Rear cab window stopped working, unsure if switch, relay or motor
Discussion in '1st Gen Tundras (2000-2006)' started by BlueC5driver, Sep 14, 2024.
  1. Sep 14, 2024 at 8:42 AM
    BlueC5driver
    BlueC5driver [OP] New Member
    2006 Tundra Double Cab
    Hello from KY fellow Tundra drivers..especially 1st gen!!
    My 2006 double cab rear cab window stopped working yesterday. I had rolled it down part of the way then when I got home to roll it back up...nothing. No clicking at all. I have removed the panel and the wiring looks good...no corrosion. Wondering if someone has access to a wiring diagram that would cover this....as I don't know if it's a switch...relay or the motor itself. I have had this truck for about 1 1/2 years and the window has always worked so it's not stuck or from lack of use..at least since I have owned. Thanks
  2. Sep 14, 2024 at 11:21 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Check fuses?
  3. Sep 14, 2024 at 11:28 AM
    BlueC5driver
    Yes fuse seems to good.
  4. Sep 14, 2024 at 1:46 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    No offense intended, but did you accidentally activate the power window lock switch? I've accidentally done that and thought something went haywire with the window.
    shifty` and TX-TRD1stGEN like this.
  5. Sep 14, 2024 at 2:00 PM
    shifty` I'm having daydreams about night things
    Wiring diagrams are linked from the 4th or 5th paragraph over here: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    But to @Mustanley's point, did you try rolling up/down any of the 3 non-driver windows at their controls, just to make sure the lockout isn't pushed in? It's such an easy button to press. You'd be about the half-dozenth person I've seen do it.
  6. Sep 14, 2024 at 2:48 PM
    BlueC5driver
    Yes guys I had already checked the window lock and it's not down (but i pushed it off & back on to be sure). Also checked all 4 door windows & all are working. I think all those easy fixes are not to be...unfortunately for me. Lol Thanks for asking though!
    Weagle likes this.
  7. Sep 14, 2024 at 4:51 PM
    Next steps ... If you pop off the back plastic wall to gain access to the motor - which I realize is a not convenient already, but you'll be doint it anyway - IIRC, the motor has three or wires. The ones I remember are one for up+, one for down+, one for ground-. I posted more info around here, but the gist (going from memory) is, separate the harness connection jumper, then use a 9v (or if you have a 12V battery from an alarm or UPS) with a jumper wire to jumper the motor's ground connection to the negative batt terminal, then feed power into each of the other plugs in the connector. The motor should go up and down in each of the other wires if it's OK. If not, you need to replace the motor. If so, you have a wiring issue and need to hit the community megathread I linked above to trace back in the wiring diagrams (EWD).
    And to that point, you can use the EWD to figure out the wiring colors. Or use search to find a prior post of mine on it.
  8. Sep 14, 2024 at 4:52 PM
    Here you go, from quick search:
    https://www.tundras.com/threads/2005-double-cab-rear-window-question.142896/#post-3593138
    Quoting that here, and the bolded red info is important to you. 'click to expand' this quote for more, and note, if you have a cordless drill you can probably use its battery as a stopgap for battery source:
