Rear brakes and Emergency brake questions
Discussion in '2nd Gen Tundras (2007-2013)' started by patterson.walter, Aug 12, 2021.
  1. Aug 12, 2021 at 2:29 PM
    patterson.walter
    patterson.walter [OP] New Member
    Walter
    2007 white SR5 5.7 db cab
    Bought my 07 with 172000k at the beginning of this year. Found out that the parking brake does not work. Finally getting around to it have a few questions.
    What size are the rear bolts that thread in the the rotor to back then off the axle?
    Has anyone ever worn out there parking brake bad enough to have to adjust it?
    Thank you in advanced.
  2. Aug 12, 2021 at 3:01 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I believe there have been some rumblings about the cable mechanism for the parking brake seizing up, which is up about under the driver's side seat on the truck. I would be sure all that is moving freely before diving into the parking brake itself.
  3. Aug 12, 2021 at 3:10 PM
    timsp8
    NY
    Parking brakes can wear out. Like said above, there is an adjustment you can do on the cable going back to the brakes. It’s under the drivers side. Just follow the cable.
    The rotors don’t have a bolt holding them on, just the lug nuts. There is a star screw type thing you can use to adjust through a hole in the rotor. With you mileage and age, might want to check the rotor wear for replacement and just pull them off and check the parking brakes. Have a sledgehammer ready.
  4. Aug 12, 2021 at 4:11 PM
    patterson.walter
    Walter
    “Rotors don’t have bolts holding them in” correct :thumbsup:
    My truck had newly installed pads and rotors all around from the dealer I bought it from. The passengers side has rusted to the axle and I there are 2 threaded holes that can accept bolts. I am wondering what size they are? Was hoping some one knew so as not to make more then one trip to the local “gittin spot”. :eek:
    I will look for the adjustment under cab thank you for the advice. :)
  5. Aug 12, 2021 at 4:17 PM
    timsp8
    NY
    I read you post wrong and thought you were asking something else. Just did the wife’s rotors and hers had bolts holding it on. Every time I’ve done the tundra I just used a mallet to bang them off.
    patterson.walter[OP] likes this.
  6. Aug 12, 2021 at 5:38 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    8mm bolts to push out rear rotors get 2 of them
