Rear Differential leak?
Discussion in '2.5 Gen Tundras (2014-2021)' started by justfortun, Sep 18, 2019.
  1. Sep 18, 2019 at 3:59 PM
    justfortun
    justfortun [OP] New Member
    James
    Boston
    2016 SR5
    Hi all. I'm going in for my 55k checkup tomorrow and I was wondering if I should ask about this...seems like my rear differential has some leak marks. Normal? Nothing to worry about?
    sorry for the bad pic
  2. Sep 18, 2019 at 4:02 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    justfortun[OP] likes this.
  3. Nov 5, 2020 at 1:15 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Coming here with the same issue. The post linked above looks like it was deleted (pretty sure I remember reading that thread quite a bit and the OP was banned from the forum, so that may be why) so maybe we need to track some info in this one.
    @justfortun were you able to get your leak fixed? I just noticed some weeping from the seem the other day. I have 22k miles on my truck, so it's still under warranty, but I'm curious if anyone has had issues with dealerships making the repair.
    Here's the passenger side with signs of the leak:
    Drivers side looks fine:
  4. Nov 5, 2020 at 4:17 PM
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    I had noticed a "seep/weep" mark on mine at about 40k miles.
    I thought I was done with diff weeps when I traded my tacoma off. Had the gasket replaced once under warranty and then spots returned 15k miles later. Wouldn't touch it again unless it was considered a leak vs a weep due to revised guidance by Toyota.
  5. Nov 5, 2020 at 6:03 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Dang. Guess I'll just have to see what the dealership says about it at my next service. Doesn't look like anything catastrophic in my case, but I know it wasn't there 5k miles ago.
  6. Nov 6, 2020 at 8:06 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Oh no time to re-gear and throw in a LSD
    TRDFerguson likes this.
  7. Nov 6, 2020 at 11:29 AM
    timsp8
    NY
    Yeah, OP was banned and the thread was deleted. Seems most dealers will just retorque the bolts and say keep an eye on it. I remember reading 1 or 2 got a new gasket. Most people said it’s such a small seep, that you’ll never have any issues from it.
    TRDFerguson[QUOTED] likes this.
  8. Nov 23, 2020 at 1:50 PM
    justfortun
    James
    Boston
    2016 SR5
    Never had it looked at. I'll check it tomorrow to see if it's gotten worse.
  9. Nov 23, 2020 at 1:52 PM
    TheBeast The Beach
    seems to happen on the gen 3s. My gen 2 is bone dry.
  10. Nov 23, 2020 at 2:20 PM
    jsquared22
    jsquared22 _________________
    2018 White Tundra Platinum
    Here's mine on my 2018. If it was easy to check the differential oil level (without having to crawl under the truck), then I'd be less concerned about this whole "seep" issue. By the way, I'm at 20K on the odometer. Differential.jpg
  11. Nov 23, 2020 at 2:25 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yours kinda looks like it's coming (at least in part) from the breather. That doesn't look good...
    AZBoatHauler likes this.
  12. Nov 23, 2020 at 2:42 PM
    jsquared22
    Agreed. I will make a 2nd attempt at getting the dealer to repair it. It definitely has gotten worse since the dealer first declined to repair it.
  13. Dec 7, 2020 at 8:10 AM
    Critical05
    A few months back i fiddled with the breather, just rotating it and making sure it was free. It was a little crusty and didn't turn too freely. I looked under this weekend and it seems the weep has gone away as there is dry dust on top of the weep marks, no longer wet looking.
    rockmup likes this.
  14. Dec 7, 2020 at 8:32 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    I don't know that I've ever owned a drop out third that didn't weep, the pics shown are nothing to lose any sleep over.
    Absolutely check your breathers they are almost always the cause of this
    JLS in WA and Critical05 like this.
  15. Jul 5, 2023 at 2:08 PM
    chingyeunglo
    chingyeunglo New Member
    It looks like the breather no good.
  16. Jul 5, 2023 at 2:36 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I would agree with a slight weep and nothing to worry about. My 2020 has had some stains on it for the last 10,000 miles or so, has not gotten any worse. I do not see any webpage near the vent, I may wiggle it around just to see if it sounds crusty, like some others have said.
