Rear diff shavings found at fluid change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra18overland, Sep 18, 2021.
  1. Sep 22, 2021 at 11:28 AM
    #61
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Not sure what you’re trying to convey?
    Ravenol Gear Oil MTF-1 75W-85 GL-4 GL-5?
  2. Sep 22, 2021 at 11:29 AM
    #62
    Spyker
    Im just curious if anyone has ran this fluid and found any issues? It’s quite a bit cheaper than running the dealership Toyota oil.
  3. Sep 22, 2021 at 2:34 PM
    #63
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    The “Ravenol Gear Oil MTF-1 75W-85 GL-4 GL-5” is for the front and rear diff.
    the Ravenol MTF-3 75w is for the transfer case.
    Good reviews on the website, not sure of any other literature supporting it for the Tundra but it appears to be high quality oil used in other German race applications and it’s also the exact weight the manual calls for (75w85, where as alot of people ignore that and use 75w90)
    crewmaxlmt and Uhhhh.... like this.
  4. Sep 22, 2021 at 4:30 PM
    #64
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    I would go OEM in the transfer case as there is a significant difference in the additives.
  5. Sep 22, 2021 at 8:38 PM
    #65
    Spyker
    I think that’s what I’m going to end up doing.
  6. Sep 22, 2021 at 8:47 PM
    #66
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Mine at 9300 miles
  7. Sep 23, 2021 at 4:24 AM
    #67
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Tundra18overland[OP] likes this.
  8. Sep 24, 2021 at 6:23 PM
    #68
    Spyker
    Did anyone use thread sealant on their TC plugs? Like permatex high temp thread sealant?
  9. Sep 24, 2021 at 6:41 PM
    #69
    Tundra18overland
    Jesse
    GA
    I did not but it appears like Toyota did originally. As long as there’s no leaking which there isn’t I don’t see the need for it
    Spyker[QUOTED] likes this.
  10. Sep 24, 2021 at 6:45 PM
    #70
    Lost in the East
    Lost in the East New Member
    Derek
    Voodoo Blue TRD Pro (Should’ve kept it) Mudbath TRD Pro
    Where you located? I may bring my truck to get the front done.
  11. Sep 24, 2021 at 6:46 PM
    #71
    Joe333x
    Joe333x Member
    Boston
    A drain and fill on the rear dif is easier than doing an engine oil change as long as you can physically crawl under your truck
  12. Sep 24, 2021 at 6:50 PM
    #72
    Lost in the East
    Derek
    My rear is done. I try to knock out everything I can myself. It adds pride and joy when looking back the truck. I currently don’t have the gear to knock it out.
  13. Oct 5, 2021 at 4:49 PM
    #73
    pursuit2550
    pursuit2550 New Member
    Well I just did a oil change and diff oil change after a 2700 mile road trip. Here is the rear diff plug at 16,500 miles. Had one long piece of shaving the rest was gunk shavings. Also switched over to 5w-30, engine is so much quieter now. 0w-20 sounded like a Diesel engine.
    TRDblvd likes this.
  14. Oct 5, 2021 at 5:32 PM
    #74
    Spyker
    That’s one hell of a piece of metal shaving. I’m planning on doing the rear diff at 10k, purely for piece of mind and curiosity.
    What fluid did you decide to run in the diff?
  15. Oct 6, 2021 at 4:58 AM
    #75
    pursuit2550
    TRDblvd and Spyker[QUOTED] like this.
  16. Oct 23, 2021 at 2:07 PM
    #76
    Spyker
    Magnet on the diff drain plug didn’t look bad at all, thoughts, 10k miles;
    Retroboy1989 likes this.
  17. Oct 23, 2021 at 2:39 PM
    #77
    Tundra18overland
    Jesse
    GA
    Normal. Good to go.
    Spyker[QUOTED] and Retroboy1989 like this.
  18. May 28, 2022 at 7:46 AM
    #78
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Does anyone have extensive research on amsoil severe gear vs. royal purple? I used royal purple 3 times over the 200k miles in my last tundra and had 0 issues. I have seen many of the amsoil YouTube comparisons versus royal purple and claims of it being superior. I’m now intrigued by the squeezable bags. You guys are using 75-85 now and not 90?
  19. May 28, 2022 at 8:08 AM
    #79
    AJTundy
    AJTundy New Member
    2020 Tundra Crewmax SR5
    Leer 100XR truck cap, 5100's on the middle setting. Ikon Add A leaf, Cooper Discover ATX3 275/70/18, Genuine Cooling Systems transmission cooler, chrome delete.
    I had my front and rear differentials and transfer case fluid changed by the dealer at 30k miles. They said the rear diff had a lot of shavings in it, but I shouldn't worry for "how much I tow." I've towed a 4,000lb trailer about 10 times. I was concerned about it for a while but I am chalking it up to the break-in process. Knowing what I know now I would have changed the factory fluids out around 10k miles, but I am not that concerned about it overall. I am going to change the rear diff myself at 40k miles so I can see what the magnet looks like with 10k more on it. If it looks bad I will probably talk to the dealer about it before my warranty runs out at 60k. I don't expect them to do anything about it, my dealer's service department is awful. 100% of the time I have taken my truck in they screw something up or I notice pieces missing or overtightened. I take my truck to an independent shop now if it needs something I don't want to deal with myself.
