Rear block, stock?
Discussion in 'Suspension' started by OBXTundra, Sep 7, 2017.
  1. Sep 7, 2017 at 11:34 AM
    OBXTundra
    OBXTundra [OP] Member
    Southeast USA
    2018 Nissan Armada, 4x4
    This pertains to a 2010 Tundra, TRD, 4x4.
    I bought the truck used with 69k. I am trying to go through the truck, figure everything out, figure out mods the previous owner has done, and create a game plan. I am trying to figure out exactly what I have as far as a lift/leveling kit.
    The front is a bolt-on spacer above the stock TRD coilovers, I am planning to go with adjustable coilovers. I have my eyes on Radflo coilovers and JBA UCA's right now.
    The rear is where I have a question, do the 2nd gen 4x4 Tundras come with any sort of block from the factory, or does the leaf pack sit directly on the axle pad? I have a 1" block between the leaf pack and the axle pad (mounting pad welded to axle). I know some other manufacturers come stock from the factory with a 1" or smaller block under the leaf pack.
    I believe what I have right now is a "3-1 lift kit", 3" front 1" rear. I want to confirm this before moving forward.
  2. Sep 7, 2017 at 11:43 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You most likely have a block. It's not stock in which case.
    Post a pic so we can tell you for sure.
    GNTundra likes this.
  3. Sep 7, 2017 at 12:31 PM
    OBXTundra
    Southeast USA
    I'll get a pic on here in about 2 hours. Trucks at home.
    GNTundra and Law323 like this.
  4. Sep 7, 2017 at 2:32 PM
    OBXTundra
    Southeast USA
    1 of the front and 2 of the rear. What say you?
  5. Sep 7, 2017 at 2:42 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup, looks like a spacer lift up front with a block in the rear.
    831Tun and TheBeast like this.
  6. Sep 7, 2017 at 2:42 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I just went out and looked at mine, a stock 2013 and the spring pack is right on the axle pad. I'd say the P.O. added the block you have.
  7. Sep 7, 2017 at 4:26 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep. Not stock
  8. Sep 7, 2017 at 4:27 PM
    OBXTundra
    Southeast USA
    Thanks. I wanted the confirmation before I start making plans for the front.
    Law323 likes this.
  9. Sep 27, 2017 at 3:49 PM
    OBXTundra
    Southeast USA
    On the next episode of "DO I HAVE THIS". Is this the spacer for a front diff drop? Do I already have a front diff drop? Trying to get my ducks in a row before I place an order. For reference, this is the passenger side mount for the front diff.
    Eclipsed & Floating likes this.
  10. Sep 27, 2017 at 5:58 PM
    TheBeast The Beach
    looks like it. It's a good sign if the P.O. did it.
  11. Sep 27, 2017 at 6:03 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Mine came stock with a different drop, or else the shop that installed my lift put one on without mentioning or charging me for it.
  12. Sep 27, 2017 at 7:58 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I'd get rid of that block and get yourself a new Leaf PAC looks like there "hyper bowing" or at least flattining out a bit
  13. Sep 28, 2017 at 4:43 AM
    OBXTundra
    Southeast USA
    Does anyone know for sure if its a diff drop spacer or if this is what it looks like from the factory? To me it looks like a spacer. I don't want to make more work for myself or put an additional spacer in place, causing other problems.
    That is the plan. New leaf pack somewhere in the future. Getting the front sorted first.
  14. Sep 29, 2017 at 4:52 AM
    OBXTundra
    Southeast USA
    Does anyone else have a pic of their passenger side front diff mount? One that you know for fact either has the diff drop or is stock?
    I need a reference before I dig into the front end of the truck.
    Thanks
