Rear diff shavings found at fluid change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra18overland, Sep 18, 2021.
  1. Sep 18, 2021 at 7:08 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I’m talking about cutting the gears themselves. Gear hobbing is such a cool procedure and the guys that do it are in a small niche of the machining world. It’s so simple but so involved at the same time. Fun stuff.
  2. Sep 18, 2021 at 7:12 PM
    Oh no, never seen that process. It would be cool.
    crewmaxlmt[QUOTED] likes this.
  3. Sep 18, 2021 at 11:00 PM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Just changed my differential oil a couple days ago in my 2016 that I purchased new and now at 95,000 miles. This was the first time oil changed after pulling an 8,000 lb. travel trailer around the country for a few years. I was very impressed with the Tundra that had a little sludge and one small piece of shaving from the edge of a gear on the magnet about 1/4 inch and expected to find a lot more due to miles and load but not so. Had I known someone would be asking about this could certainly have taken photo but now to late, it's churning around in Lucas.
    Ely010606 and CallsignKodiak like this.
  4. Sep 19, 2021 at 5:03 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I think I see a couple ballpoint pen springs in there.
  5. Sep 19, 2021 at 6:05 AM
    That would be a pretty close. That is from a LS clutch pack that came apart due to abuse on a diesel truck (11.5 AAM rear axle)
    Uhhhh....[QUOTED] likes this.
  6. Sep 19, 2021 at 8:08 AM
    blanchard7684
    blanchard7684 New Member
    I've serviced over 200 differentials in my adult life. Of all makes, models, brands, mileage, abuse, and neglect. They all have some material on the plug.
    I've done first oil change on probably 80+ differentials of various makes and models and they all look really ugly the first time.
  7. Sep 19, 2021 at 9:02 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    I saw it but it might have just been stuck in the sludge. Its either a piece of shim stock, which is no big deal, or it's chrome that has flaked off a bearing, race or cup. Not much to do about that either.
    I'd still run it and not worry
  8. Sep 19, 2021 at 9:20 AM
    classiccat
    classiccat New Member
    2017 Tundra Limited SuperWhite
    I just did the front & rear diff @ 30k on my 2017 DC. I do quite a bit of towing & engage 4x4 a few times a month to exercise the system.
    front was dirtier than the rear which was a little surprising.
    Front diff:
    Rear diff:
  9. Sep 19, 2021 at 9:30 AM
    CallsignKodiak
    CallsignKodiak New Member
    Bear
    Iowegia
    2021 CrewMax SR5 4x4 Barcelona Red
    Bone stock
    Ok, so what brand & weight of diff oil are you guys using to either "break in" new or "run & maintain" non-new trucks in order to get the longest possible life out of your differentials? Recommendations solicited & listened to...
    Stock Toyota diff oil from the factory is an acceptable answer – no judgement whatsoever from me.
  10. Sep 19, 2021 at 9:35 AM
    classiccat
    found the OEM stuff for $26/L.
  11. Sep 19, 2021 at 9:39 AM
    rockmup
    rockmup New Member
    Todd
    I have run non synthetic 90wt in everything I have ever owned. I've lived in N.Calif. and S.Louisiana, I've never had a single issue
  12. Sep 19, 2021 at 9:39 AM
    AZBoatHauler
    So.Arizona
    I used Royal Purple my first change at 30k. After additional reading/research, used Amsoil severe gear the second change at 55k. 75-90 both times.
    The front on the second change still looked new. I’ll probably go 50k on the amsoil assuming no water fording.
    The rear on the second change wasn’t black (like it was at 30k) but wasn’t clean either. I’ll keep it on 30k intervals which is about every 2.5 years for me.
    Everything I’ve seen / read / watched indicates amsoil severe gear is the best or one of the best fluids available and the price is right. It is either true or they have an amazing marketing team.
    Oey12 and CallsignKodiak[QUOTED] like this.
  13. Sep 19, 2021 at 10:35 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    The can of worms is now open ;)
  14. Sep 19, 2021 at 7:42 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Looks like they're not just for ketchup and personal lubricant anymore.
