Readylift 4/2 SST
Discussion in 'Suspension' started by 2020Platinum, Jan 31, 2020.
  1. Jan 31, 2020 at 9:31 PM
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Hey guys!...quick question, I’m brand new to lifts, I’ve never lifted any of my trucks in the past, so don’t know much about them...I’ve done a ton of research on my own, and also talked to several guys as well who have been very helpful...who is running the Readylift 4/2?...pros/cons?...I’m really leaning towards that kit, I like the Bilstein route as well, but want a little extra lift...pics would also be great if you’re running this exact kit...it’ll be going on my 2020 Platinum
    other question I have is, instead of blocks on the back, can I use shackles to get the 2” lift in the rear?...I’ve been told by a couple guy that blocks aren’t the best idea
    I’d also like to know if I can add Bilstein 5160’s to the rear, or if I have to stick to 5100’s
    thanks in advance for any and all help!!
  2. Jan 31, 2020 at 10:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    $1000 for a spacer kit...
    Get some actual lift shocks that won’t ride like crap.
    What tires/wheels do you want? Start from there, because that kit is just chock full of compromises
  3. Feb 1, 2020 at 2:19 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Extreme angles on the CV’s is the biggest thing and a rough ride. For $1000 you can get a fox 2.0 set up or even 6112 Bilsteins. You can not be at 4” but you can get close to 3” or 3” with some shims.
    shackles will be good in the rear I’m running 2” right now.
    just research max height those rear shocks can handle 5100s I think are good up to 1” not of lift so just make sure they accommodate the lift you want in the rear
    2020Platinum[OP] likes this.
  4. Feb 1, 2020 at 3:01 AM
    2020Platinum
    Patrick
    Northeast PA
    Ok awesome, thanks for the info!...if I do go this route (4/2 Readylift), do I just buy shackles and use them instead of the blocks that come with the lift?...sorry if that’s a stupid question, just trying to make sure I understand it all before making up my mind and pulling trigger...thanks in advance!
  5. Feb 1, 2020 at 3:22 AM
    xtyfighterx
    Ty
    North Idaho
    Yep also get poly bushing with the shackles.
  6. Feb 1, 2020 at 3:24 AM
    xtyfighterx
    Ty
    North Idaho
    I have pro form 2” shackles $60 on eBay super heavy duty can’t beat them for the price
    monaco730 and 2020Platinum[OP] like this.
  7. Feb 1, 2020 at 3:52 AM
    2020Platinum
    Patrick
    Northeast PA
    Just found them on eBay, added them to my watch list in case I go this route...thanks for the help!
    xtyfighterx[QUOTED] likes this.
  8. Feb 1, 2020 at 6:56 AM
    2020Platinum
    Patrick
    Northeast PA
    Here’s another question which I think I found the answer to, but again I just want to be sure before I pull the trigger on a kit for my truck...if I decide to just go the Toytec or Bilstein route (6112’s in front, 5100/5160’s in rear), can I add anything to get a little extra lift from that set up??...shims or anything like that??
  9. Feb 1, 2020 at 7:08 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    At the cost of the performance of your front suspension you can.
    Here is a good test, put a floor jack under the front crossmember and raise it up 3 inches. Do the angles on the control arms and cv’s look healthy? The higher the angle, the worse your ride quality is
  10. Feb 1, 2020 at 8:29 AM
    xtyfighterx
    Ty
    North Idaho
    Ya you can add shims to the top get you around 3”
  11. Feb 1, 2020 at 10:49 AM
    2020Platinum
    Patrick
    Northeast PA
    Ok that’s what I thought, thanks man I appreciate it!
  12. Feb 1, 2020 at 9:31 PM
    2020Platinum
    Patrick
    Northeast PA
    Ok, so another question (probably a very dumb one...lol)...if I go with the 4/2 Readylift, can I add either the Bilsteins (6112’s in front and 5100/5160 in rear) to that kit as well to help with ride??
