Rear Diff has metal fragments in it.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by YotaBro, Sep 18, 2020.
  1. Sep 18, 2020 at 7:13 PM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    Lots of shenanigans.
    I purchased a 2017 Tundra TRD PRO double cab a week ago. She has 38k miles and had one previous owner. I wasn't 100% sure if the rear/front diff and transfer case oil have been swapped out so I did it myself. When removing the drain bolt for the rear diff I noticed that the magnet had 2-3 decent size pieces of metal. The oil seemed like it wasn't terribly old. It had the typical sludge as well. How serious is this? What do I need to do to fix this? If I need to fix it, I plan on upgrading the part so feel free to send in suggestions. I sent the picture (below) to the salesman so that he can show the techs. I haven't had any issues with the truck besides that she slightly pulls to the right. I already planned on doing an alignment soon, but don't think that it has anything to do with the metal. Like I said earlier, I just got this truck. I haven't even taken it to the gas station to fill her up.
  2. Sep 18, 2020 at 7:23 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Thoes are not small chunks. Looks like part of the ring gear, not sure about the other fragment. If either have a super shiny luster to them or small vertical lines on them.
    You didn’t mention where you got said truck ? Any warranty, As is? Have it fixed before it get more expensive.
    Good luck
  3. Sep 18, 2020 at 7:24 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    You’re still under warranty so I would take it in and have them inspect it
  4. Sep 18, 2020 at 7:26 PM
    YotaBro
    Calvin
    FL
    What would happen if I did nothing?
    I bought it from a Toyota Dealership. It only has the standard Toyota dealership warranty rn.
  5. Sep 18, 2020 at 7:26 PM
    YotaBro
    Calvin
    FL
    Do you know how many miles the warranty expires? Isn't it like 50k or so?
  6. Sep 18, 2020 at 7:30 PM
    biebs96
    PA
    I’m pretty sure that’s considered drivetrain 5yr/60k.
    I’d bring it in for sure.
  7. Sep 18, 2020 at 7:31 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    You are just outside toyota standard 3 year 36000 mile warranty. I would definitely still take it back to the dealership you got it from have them look into it
    Inquiringone likes this.
  8. Sep 18, 2020 at 7:32 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    ^^^X2
  9. Sep 18, 2020 at 7:38 PM
    YotaBro
    Calvin
    FL
    Ok, well hopefully they'll give me a discount or something to fix this issue...
  10. Sep 18, 2020 at 7:38 PM
    Inquiringone
    Ter
    NorCal 408
    left alone, it can do some real damage to the rest of the ring and pinion gears if any of fragments were to get caught between them under load. Cause damage to the carrier unit and or bearings.
    I had to replace the entire rear end on a Ford F-150 because of stuff like you pulled out of your read end.
    Mine grenaded , had a 67 Chevelle with a positive unit in it and it froze up and tore out the drive shaft.
    not to hijack your thread. Have it fixed ASAP
  11. Sep 18, 2020 at 7:41 PM
    YotaBro
    Calvin
    FL
    Ok, good to know. I already contacted the salesman once I saw it but it was after hours. I plan on making an appointment first thing in the morning.
  12. Sep 18, 2020 at 7:41 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That's definitely something broken off, and not some metal debris that sometimes gets in there during the diff casting process. Definitely bring it back.
  13. Sep 18, 2020 at 7:56 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Powertrain warranty is 60 months/60,000 miles from "in-service" date. Your differential should be covered.
    GODZILLA and YotaBro[OP] like this.
  14. Sep 18, 2020 at 7:58 PM
    YotaBro
    Calvin
    FL
    Lets hope you're right! :)
    Tundra2 likes this.
  15. Sep 18, 2020 at 8:09 PM
    JohnLakeman
    Your dealer will be on your side. He just sold you a truck a week ago with what appears to be a damaged gear set. IMO, he'll be anxious to get this resolved quickly.
  16. Sep 18, 2020 at 8:12 PM
    YotaBro
    Calvin
    FL
    Yeah, the salesman was pretty good. The only thing that I am worried is his snake sales manager. I'll prob be a dick and threaten to leave a really negative review if they don't honor the warranty.
  17. Sep 18, 2020 at 8:18 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Great time to re-gear and go 35" tires. LOL
    They should be willing to fix that for ya under warranty.
    JDL17CM4x4 and YotaBro[OP] like this.
  18. Sep 18, 2020 at 8:20 PM
    YotaBro
    Calvin
    FL
    Hahaha, I'm sure I can haggle in some BF Goodrich 35" lol
    831Tun[QUOTED] likes this.
  19. Sep 19, 2020 at 5:05 AM
    JohnLakeman
    The sales manager won't be involved; his guy has done his part. The service manager will authorize the repair after technicians determine no abuse was involved.
    Personally, I would focus on getting the truck repaired to specification. Lobbying for anything beyond that (non-Toyota gearset?) might raise suspicion that an ulterior motive "helped it along".
    Ely010606, Tundra2 and Black Wolf like this.
  20. Sep 19, 2020 at 6:32 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    You will never sleep well again! Lol, good luck on getting it fixed, The clowns at the dealership will probably tell you , "you'll be fine"..
    Whoever owned the truck before thought they were Starsky@Hutch..
  21. Sep 19, 2020 at 4:28 PM
    YotaBro
    Calvin
    FL
    Thanks! I called the dealership this morning and the truck will be towed out there Monday morning.
  22. Sep 19, 2020 at 5:05 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Man that's terrible. Other side of the coin, I let me LSD diff change slip on my 2006. Seems like I went over 100,000 miles before changing it. The oil was putrid but I had nothing more than the usual smear of metal paste on the magnet.
  23. Sep 19, 2020 at 5:22 PM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Geez, I might be in the same situation as you, but so far no shavings or chunks on the magnet, only a concerning whine. Dealer wants to take it apart on wednesday... hopefully it wont cost me anything but time.
  24. Sep 19, 2020 at 8:06 PM
    YotaBro
    Calvin
    FL
    Are you still under warranty? I didn't purchase any extended warranties so I'm banking on the powertrain warranty rn.
  25. Sep 20, 2020 at 7:47 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    no warranty on the diff, just engine and transmission. previous owner didn't purchase the extended one
  26. Sep 20, 2020 at 10:03 AM
    JohnLakeman
    Differential should be covered by standard powertrain warranty within 60 months/60K miles.
    From the 2017 Owner Warranty and Maintenance Guide, Powertrain Warranty includes engine, transmission and transaxle, front-wheel-drive system, and rear-wheel-drive system. Rear-wheel-drive system includes "Axle housing and all internal parts, propeller shafts, U-joints, axle shafts, drive shafts, bearings, supports, seals, and gaskets."
  27. Sep 20, 2020 at 10:23 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    You can have mine. 4000 miles on them. I went to a LSD and 5:29
  28. Sep 20, 2020 at 11:48 AM
    shawn474
    MoCo, Maryland
    The rear diff is definitely covered on the 60k power train warranty
  29. Sep 20, 2020 at 2:13 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    I ended up scrapping mine, nobody would take them
  30. Sep 20, 2020 at 2:35 PM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Stupid Toyota Mexico's warranty is BS... its 60,000 KM or 3 years... but corrosion is covered for 60 mo...yay. No specifics on power/drivetrain
    I'd take it in a heartbeat, but it wouldn't make it past customs without an invoice.
    Anyway, poo has yet to hit the fan so I'm holding my breath until the dealer gets a chance to make this right.