  15. Sep 20, 2021 at 6:14 PM
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Not trying to derail this thread, but I'm just about to swipe the card for some fresh fresh Amsoil Severe Gear, and I'm wondering how much to buy? The pull down menu on the Amsoil website indicates that 6qts exactly will do both diffs, is that true? its a 2018 4x4
  16. Sep 20, 2021 at 6:41 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    It is but imo I would get 7
    Ely010606 likes this.
  17. Sep 20, 2021 at 6:52 PM
    sea_weathered
    Pacific Ocean
    I really probably should. just being a cheapskate
  18. Sep 20, 2021 at 7:07 PM
    crewmaxlmt
    scott
    This
  19. Sep 20, 2021 at 8:03 PM
    #49
    AZBoatHauler
    So.Arizona
    I was able to get both done with 6. I used 3 bottles with a pump for the front and 3 bags with the left over from the bottle for the rear.
    I bought 7 the first time and still have the unopened left over quart on the shelf in my garage.
  20. Sep 20, 2021 at 8:18 PM
    #50
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I just did my front and rear diff a couple ago. I used the Amsoil, I got the squeezable bag made it much easier.
  21. Sep 21, 2021 at 3:10 PM
    #51
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    This thread pushed me over the edge to do mine before I make a 1000 mile trip towing a trailer. Only have 2470 miles on it. Decent amount of junk on the magnet. The oil had quite a bit of glitter. The Amsoil bags made it a quick and easy job to change. I already had the crush washers because my T100 uses the same ones.
    Was it needed? No idea. I won’t say someone should do the change this soon but for me it wash incredibly easy and cheap for the peace of mind. I’m going to change the front after winter since I use 4x4 high quite a bit.
  22. Sep 21, 2021 at 3:25 PM
    #52
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I just had my 25k service yesterday and I asked the dealership replace the diff fluid. They looked at me funny and said I'd have to pay for it, but I was OK with that. I didn't see the drain plug when they pulled it, but it was enough for them to write it up and document it. They told me they if pretty much anything happened to my rear diff, I was covered, even if the warranty was expired. They got the overall service manager involved and he was surprised.
    They did ask if I had noticed any functional issues or unusual sounds, but I have not.
    I don't know what mine looked like compared to yours, but it was enough for them to document it.
  23. Sep 21, 2021 at 4:08 PM
    #53
    Uhhhh....
    Dave
    7” BDS, 37s
    Wow. I would have expected them to not say much to you and wait for failure before saying it’s covered even if warranty expires. Glad to see integrity.
  24. Sep 21, 2021 at 6:40 PM
    #54
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Thanks everyone, your replies made me feel better lol. I’m doing the front diff and T Case tomorrow, we’ll see how they look. I’m running Ravenol 75w85 for the diffs and 75W for the t case. The manual calls for 75w85 but I know alot of people run 75w90 with no issues. This stuffs a little pricey but I’ve heard good things about it and I like that’s it’s the exact weight the manual calls for. Apparently Toyota used to recommend 75w90 but they changed to 75w85 a few years ago.
    https://www.blauparts.com/ravenol-manual-transmission-fluid-mtf-1-75w-85-gl-4-gl-5-1l.html
    CallsignKodiak likes this.
  25. Sep 22, 2021 at 10:27 AM
    #55
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    are you running the above linked fluid in both your diffs and transfer case?
    edit: I see they offer a kit that has 2 bottles of the 75w
  26. Sep 22, 2021 at 10:43 AM
    #56
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    hagrid and ColoradoTJ[QUOTED] like this.
  27. Sep 22, 2021 at 10:54 AM
    #57
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I personally like Mobil-1 Synthetic 75W-90. I've tried Lucas Oil in the past, but it had an odor.
    Also, am I wrong in using the same oil in the transfer case??? I just get a 12-pack case of Mobil-1 and knock it all out at once (ft, rr and tc) and have enough left over to re-do the front when a CV axle breaks.
  28. Sep 22, 2021 at 10:57 AM
    #58
    Spyker
    Tundra18overland[OP] likes this.
  29. Sep 22, 2021 at 11:23 AM
    #59
    Tundra18overland
    Jesse
    GA
  30. Sep 22, 2021 at 11:25 AM
    #60
    Tundra18overland
    Jesse
    GA
    From my 2018 manual
    Terndrerrr and CallsignKodiak like this.
