REAR back window loose
Discussion in '2.5 Gen Tundras (2014-2021)' started by mightyowl, May 20, 2020.
  1. May 20, 2020 at 4:31 PM
    mightyowl
    mightyowl [OP] New Member
    Any experience this issue? If i roll down my back window any bit, there is a rattle inside. Any experience this?
  2. May 20, 2020 at 5:47 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Weird.. no.
    behind the rear seat there is a large access panel, not a ton of hardware to pull it loose. You’d probably see what’s causing the rattle.
    Or... take it in and mention it during the next service.
  3. Nov 23, 2020 at 3:27 PM
    Corrosivetendency
    Corrosivetendency New Member
    Nate
    2016 plain-jane d-cab
    I picked my truck up from being tinted today and he mentioned to me that the center, bottom of the rear window glass bowed out when he was doing his squeegee work. No leak, but the center bottom of the glass (non-slider/ fixed) will push out. And now it rattles on bumps. Is the window a framed assembly or what? I will have to pull the rear seats to check it out.