    Joro43 likes this.
  20. May 28, 2022 at 8:13 AM
    #80
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    I think as long as you’re changing it with a high quality synthetic you’re doing more than enough. My main reason for using Amsoil is the bags make it so dang easy. I used 75w90.
    I’ll be changing my rear again at 10,000 miles. Plan to do the front and transfer case as well. Front will get the same 75w90 and the transfer case will get Toyota’s magic oil. By the time I hit 10,000 miles I’ll have around 3,000 miles of towing on it.
    Wallygator and Joro43[QUOTED] like this.
  21. May 28, 2022 at 8:16 AM
    #81
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    These guys are the pros, I’d read the article
    https://eastcoastgearsupply.com/ft-2536-ecgs-gear-oil-recommendation.html
  22. May 30, 2022 at 3:30 AM
    #82
    Retired...finally
    Joro43 and Tundra18overland[OP] like this.
  23. Feb 15, 2023 at 9:44 AM
    #83
    Tundra18overland
    Jesse
    GA
    Little revival on this thread…
    Just changed rear diff oil again 15k mi later and pleased to see no shavings, just some minor gear sludge. See attached pic.
    Also PSA for anyone running Ravenol…
    BlauParts (Ravenol’s primary and possibly only US distributor)
    They're now selling Ravenol’s “updated with added performance” gear oil which is no longer red in color (gold now) and is now advertised as “heavy duty.”
    (DGL 75w-85 GL-5 LS)
    I was advised by Blau that the MTF-3 75w gear oil for the transfer case has remained the same (gold in color)
    I found all this out yesterday when I called Blau because it appeared that the MTF-1 75w85 red gear oil I was about to put in my rear diff does not contain the LSD additive (update: not needed for Auto LSD (open differentials))
    She advised me that they are trying to fade out the MTF-1 and are now only selling the new “DGL 75w-85 LS” that is gold in color, however, the MTF-1 does still meet all of Toyota’s specs and is still appropriate for my truck. When I bought my gear oils from Blau all they had was the MTF-1. She sent me 2 free bottles of the new DGL, that I will be putting in my front diff when the time comes (which currently has the MTF-1 in it). If you’re OCD like me, I’d rather have the new “heavy duty” DGL gear oil. I put Mobil 1 75w-90 w/ LS additive in my rear diff until I can get some DGL
    (update: won't use oil with LSD additive next go around, not needed)
    Really just wanting to give everyone a head's up that if they choose to use Ravenol, you should opt for the DGL oil because it's updated and now "heavy duty."
    Also, see attached pic of Blau responding to a review of someone complaining of the same thing.
    Also the oil has increased from about $15 per qt to $24…
    Henry1jg, Wallygator and ColoradoTJ like this.
  24. Feb 15, 2023 at 10:03 AM
    #84
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    That certainly is very interesting to hear about the gear oils since I also have all Ravenol in my diffs and transfer case. Those prices certainly have gone up though! Depending on the prices when I need to do oil changes next Ravenol may or not be the oil I use if I can just get Amsoil or OEM fluid for a similar price.
    However, that tech was right. Unless you added an aftermarket LSD (ex: Auburn) absolutely every Tundra from 2007-2021 has an open diff with an "electronic LSD" which just uses the brakes to simulate a LSD. You do not need a LSD additive.
  25. Feb 15, 2023 at 10:29 AM
    #85
    AZBoatHauler
    So.Arizona
    ^ this. No 2018s came with a real LSD.
  26. Feb 15, 2023 at 11:15 AM
    #86
    Tundra18overland
    Jesse
    GA
    Well, I stand corrected then. Thanks. Updated the post. Guess I could have used the MTF-1 then after all.
    Hugemoose[QUOTED] likes this.
  27. Feb 16, 2023 at 10:17 PM
    #87
    Joe333x
    Joe333x Member
    Boston
    Im sure its absolutely fine but there's really no need to use 75w85 over 75w90, the 75w85 is just an OEM fluid spec to try and increase MPG for CAFE standards. 75w90 which is readily available at Walmart for half the price will be good if not better.
  28. Feb 18, 2023 at 7:05 PM
    #88
    Joe333x
    Joe333x Member
    Boston
    Just changed mine out again at 40,000, this is the fluid and bolt after 30,000. Definitely better than the initial change at 10,000.
  29. Feb 18, 2023 at 7:50 PM
    #89
    Wallygator
    Royal purple sychromax is compatible with the ridiculous OEM transfer case liquid gold oil. They list the fluid on their spec sheet. It's good stuff
  30. Feb 19, 2023 at 10:19 AM
    #90
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    People need to be wise about what goes in the transfer case. It has brass synchronizers and needs GL-4 fluid or GL-5 that is compatible or the brass can experience higher wear rates...
    PO owner said they changed the fluid at 60k, I dumped it at 105k and found this lovely peice left from the machining process.
    TG for magnets! lol
    FWIW even stuff made in Japan comes with quality break in material. This from a used IS-350 I bought from LKQ while I install an OS-Giken Super Lock LSD.
    Best guess is this came from the ring gear or the flange of the open diff carrier and stayed along for ride to be dumped out at 90k mi as the idiots at LQK shipped it full of fluid w no plugs in it.
    Wallygator[QUOTED] likes this.
