diff?
  25. Sep 18, 2022 at 5:25 PM
    #175
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I ditched the skid and welded a bash plate to the diff, a 1/4" piece of steel bent to conform to the curve of the diff.
  26. Sep 18, 2022 at 7:07 PM
    #176
    TheBeast The Beach
    CBI, RCI ,C4 don't they all make one nowadays ?
  27. Nov 2, 2022 at 7:31 AM
    #177
    coTony
    Tony
    Montrose, CO
    I have seen one I like yet
Thread Status:
