Rear charger fuse location??
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Kevfran99, Oct 29, 2020.
  1. Oct 29, 2020 at 8:51 AM
    Kevfran99
    Kevfran99 [OP] New Member
    Kevin
    Lilburn, GA
    '19 TRD PRO
    TRD Rear Sway Bar - Front tint - Caliraised LED Fogs & Light Bar-Bed LEDs-Bed Cover-Wireless Charger
    Added the wireless phone charger to the center console today but it’s not getting power. Anyone know which fuse powers the rear power port. I can’t seem to find it.
  2. Oct 29, 2020 at 9:03 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I am 90% sure of this:
    Drivers kickpanel > pull off fuse box cover > it is P/OUTLET NO2 (on right side, half way down). 15A fuse.
  3. Oct 29, 2020 at 9:06 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Checked that one and it’s good.
  4. Oct 29, 2020 at 9:10 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    2018 SR5 4x4 Inherited from my dear dad RIP 4/21/2020
    Two years old and 5200 miles when I took ownership
    Is that new charger powered from the console box rear passenger cigarette lighter socket?
    If so there is a fuse in the under the hood fuse box as well as the drivers kick panel.
    On my 2018 there are two fuses, I know cause I popped one of the 2
  5. Oct 29, 2020 at 9:12 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Yes it is. Which 2 fuses under the hood?
  6. Oct 29, 2020 at 9:13 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    Hmmmmm.........let me run out.....
  7. Oct 29, 2020 at 9:18 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    If my memory is worth a shit.....it's the 15 amp fuse shown almost dead center on the cover map called p/outlet No. 1
  8. Oct 29, 2020 at 9:20 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Damn checked this one already too
  9. Oct 29, 2020 at 9:22 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    Well....there is what looks like a relay in that under hood fuse box.
    Middle and almost far right on the map.
    Says: P/OUTLET NO. 1
    Don't know anything bout it
  10. Oct 29, 2020 at 9:24 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Swapped that. Didn’t work either
  11. Oct 29, 2020 at 9:27 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    We must be not looking right. Maybe different fuses than we think.
    Have a volt meter?
    I'd probably try pulling the fuse and probing for +12 volts etc.
  12. Oct 29, 2020 at 9:33 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
  13. Oct 29, 2020 at 9:53 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
  14. Oct 29, 2020 at 10:14 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    Kev...I still think you have a bad fuse.....somewhere.........
    What caused your loss of power?
  15. Oct 29, 2020 at 10:23 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Not sure. Just plugged in the wireless phone charger. Unplugged it still no power the the rear charger.
  16. Oct 29, 2020 at 11:30 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    OK, so once you solve the loss of power then you will have to try the charger again to verify if it's bad. Get extra fuses if that's the no power issue.
  17. Oct 29, 2020 at 12:27 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Honestly I don’t care if the rear charger works. I just want the wireless phone charger to work. Gotta figure out why it’s not getting power.
  18. Oct 29, 2020 at 1:28 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    So I have confirmed it’s the fuse for power outlet 2 under the driver side dash. I have swapped out the fuse so that’s not my problem
  19. Oct 29, 2020 at 1:38 PM
    1rebmem
    1rebmem New Member
    Jef
    TN
    I feel for you.
    I'm sure you didn't plan to spend ALL day long on this project.........
  20. Oct 29, 2020 at 1:51 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Pretty much. Figured 30 mins at most 45. Spent the rest of the day putting in the tailgate lock. Instructions where different than what I had ‍♂️ But at least it’s done and working. Still trying to figure this one out. Fml
  21. Oct 29, 2020 at 2:21 PM
    1rebmem
    1rebmem New Member
    Jef
    TN
    Kev, how are you checking the fuses?
    Meter?
    Substitution?
    Also...the new wireless charger is not getting power. Could the supplied pigtail wiring harness be the culprit?
  22. Oct 29, 2020 at 2:43 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Yes I have swapped out other working fuses. Even used the spare. I disconnected the phone charger and verified that wasn’t the problem already.
  23. Nov 3, 2020 at 6:06 AM
    Drundra
    Drundra New Member
    Dru
    Seattle, WA
    2014 White Tundra 1794
    Hey did you get this figured out OP? Just ran into the same problem on my '14. I narrowed down my problem to the 3a fuse on the wireless charger harness. It keeps popping once I turn the car on.
  24. Nov 3, 2020 at 6:30 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I did check this fuse and it's not my problem. I don't have power to the rear charger with or without the phone charger plugged in. I'm taking it to a wiring genius Thursday.
  25. Nov 3, 2020 at 6:34 AM
    Drundra
    Drundra New Member
    Dru
    Seattle, WA
    Good luck man! Keep us posted.
    Kevfran99[QUOTED][OP] likes this.
  26. Nov 3, 2020 at 8:05 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Ok, stupid question. Are you checking for power with or without the key on? Some people may not know our trucks have keyed sockets. That's why I modded mine to be constant.
  27. Nov 3, 2020 at 8:17 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    yes I checked with the key on
    Rockgate[QUOTED] likes this.
  28. Nov 11, 2020 at 6:50 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    Hey OP.....did you get this figured out?
  29. Nov 11, 2020 at 6:55 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Yep forgot to post. When I plugged in the new wiring harness I accident without knowing it bent a terminal from the original plug. Hence the reason it still didn't work when I plugged it back into the rear charger. face palm
    1rebmem[QUOTED] likes this.
