Rear brake rotors warping faster
Discussion in '2.5 Gen Tundras (2014-2021)' started by alex r, Nov 26, 2020.
  1. Nov 26, 2020 at 6:40 PM
    alex r
    alex r [OP] New Member
    2015 tundra crewmax
    I have been noticing my rear rotors and break pads have been warping and where just replaced less than 9 months ago by the dealer any thoughts. Not towing anything and just city driving.
  2. Nov 26, 2020 at 6:45 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    What brings you to this conclusion???
  3. Nov 26, 2020 at 6:50 PM
    alex r
    2015 tundra crewmax
    Rear left break pad completely gone and warped rotor disc but rear right beginning to warped but break pad is wearing evenly with the front breaks
  4. Nov 26, 2020 at 7:27 PM
    timsp8
    NY
    Sounds like you have a stuck caliper. My 18 right rear was sticking after 2 winters. The pins were rusted over. Try to put new pins in it. I ended up just replacing it. Calipers are around $115 and it takes less than an hour to do.
  5. Nov 26, 2020 at 7:36 PM
    alex r
    2015 tundra crewmax
    Will look into might be the reason I had never seen only one side be so worn out.
  6. Nov 26, 2020 at 9:24 PM
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    Could this be covered under warranty?
  7. Nov 26, 2020 at 10:26 PM
    Maadcaap
    Maadcaap White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
    The traction and stability control will apply rear brakes too....
  8. Nov 27, 2020 at 4:56 AM
    timsp8
    NY
    I’m pretty sure pads and rotors are considered a wear item and not covered under warranty. You could try a stuck caliper, but they will probably say the same thing.
  9. Nov 27, 2020 at 5:18 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Agree with caliper issue...brakes typically are not covered under warranty...they are considered a consumable.
  10. Nov 27, 2020 at 5:23 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Would seem to me that if the dealer did the rear brakes 9 months ago and your having these problems already, maybe you should return and discuss this with them. I can't imagine that much wear that quickly unless there's bad parts, (sticking caliper or ?) but if so the problem most certainly should have brought to your attention by the tech. I see a possible argument for improperly completed job by the dealer.
    Dalandshark and deptrai like this.
  11. Nov 27, 2020 at 4:26 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Over-torqued lug nuts can warp a rotor as well.
    barryg41 likes this.
  12. Nov 28, 2020 at 5:18 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    This^^^. And improperly torqued.
