Rear diff shavings found at fluid change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra18overland, Sep 18, 2021.
  1. Feb 19, 2023 at 10:31 AM
    #91
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    There seems to be a pretty huge range when it comes to deposits and miles. I'm shocked at some of the guys waiting 30 or 40k miles to change the diff fluid only because mine was black as the devils heart at 20k miles. Granted it was the first change and I offroad and drive heavy alot of the time. There was only one minor chunk but a decent amount of "fur". I plan on doing it again in 20k miles just to guage if it was only that black because it was the break in oil or if it's normal for my usage.
    Tundra18overland[OP] and Joe333x like this.
  2. Feb 19, 2023 at 11:19 AM
    #92
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I did my first at 10 and second at 40, the first one at 10 was definitely the worse of the two. I'd say getting that break in oil out as soon as you can is the way to go and then you can go 20-30k after that. I'll probably be sticking with 20k myself.
  3. Feb 19, 2023 at 11:38 AM
    #93
    Wallygator
    Yes be wise, put the appropriate fluid in according to the manufacturer.
    In the Tundra transfer case an example of the appropriate fluid is Royal Purple Sychromax.
    https://www.royalpurple.com/product/synchromax-manual-transmission-fluid/
    Look at the lubricant cross reference chart and find genuine Toyota LF fluid. Which happens to be what is in the Tundras transfer case.
  4. Feb 19, 2023 at 11:49 AM
    #94
    Joe333x
    Joe333x Member
    Boston
    If it works, it works, many have had luck with using 75w90, many have used Ravenol, I used the Toyota fluid myself. VOA of the Synchromax vs the Toyota fluid, its definitely not the same but like I said, if it works, go for it.
    Toyota brand differential fluid VOA
    Royal Purple Synchromax VOA
  5. Feb 19, 2023 at 12:36 PM
    #95
    MadMaxCanon
    Yeah I'm expecting the next one at 40k to be much cleaner.
  6. Feb 19, 2023 at 2:55 PM
    #96
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Synchromax's claim to fame is that it protects synchronizerss.
    This fluid also claims to meet Toyota's spec and is GL4.
    https://www.redlineoil.com/mt-lv-70w75w
    georgiey22 likes this.
  7. Feb 19, 2023 at 4:28 PM
    #97
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    Dealer won’t do anything unless your diff blows up. Keep driving - this looks relatively normal for a first change IMO. Slightly more than mine had.
  8. Feb 19, 2023 at 7:22 PM
    #98
    mgrs
    mgrs New Member
    '20 OR
    My '20 looked rather like that on the first rear diff oil change (27700 miles). Probably the worst looking "break in" oil change I have ever seen.
    Not really concerned unless it keeps doing it.
    Wallygator likes this.
