Rear diff cover rusted
Discussion in '1st Gen Tundras (2000-2006)' started by jake22si, Jan 4, 2021.
  1. Jan 4, 2021 at 10:21 AM
    jake22si
    jake22si [OP] New Member
    kevin
    2000 tundra 4.7
    Guy I bought the truck off told me over the holidays that he had the rear diff repaired a few years ago and the guy told him it would never leak again, so I had to take a look
    Darkness and Winning8 like this.
  2. Jan 4, 2021 at 10:25 AM
    jake22si
    kevin
    2000 tundra 4.7
    I immediately started scouring the classifieds and scored this for $100
    bmf4069, the red, Darkness and 5 others like this.
  3. Jan 4, 2021 at 10:50 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Wow that original diff looks like a marshmallow that was kept over the fire too long... you did well finding the replacement, Jake.
  4. Jan 4, 2021 at 10:55 AM
    Kongap
    Kongap New Member
    2004 SR5 DC
    :(Hahaha looks like my rear diff cover
  5. Jan 4, 2021 at 11:55 AM
    HanD
    HanD New Member
    Maryland
    05 DC
    nice score. mine started leaking within a month of buying it and i bought the replacement cover on barnes and had a new one welded on.
  6. Jan 4, 2021 at 1:19 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Ahunnert bucks?! Score! :yes:
  7. Jan 4, 2021 at 1:55 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
  8. Jul 27, 2021 at 2:45 PM
    jake22si
    kevin
    2000 tundra 4.7
    Old one out new one in
    bmf4069, the red, Glock 40 and 4 others like this.
  9. Jul 27, 2021 at 2:48 PM
    HanD
    HanD New Member
    Maryland
    05 DC
    Looks great
  10. Jul 27, 2021 at 4:16 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Great buy! I hardly think I'd find one that nice in my area for $100 or even several hundred for that matter.
    The original one looks like toast. It's good you replaced it.
  11. Jul 27, 2021 at 4:18 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Was the guy parking it in salt water overnight or something?
    bmf4069 likes this.
  12. Jul 27, 2021 at 4:40 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Reason number 246 why my wife doesn't let me decorate the house. I would use a diff housing as a manly toilet paper holder. Thats brilliant!
    bmf4069 and Bo Dangles like this.
  13. Jul 27, 2021 at 5:08 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Noice work bruh
  14. Jul 27, 2021 at 5:08 PM
    Coal Dragger
    Kung Fu Dick
    You could use the old diff and rear axle as a sweet base for a bridged coffee table…. Maybe put clear lacquer over all the rust to preserve the look (and prevent rust flakes from getting all over everything).
    bmf4069, Darkness and N84434 like this.
  15. Jul 28, 2021 at 3:29 PM
    jake22si
    kevin
    2000 tundra 4.7
    I had to reuse my rusty looking differential but the housing and axles came with the deal, even the brakes were new. Guy said he bought it and replaced seals and brakes only to find out his truck had abs
    Darkness likes this.
  16. Jul 29, 2021 at 5:19 AM
    Richid
    Richid New Member
    There's a guy in our area that sells them for $400 refurbed from the south. Dealer quoted me just about $1500 in parts and labor (installing bearings and seals) for new.
    I found an entire axle up in Maine on a truck that came from Az. but if the $400 one was available, I would have bought that.
  17. Jul 29, 2021 at 5:49 AM
    jake22si
    kevin
    2000 tundra 4.7
    Yes but I believe the $400 ones are also housing only no axles or diff
  18. Jul 29, 2021 at 5:57 AM
    Richid
    Richid New Member
    Right - but that's all you really need. I couldn't even give away the old diff (I reused the axles) or the axles and scrapped them. So this does only fix the housing issue, but I haven't seen many users actually break the diff or axle.
    I think the only challenge would be finding a replacement limited slip if someone drove it low on fluid for a long time. I simply used gas tank sealant to hold until the axle housing was prepped for replacement.
    Pucks18 likes this.
  19. Jul 29, 2021 at 11:49 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    WHATTTT???? I am in desperate need for a rear end. mine is crying everytime i go over 50mph
  20. Jul 29, 2021 at 1:49 PM
    jake22si
    kevin
    2000 tundra 4.7
    I think I saw someone cut the end off the housing and make a bearing pulling tool out of it
