Real camper mods
Discussion in 'Outdoors' started by mrhotvw, Jun 8, 2022.
  1. Jun 8, 2022 at 8:29 PM
    mrhotvw
    mrhotvw [OP] New Member
    2012 Tundra Crewmax
    TRD Supercharged and Limited 295/55r20's
    So I'm thinking - remove bed from crewmax.
    Add on fiberglass camper shell from a dolphin or whatever. Full time camper. Anyone done this?Screenshot_20220608-231856_Gallery.jpg Screenshot_20220608-231718_Facebook.jpg
  2. Jun 8, 2022 at 8:34 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Doesn’t look like it would fit
  3. Jun 8, 2022 at 8:47 PM
    You’ll need 2 Dolphin camper cabs to cover the back of your truck. And some blocks to set it up high enough to clear the cab of the truck. I’m sure it would look awesome.
    Retired...finally likes this.
  4. Jun 8, 2022 at 8:53 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Its a lot cheaper to buy a slide in camper or a travel trailer.
    dherring256 likes this.
  5. Jun 9, 2022 at 6:14 AM
    mrhotvw
    2012 Tundra Crewmax
    The new tacozilla in that road and track article got me thinking, is all.. probably much quicker to buy a camper, but to make one of these for less than 200k, it's the best I could come up with
  6. Jun 9, 2022 at 6:18 AM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    I say you should do it….. :popcorn:
  7. Jun 9, 2022 at 7:01 AM
    Warreng
    Warreng New Member
    I second this
  8. Jun 12, 2022 at 10:42 AM
    trj
    trj New Member
    Tom
    2020 Tundra SR5 TSS Quicksand
    If you want to remove the bed, then I would consider installing a flatbed (there are some very cool options out there now, ie sherptek.com, highway products), and then for camping consider the purchase of a flatbed camper (many options for these too).
    You can buy a flatbed that is slightly longer and wider then stack while still at around the same weight as the stock bed, and you can then purchase a lightweight flatbed camper to mount on top of the flatbed. If you consider this configuration, you can still have pickup truck when you have work needs (short sides can be removed/installed as needed, like a stakebed), and then mount the flatbed camper to the truck when you want to camp. If $ is no object, then consider the above.
    A reduced-cost option to above is a hard-shell-cab-over-camper-shell. I personally would like to go this way as it's one of the least expensive and lightest options. Tradesman (all aluminum) used to make these, but I understand has shut down due to covid.
    https://www.tundras.com/posts/2763448
    Bel-air camper shells makes camper shells as well and those are aluminum-clad wood structure builds.
    Moonlander is pretty cool, and I understand they are considering a cab-over for 2023 (who knows if that will happen).
    I think if you do any of the above, you will be within GVWR.
    All of the above would be light-weight alternatives and give you added flexibility as compared to the perm fiberglass intall route.
