Rear dash cam installation
Discussion in 'Audio & Video' started by Netmonkey, Mar 9, 2019.
  1. Mar 9, 2019 at 12:21 PM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    I installed an old dash cam a couple of years ago:
    https://www.tundras.com/threads/dash-cam-genius-dvr-fhd590-installation-and-review.12759/
    but it was very old and had dated features. Recently, I upgraded the front camera to the Garmin 55 (which I highly recommend) and I have been wanting to add that same camera to the rear. I have been thinking about this installation for a while now, but I just wasn't sure about how to install it (since the window on the crewmax rolls down). A couple of options that I thought about were attaching a bracket to the rear seat head rests or maybe drilling a bracket into the interior trim around the rear seat belt. The Garmin 55 doesn't use a traditional suction cup. Instead, it has a magnetic disc that adheres to the glass. It is also not compatible with all the camera mounting armatures (like the GroPro uses) so I would have to fabricate some sort of mount.
    Anyway, here is what I came up with:
    To start, I ran a wire from the add-a-fuse (that I used for the front camera) down behind the driver's side kick panel and down along the front and rear door sills along the driver's side of the truck to the back wall. I tucked the wire behind the panel on the rear wall and up to the rear window. I mated that wire up to a 12-volt accessory plug and plugged the dash cam into that. I tucked the dash cam wire up along the interior trim (near the rear seat belt) and along the head liner to the center of the truck.
    I rolled the rear window down and then measured and added a piece of blue painters tape along the center line of the truck (the left edge of the tape is the center of the truck). This would give me a guide so I could center the dash cam. I didn't want to mess with removing or damaging the head liner, so I used some plastic prying tools to feel around underneath the headliner near the brake light.
    I figured that I would create a mount using metal sheets. I felt around for anything that I could stick a metal sheet on to or perhaps a crevice that the sheet could be wedged into.
    I bought a 12x24, 26 gauge metal sheet. I figured that was enough material for some trial and error :)
    The camera mount is 1 inch wide, so I started by cutting a 1 inch x 3 inch piece.
    I played around with that piece under the head liner for a while; trying different positions and thinking about different angles that could be wedged up there. Nothing made sense until I removed the pry tool. Once the pry tool was removed, the metal piece was wedged in there tight. Since the camera has a magnetic mount, I was able to attach it to the metal piece and play around with positioning. I determined that the metal needed to be bent down a little so that the rear window would clear when closed.
    For good measure, I used some double sided foam tape on the back of the metal piece.
    I inserted the metal piece under the headliner and attached the camera's magnetic disc mount to the metal. With the tension from the head liner and with the surfaces that the tape caught on, the metal piece is firmly in place.
    I attached the camera and plugged it in.
    I made sure that the camera lens is between the window heater elements.
    The camera hangs down about 2 inches from the headliner, but I don't see it while looking in the rear view mirror from the diver's seat.
    While driving, I don't see the camera, but here it is from the rear view mirror.
    I suppose I could have positioned it over the passenger side head rest. It might have been less obvious there.
    Somewhat visible from outside. BTW, the camera is centered to the truck, but the lens is not centered on the camera; nor is the mount centered on the camera.
    Thanks for looking :)
    TreeCat, Anomalos7, GODZILLA and 15 others like this.
  2. Mar 9, 2019 at 12:59 PM
    Very nice. Now I know how I'm going to mount mine.
    Soon as the weather warms up here, I'll be going to Home Depot.
    Thanks for sharing. :thumbsup:
    Netmonkey[OP] and porkitt like this.
  3. Mar 9, 2019 at 1:48 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    I'd recommend tinting the rear window so nobody can see it. It won't affect the view of the camera either. I have a Blackvue DR590 2ch system and it works great.
  4. May 3, 2019 at 10:35 AM
    boneless
    boneless New Member
    2016 Black Tundra Platinum
    Looks good! Just got a new camera, and it has a rear facing camera as well.
    Just wondering, how did you run the cable exactly? Through the headliner?
  5. May 3, 2019 at 11:27 AM
    Netmonkey
    Georgetown, TX
    :D
    NewImprovedRon likes this.
  6. May 3, 2019 at 11:30 AM
    boneless
    boneless New Member
    So far for comprehensive reading... I have an excuse, I am a foreigner... :)
  7. May 8, 2019 at 12:49 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I used a pair of rectangular magnets to secure the rear cam of my Thinkware F800. Works great!!!F9009629-52C6-41B1-B8BA-EBF259E495F8.jpg760B351D-98D7-4962-96F8-1475D11E74B9.jpg
  8. May 8, 2019 at 1:55 PM
    plumber802
    Andy
    Vermont
    Ace Hardware $3:99 5DB3EFA0-341B-4AAE-8B32-D568AA618054.jpg
    D4x4TRD and Ostrich like this.
  9. May 8, 2019 at 1:57 PM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    How sturdy are they? Does the rear cam shake much?
