Rear brake backing plates
Discussion in '1st Gen Tundras (2000-2006)' started by Dtimber, Jan 4, 2019.
  1. Oct 10, 2019 at 4:27 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I dont think there is either, now that you mention it. I've all ready got a whole new bearing kit waiting.
  2. Oct 25, 2019 at 6:09 PM
    Mytechguyri
    Mytechguyri New Member
    2004 Tundra 4x4 Access Cab step side
    That would be the magic bearing tool alright.
    Such a well thought out design... It made the job almost painless (almost because while i was doing it, i tripped over the hydraulic lift base that was holding my truck up in the air, and cracked a couple ribs... But even with broken ribs i was able to finish the job that day with the tool )
    TX-TRD1stGEN and bmf4069[QUOTED] like this.
  3. Oct 27, 2019 at 7:18 PM
    Mytechguyri
    If you do it, i recommend replacing: backing plates, wheel cylinders (theyre only $10 and it beats the hell out of fighting to get the old one off a rusted backing plate or trying to open a rusted bleeder screw), plan on getting new studs and nuts for the bearing housing if the rust is severe (2 of the 4 on each side broke when taking mine off)... Of course axle bearings, inner and outer seals, and axle bearing housing o-rings....Since you have the brakes all apart, might as well do those too...So new brake shoes and brake hardware kit...and last... Depending on rust... Plan on replacing the 2 brake hard lines to each wheel... They'll likely break too... And new parking brake cable.
    Buy the parts online for the dealer stuff from somewhere like https://toyotaparts.bochtoyotasouth.com
    They'll be a whole lot cheaper for the dealer parts online than going to the dealer parts counter
