Rear dash cam installation
Discussion in 'Audio & Video' started by Netmonkey, Mar 9, 2019.
  1. Jan 20, 2020 at 9:40 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Yea that’s the main reason I got it but if you don’t have a hotspot it won’t send you alerts so I bought a dedicated hotspot it does make it much easier cause it’s an SOB to connect up to my phone for whatever reason and then when I am connected if I close the app it disconnects and I have to go thru the same BS again to connect it so now with my Hotspot it’s always connected and even tells me about speed cameras. I just bought the system late December BD gift to myself and installed it in early January so I haven’t played with it much just research it on YouTube
  2. Feb 29, 2020 at 1:10 PM
    Finch
    Finch New Member
    Donnie
    '16 Inferno CM 5.7L TRD Off-Road
    Sent you a PM. Curious with which mount you ended up going with for your rear cam. Thanks.
  3. Feb 25, 2021 at 9:25 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Jump a year later. That is such an easy hack, just bought a Viofo 4K Pro Duo and did it. The rear cam butts up against the binder hinge like it belongs there too.
    Cheers!
  4. Feb 25, 2021 at 9:46 AM
    TundraBlack
    TundraBlack New Member
    Nice tip. I got the garmin 46 in front and will buy the garmin mini for the rear, with same specs as the front minus the screen.
  5. Mar 10, 2021 at 10:28 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