  10. May 8, 2019 at 2:06 PM
    plumber802
    Andy
    Vermont
    I drove around on our pot hole cratered streets for a while and checked the rear cam footage and it seems pretty stable. The good thing about the magnets is that they have a low profile that keeps the camera close to the headliner which has a fair amount of rigidity along that seam/edge.
    porkitt and Ostrich[QUOTED] like this.
  11. May 8, 2019 at 2:24 PM
    Ostrich
    Nikki
    Marion, Texas
    That's good to know, thanks. I'm getting a cam this week so I'll try that out.
  12. May 8, 2019 at 2:27 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  13. May 12, 2019 at 7:10 AM
    osucowboy96
    osucowboy96 New Member
    Wichita Falls, TX
    2017 Inferno CrewMax
    I found basically the same exact magnet at harbor freight, but with 5 lb pull, for $0.99. Do you think that there would be an issue with the magnets messing with the camera?
    619Tundra likes this.
  14. May 12, 2019 at 7:22 AM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    What is this? Is this secured with the magnet?
    Where did you get this?
  15. May 12, 2019 at 7:56 AM
    See posts 7 & 8. ;)
  16. May 12, 2019 at 8:07 AM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    So, that black thing is a block magnet?
  17. May 12, 2019 at 8:15 AM
    Not my post but if you go to www.magnetsource.com
    Search 07044, you will see it is a block magnet.
  18. May 12, 2019 at 9:25 AM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    It is strong enough to stick to the metal under the liner?
  19. May 12, 2019 at 10:24 AM
    That is a question for the OP!
  20. May 12, 2019 at 11:11 AM
    Netmonkey
    Georgetown, TX
    i didnt use the magnet. you will have to ask @plumber802 :)
  21. Jan 12, 2020 at 12:40 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Reviving an older thread as my single front cash can is being returned, tried a GoPro but can't get good coverage as it's too far from the windshield and it posses its own problems (auto on, thedt, etc).
    I tried a magnet today, not a super strong one and I found a spot just off center that a magnet will stick.
    Thoughts on if that will work for a rear dashcam mount, without having to access under the header to put a shim, if I attach a magnet to the base of say this one?
    Is the magnet block above simply just placed against the headliner and secured with magnet strength? If so, it sounds too easy.
    You can sort of see my magnet on the roof.
  22. Jan 12, 2020 at 3:28 PM
    TundraTSS19
    San Antonio, TX
  23. Jan 12, 2020 at 3:57 PM
    Netmonkey
    Georgetown, TX
  24. Jan 12, 2020 at 6:16 PM
    TundraTSS19
    San Antonio, TX
    I got the 2 inch and yes very simple to install. I got 2 sided tape and then placed between headliner and metal roof and pushed up to seal it. From there 2 sided tape on the camera to the bracket and done.
    BravoDeltaRomeo likes this.
  25. Jan 12, 2020 at 6:57 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I used a Binder Clip to hold my Thinkware U1000 Rear Camera worked good holding strong took a second To install and cost me .99 for 2
    D3C8C454-9AA5-43CC-93A4-A59AADAB93D9.jpg 4F685AC1-4382-4F38-A411-3FB3AE1D0674.jpg 2760F010-C6FD-408F-A508-37D4074FFD2F.jpg
  26. Jan 12, 2020 at 7:19 PM
    ZPMAN
    Minnesota
    When I get time I'm going to install one of these: TOGUARD Backup Camera 10" Mirror Dash Cam, Dash Cam Front and Rear Full Touch Screen Video Streaming Rear View Mirror Camera,Night Vision Waterproof 1080P Rear Camera https://www.amazon.com/dp/B07PFPJ2DJ/ref=cm_sw_r_cp_apa_i_P-9gEbKYCFC7E
    Seen and used these in the Philippines.
    Has anyone tried incorporating the rear cam into the center break light lens ?
  27. Jan 12, 2020 at 8:10 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
  28. Jan 20, 2020 at 7:17 PM
    2chains
    2chains New Member
    Southern Ablerta
    Great ideas, thanks for posting! Looking at Thinkware f800 dual setup.
  29. Jan 20, 2020 at 7:49 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    I got the U1000 dual 128G with the parking sensor and OBD Hard wire harness and now a dedicated Hotspot in my truck for it from T-Mobile, i dont know how I feel about the set up it was a lot of money the picture is great maybe I don’t really understand how it’s suppose to work But I thought I was going to be able to live view the truck while it was parked and I still can’t do that cause the camera does not get power when the truck is off so next step is to get a Celllink for another $300 so the Dashcam can have its own dedicated power source i dont know will see maybe I’m missing something I need to call Thinkware just been super busy with the weather here in chicago truck is parked in the garage I don’t use it till spring
  30. Jan 20, 2020 at 9:06 PM
    2chains
    2chains New Member
    Southern Ablerta
    Looking at the Cellink feature. Mostly interested in the parking mode aspect... these bundle's are surprisingly expensive.
