Rear diff cover and fluid advice wanted
Discussion in '1st Gen Tundras (2000-2006)' started by Dunk, Nov 26, 2021.
  1. Nov 26, 2021 at 3:11 PM
    Dunk
    Dunk [OP] New Member
    Michigan
    2001 White TRD SR5 V8
    Hi everyone,
    My rear diff cover is leaking and I have to replace it. Just wondering if there’s anything I should know going into this. Gonna take a grinder to it then weld the new cover on, I don’t see any other better way to do it. I’m planning on replacing it with this:https://www.barnes4wd.com/Toyota-T1...ndra-Heavy-Duty-Differential-Cover_p_359.html
    I read a post where somebody recommended against using synthetic fluid, does anyone know about this?
    Thanks
  2. Nov 26, 2021 at 9:50 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
  3. Nov 27, 2021 at 12:04 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If you have a factory LSD synthetic fluid will cause chatter even with friction modifier. If you have a open diff you can run whatever you desire.
    For the LSD diffs Lucas severe duty seems to be the best for our LSD clutches
    Dunk[QUOTED][OP] likes this.
  4. Nov 27, 2021 at 12:06 AM
    empty_lord
    05 rollover special
    As much as I hate dorman I would recommend their diff cover over the Barnes unit too. The Barnes is ok, but the dorman is factory shaped. The shape of the cover helps with the oiling of the ring gear and pinion. Diff temps likely will be higher which leads to more wear with the Barnes cover. The punch out on the factory and dorman ones guide the fluid to sling over the ring gear and in effect the pinion
    Dunk[OP] and Luckydog like this.
  5. Nov 27, 2021 at 4:32 AM
    Richid
    Richid New Member
    Replaced the entire rear axle (swapped out the shafts as the the brakes were junk) about 8 years ago. Only extra parts needed were new u-bolts, some brake fluid, and POR-15 with paint.
    There's lots of parts already out there so it may be easier that welding on a new cover.
    dinosaur and Luckydog like this.
  6. Nov 28, 2021 at 10:04 AM
    Dunk
    Michigan
    Thanks for the input. Is this the cover you’re talking about?
    https://www.amazon.com/Dorman-926-9...t=&hvlocphy=9017652&hvtargid=pla-665740402057
  7. Nov 28, 2021 at 10:06 AM
    empty_lord
    05 rollover special
  8. Jan 31, 2023 at 8:23 AM
    SteveT
    SteveT New Member
    LugNutz
    None yet. Just good ole maintenance
    Reactivating old thread ... while I consider going the replacement cover route my dilemma is this: Dorman seems to only have one cover product for the first gen Tundra, part No.926-958 and they list my vehicle as incomaptible (2002 SR5 Access Cab 4WD with LSD). and then there is the Barnes product B4W0008K, which Barnes says is correct. Dorman responded to my email and says their cover is not the correct fit and then others on this forum say the Barnes is a bad design for lubrication flow purposes. My gut says go Dorman and ignore their claim as inaccurate.
    Has anyone used the Dorman on my vehicle (above) without issue? I can't imagine that its not a correct fit, but I just dont know enough about these rears to be sure.
