Ready to pull the trigger on SCS Ray 10's...need advice
Discussion in 'Wheels & Tires' started by Kung, Feb 28, 2023.
  1. Feb 28, 2023 at 9:53 AM
    Kung
    Kung [OP] [Insert Custom Title Here]
    KG, VA
    Stage 1 Eibach lift is sitting next to me right meow as I type this....and next is rims. I've settled on SCS Ray 10's, but have two questions:
    1. Am thinking gunmetal or bronze, instead of matte black. What sayeth ye? Truck is Voodoo Blue so I think pretty much any of the colors would look sweet.
    2. I notice splines/extended spline lugs are sold as well. Would the lug nuts from my current rims (stock TRD Off-Road) not work? Obviously with a purchase of this size I want to make sure I get it right the first time, and get what's needed.
  2. Feb 28, 2023 at 11:12 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Color choice is up to you! I really wanted the dark bronze, as I think it’s better than any other manufacturer’s bronze tone. However, I have a Smoked Mesquite truck. The colors are too close, but don’t match. It would look like I tried, but missed. I think it would be great on just about any other color truck though!
    I have a set of Gunmetal Ray 10s and 285/75-18s sitting in the shop for when I wear through my current tires. Having a hard time waiting…
    You will need new lugs!
    Might also consider longer studs for at least the fronts, but not required.
  3. Feb 28, 2023 at 11:21 AM
    Kung
    KG, VA
    Appreciate the input. I actually ended up going with the matte black for two reasons:
    1. My Tundra (Voodoo Blue) has the blackout package; so it'll end up matching just fine.
    2. While it doesn't happen often, from what I see, they do discontinue rims, it seems, and it'd be easy to repair/match matte black rims. Not so much with bronze. LOL
    And yep, the lugs are on order. With that said, it'll be probably 2-3 months before I get them on, so I don't need the studs just yet. Got any you'd recommend?
  4. Feb 28, 2023 at 11:24 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    This is copied from a message I got from another member here. Shipping on the studs is horrendous, but finding the exact right size locally has proven to be a big challenge for most.
    <pasted info below>
    https://www.blackhawkjapan.com/en-us/products/kyo-ei-sblc-1
    Also order a stud installer from Amazonmakes it super easy. I also ordered extra cheap lug nuts just to use during install with the impact gun
    SoCiMa 22800 Wheel Stud Installer Replace Most All Automotive and Light-Duty Truck Wheel Studs https://www.amazon.com/dp/B09PNGG1Z1
  5. Feb 28, 2023 at 11:41 AM
    Kung
    KG, VA
    Out of curiosity, what are they needed for? Are the stock studs not enough as is?
    Am wondering if I need them for my use case (probably 90% driving on road; 10% on gravel roads, with the *VERY* occasional trip off-road).
    In any event; the matte black SCS 10's are on order and shipping out today. :) It'll be a month or two before I have them installed (along with my lift kit/shackles), so I've got time to get the longer studs if needed.
  6. Feb 28, 2023 at 12:06 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I’d pass for you use.
    OEM is just a little on the short side.
    Kung[OP] likes this.
  7. Feb 28, 2023 at 12:12 PM
    Kung
    KG, VA
    Well now that you said something, I'll obsess over it. LOL!
    On a serious note, if there's an issue, I'm sure I'll be notified of it when they're installed (will be having local dealership install the lift, because honestly they're the only ones I trust within about an hour radius), and if so, I'll obtain whatever's necessary.
  8. Oct 6, 2023 at 8:11 PM
    Jnickoles
    Jnickoles New Member
    2021 Tundra sr5
    Did you ever get your wheels mounted? If so, can you post a few pics? I also have a voodoo blue and I’m trying to decide between the black and gunmetal