  13. Feb 1, 2020 at 10:00 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Kind of but you won’t get 4 inches from it as the 6100 maxes out around below that
  14. Feb 1, 2020 at 10:04 PM
    2020Platinum
    Patrick
    Northeast PA
    Ok thanks man!...my head is spinning trying to learn all this shit with lifts...hahaha
  15. Feb 1, 2020 at 10:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    No worries. Theres a ton of stuff out there. The companies are trying to make money, and everything is a trade off.
    Best bet is find pictures of the truck that looks like what you were picturing then get suspension that will fit the desired wheel/tire combo
  16. Feb 2, 2020 at 7:05 AM
    I have the 3/2 kit which will be coming out soon. Spacers ride rough. Going to a much better setup.
  17. Feb 3, 2020 at 9:29 PM
    2020Platinum
    Patrick
    Northeast PA
    Decided to go with the 4/2 Readylift...May do shackles in rear instead of blocks, but anyone running this kit, what size wheels are you running?...any trimming with your size?...pics would be awesome
    and has anyone changed out their shocks with this 4/2?....thanks in advance!
  18. Feb 4, 2020 at 5:02 AM
    By the time you find shocks that would properly accommodate the travel of the 4/2 kit, you would be mostly there cost wise for a descent coilover and shackle setup.....and a better ride.
  19. Feb 4, 2020 at 5:20 AM
    2020Platinum
    Patrick
    Northeast PA
    Yea I’m not even sure I’m going to replace them, I’ve talked to several guys running the 4/2 with stock shocks that say ride is perfectly ok with stock, I don’t do a lot of off roading so I’m gonna stick with stocks to start anyway, just trying to see what’s out there in case I wanna switch em out...thanks man!
  20. Feb 4, 2020 at 5:38 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Depending on offset you can fit 35x12 with minimal trimming.
  21. Feb 4, 2020 at 8:45 AM
    2020Platinum
    Patrick
    Northeast PA
    Thanks brother, I’m sure I’m gonna be bugging you for info...hahaha
  22. Feb 10, 2020 at 7:12 PM
    2020Platinum
    Patrick
    Northeast PA
    Ok I’m gonna be installing my 4/2 Readylift SST this week, this may be a stupid question, I know I need to get an alignment done after install, but would it be ok to drive for a couple days in between without doing any harm?...I’m installing kit on Thursday, but may not be able to get truck in for alignment until Monday...thanks in advance!
    AZTundra likes this.
  23. Feb 10, 2020 at 8:13 PM
    Hokienate
    Hokienate New Member
    Nathan
    Keep us posted on this lift kit and install. I too have a 2020 platinum and am weighing my options. Following your YouTube channel hoping for some videos after your finished. Thanks.
  24. Feb 10, 2020 at 8:16 PM
    It will most likely be way out. Mine was with the 3/2. The 4/2 comes with a new UCA doesn't it?
  25. Feb 10, 2020 at 8:18 PM
    Don't do a spacer kit if you plan to offroad. @Toytec Lifts is where many of us recommend as a starting point.
  26. Feb 10, 2020 at 8:28 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    I think I drove about that long after I did my first lift. Just the less you drive he better. Unless you need an excuse to buy new and bigger tires lol
  27. Feb 11, 2020 at 3:44 AM
    2020Platinum
    Patrick
    Northeast PA
    Yes sir, comes with new UCA’s...and no off-roading for me, mines a pavement whore...lol...thanks for the feedback!
  28. Feb 11, 2020 at 3:45 AM
    2020Platinum
    Patrick
    Northeast PA
    Absolutely!...thanks for supporting my channel, plan on making many more Tundra mod videos so thanks for following along!
  29. Feb 11, 2020 at 3:48 AM
    2020Platinum
    Patrick
    Northeast PA
    Ok cool, I am actually changing out the wheels, and most likely going with 33’s or 35’s, love the Ridge Grapplers
  30. Feb 11, 2020 at 4:31 AM
    I have the RG's in 285/70/18 (34's). They are only about a 1/2 inch smaller than the 295/70 (35's) and 10 pounds per tire lighter. Mine are 59 lbs. Just an additional option for you. :thumbsup:
