Rear brakes noisy after pad and rotor replacement.
Discussion in '2nd Gen Tundras (2007-2013)' started by eggman, Aug 24, 2018.
  1. Aug 24, 2018 at 10:22 AM
    eggman
    eggman [OP] New Member
    2012 Tundra double cab 5.7
    None
    Has anyone ever had this happen? I replaced my rear brake pads and rotors on my 2012 Tundra today and when I took it for a test drive I could hear loud scrapping and a kind of squealing noise coming from the rear brakes. I jacked the truck back up and removed one wheel at a time while spinning the rear rotors. I removed one caliper and pad set at a time and spun the rotors and the noise was still there. Now All that's left is the rotors. I remove one rotor and still have the noise. I remove the other rotor and spin the axle and now there is no noise anymore. The noise was coming from the drum parking brake shoes that I never touched. I backed off on the adjuster on both rear wheels and reassembled everything. I went for another test drive and there was only a slight noise coming from the rear brakes. The more I drove the truck the more the truck the quieter the noise became until it finally stopped. I never even touched the parking brake shoes so why are they now making noise with new rear pads and rotors. I'm afraid the noise is going to come back. Any suggestions?
    Thank you,
    Gregg
  2. Aug 24, 2018 at 10:29 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Mine did/does the same thing, I just ignore it at this point.
  3. Sep 11, 2018 at 6:04 PM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Toytec Ultimate kit w/ Bilstein Fabtech UCA TRD stabilizer Boss shocks - Rear Airlift wireless one 35x12.5x20 Nitto G2 Grappler
    It's possible you slightly bumped the dust shield into the rotor and over time it wore down. This exact thing happened to me on the front. It doesn't take much to push those cheap things into the rotor.
    TheBeast and 1UPPER like this.
  4. Sep 11, 2018 at 6:10 PM
    Your new rotors might not have the same inside diameter as your factory rotors.
    Pretty common and you did the right thing by adjusting them. You’re good.
    1UPPER and NewImprovedRon like this.
