Reverse light wire location - Solved (sort of)
Discussion in 'Lighting' started by claptrap, Jun 26, 2017.
  1. Jun 26, 2017 at 9:35 PM
    claptrap
    claptrap [OP] New Member
    '16 TRD Pro
    EDIT: Solved (sort of)
    I found the reverse light wire in the passenger side engine compartment. much easier and cleaner install than running wire all the way to rear of vehicle. will post pictures of location and wire to tap shortly...
    Hello,
    Does anyone know where I could tap into the reverse lights inside the cab of the truck?
    Either under the dash, beneath the drivers seat or along either door?
    I have rigged up some Rigid auxiliary reverse lights. I'd like to use a three-way switch so I can have the lights Off, on w/ reverse, or constant on.
    Tapping into the reverse lights inside the cab is preferable to running another wire all the way back.
    Thanks in advance for the help!
  2. Jun 27, 2017 at 5:16 AM
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    I'm looking to do the same. Have you found a 3 way switch that will fit in the stock switch spaces?
  3. Jun 27, 2017 at 5:23 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Tap into the lines near the actual reverse lights
  4. Jun 27, 2017 at 7:13 AM
    claptrap
    '16 TRD Pro
    Thanks for the reply. I could do that option, but as stated in the OP: it's not my first choice.
    I'm not using stock switch locations so I'm not aware of a switch that would fit.
  5. Jun 27, 2017 at 7:25 AM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I'm interested in this as well. :popcorn:
  6. Jun 27, 2017 at 7:30 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  7. Jun 27, 2017 at 7:31 AM
    csuviper
    Broomfield, CO
  8. Jun 27, 2017 at 7:40 AM
    claptrap
    '16 TRD Pro
    Thanks for the replies csuviper!
    Running a wire to the back of the truck is easy enough, but I would really like to know where the reverse light wire is in the cab.
    My guess is that it must be under the drivers seat, and I'm hoping someone here knows which wire it is.
    I'd like not to test them all.
  9. Jun 27, 2017 at 7:45 AM
    csuviper
    Broomfield, CO
  10. Jun 27, 2017 at 7:47 AM
    csuviper
    Broomfield, CO
    @Nor7 can probably help as he is the Chilton Manual Guy
  11. Jun 27, 2017 at 7:48 AM
    claptrap
    '16 TRD Pro
  12. Jun 27, 2017 at 11:21 AM
    claptrap
    '16 TRD Pro
    I've found a solution that results in a much cleaner install than running another wire all the way to the rear of the vehicle.
    I'm using a 3-way switch and relay. I didn't want to run any more wires to the rear of the vehicle than was necessary, so I figured there must be a way to tap into the reverse lights from the cab.
    I was able to find a 2015 Service manual with wiring diagrams (downloaded from Russian website) and found what I considered the easiest place...
    Passenger side engine compartment, inside the connection box, Connector RA5, Pin Location 5, Blue wire w/ Red Stripe:
    You can pass the wire form the drivers side, behind the head unit to the passenger side using a piece of romex, coat hanger or similar.
    Then the wire passes through the firewall where all the other wires pass through. You just have to cut the tip off of the rubber nipple. (you can see my white wire passing through in the photo)
    Unfortunately, following the wiring back from the BK-UP fuse, there doesn't appear to be a dedicated reverse light wire that is easily accessed until this point.
    Hope this is helpful.
    (this is the thread where I found the service manual, no virus from download: https://www.tundras.com/threads/2015-service-manual.7436/)
  13. Jun 27, 2017 at 7:13 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    The stereo harness has a reverse wire to drive the optional backup camera.
  14. Jun 27, 2017 at 8:32 PM
    claptrap
    '16 TRD Pro
    Yes, this is correct. I didn't want to use the back up cam wire as I'm going to install the FRAC harness. I am intentionally keeping the auxiliary lights and cam completely separate. Plus I didn't have to take out the head unit to install.
    Backslider likes this.
  15. Jul 13, 2017 at 10:39 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    @claptrap are you doing this for the FRAC harness install? I'm doing the FRAC as well and I'm learning from folks like you who have a better knowledge of doing things. Any help is greatly appreciated. Thanks!
    TundraTex likes this.
  16. Jul 13, 2017 at 1:16 PM
    claptrap
    '16 TRD Pro
    this was for an auxiliary reverse light set-up. I didn't want to run any more wires than necessary to the rear of the vehicle.
    I have completed my FRAC install, so if you have specific questions I can try to help. It's a straight forward install.
  17. Apr 6, 2019 at 11:00 AM
    Rv2
    Rv2 New Member
  18. Oct 3, 2021 at 3:22 PM
    bdepew
    bdepew New Member
    2008 White Tundra Double Cab
    lifted, airbags
    did you happen to find the parking switch wire too?
  19. Jul 4, 2025 at 6:15 AM
    squeegee
    squeegee New Member
    Reverse wire is in passenger side kick panel, second white harness up from floor, blue wire + position 20 (thicker gauge than others in harness). Gen 2.5 (2014-2021)
    HulkSmurf14 likes this.
  20. Jul 24, 2025 at 8:12 AM
    nonebeter99
    nonebeter99 New Member
    Brett
    I read on a different forum post that someone had found a three-wire plug with reverse power on it behind the dash as part of the stereo harness. I was able to find the same thing on my 2008 Sequoia Platinum (with JBL sound). It is just a small plug with 3 wires going to it, red white and green. This plug was not being used in the aftermarket wiring harness, so I cut the green wire and spliced it to my new head unit's reverse signal wire. Back up camera works like a charm. I would assume even if the plug is in use you could spice into it and share the connection.
