Rear bumper light install ?
Discussion in 'General Tundra Discussion' started by GSD, Nov 18, 2020.
  1. Nov 18, 2020 at 6:06 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    2019 Platinum Crewmax
    Looking to install some flush mounted lights in rear bumper and curious if there is a step by step out there, particularly around the wiring instructions? I’m looking to wire to reverse lights and also an anytime toggle switch.
    Not sure how involved it is, but a local shop that specializes in light installs quoted 5 hours labor.
  2. Nov 18, 2020 at 6:24 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    The longest time for me was cutting the lights into the bumper. All told probably around 3 hours but I would think that a shop should be able to do it quicker than me. I used the Rigid SR-M flush mount backup kit which came with the full wiring harness and three-position switch. I have anytime on with the switch, off always, and on with backup lights for the three positions.
    Bigboitundra, Ely010606 and GSD[OP] like this.
  3. Nov 18, 2020 at 6:34 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Took me maybe 2 hours. I was going to mount in the bumper ends but after looking at getting a wrench in there I opted for the plastic. It was a little tough working around the reinforcement strips that connect to the ends. I just wired to to the reverse lights. It is easy enough to just turn the key to on and put gear selector in reverse. I had some single row leds mounted under the bumper but they started to dim and I had always wanted the ones I have now. I think the under bumper lights were IP67 and moisture got to them. I have had some Mictuning IP68 8" on boat trailer and the have had no problems in 2 years.
  4. Nov 18, 2020 at 9:03 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    How difficult was the wiring? Seems wiring straight to reverse lights would be easier, but I'd like to have the three position option like you did.
  5. Nov 18, 2020 at 9:07 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    I've got upgraded reverse light bulbs, but also need more light. I'm debating mounting them in the bumper ends, or the plastic where you put them. The bumper ends do look a little more difficult given what's on the backside...
  6. Nov 19, 2020 at 10:18 AM
    APalmTree
    Brandon
    SW Washington
    The Wiring wasn't too bad. 2 leads to the battery into the relay, 4 wires to the switch and I taped into the reverse light right at the tail light. I ran the wires along the frame rail with a stock harness that is there. The hardest part of the wiring is poking the wires through the firewall and the wires to the switch are too short to leave the relay in the engine bay without extending them slightly. With the rigid harness (I can't tell you about any other you may find on Amazon) everything was very well documented and the directions were easy to follow.
  7. Jan 13, 2021 at 7:17 PM
    Do you happen to remember what size opening was needed? My bumper opening is a 2x3. Thanks.
  8. Jan 13, 2021 at 8:22 PM
    APalmTree
    Brandon
    SW Washington
    I never measured actually. The lights came with a rubber piece that sits between the bumper and the housing and I traced the outline of that. This is from the Rigid site though that should be what you are looking for.
  9. Jan 13, 2021 at 8:47 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  10. Jan 13, 2021 at 8:57 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    F814D889-5867-4A33-AE05-33AB77CEDCDB.jpg I used these smaller Rigids. I don’t remember the part number. Flush mount. Wired to switch pro so it was easy. But still just a hot/ground to relay/ switch . I’ll dig for the instructions.
    Mounting took about 30 minutes.
    I think I measured and remeasured
    For 4 hours prior to drilling the first home. These lights did not require a rectangle hole
    I used a hole saw (carbide) specified in the instructions, 1.75” Once I knew my
    Center point to punch it was simple. I sweated though.
    Bigboitundra likes this.
  11. Jan 13, 2021 at 9:14 PM
    NoRcptn
    NorCal
    2017 Platinum
  12. Jan 13, 2021 at 9:19 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Those are Rigid Industries 20631 Black Flush Mount (Ignite LED Diffused).
    Amazon.com: Rigid Industries 20631 Black Flush Mount (Ignite LED Diffused): Automotive
    I had one I used for an extra backup light, but replaced it with a Baja Design light.
    That 20631 was a good light and plenty bright...
    I just wanted a different look with the BD...
    More pics and dimensions of the Rigid 20631 light in post 758 of this thread..
    Pay it forward----> free goodies. | Page 26 | Toyota Tundra Forum (tundras.com)
    NoRcptn[QUOTED] and Rica25 like this.
