Re-tighten lugs after some time, after installing wheel spacers?
Discussion in 'Wheels & Tires' started by 040Tundra, May 11, 2017.
  1. May 11, 2017 at 6:45 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    They shouldn't affect the alignment at all.
    040Tundra[OP] likes this.
  2. May 11, 2017 at 6:48 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Did you make sure they were completely seated on the hubs? Don't see how that could happen. Would be pretty obvious. Maybe you got a defective spacer.
    Voyagermike likes this.
  3. May 11, 2017 at 6:52 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    I'd Re-align as it will be slightly off
    Bora also make .75 bolt on
    Some will tell you that alignment isn't necessary. Some who do alignment for a living will say to re-align.
  4. May 11, 2017 at 6:56 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What a noob
  5. May 11, 2017 at 7:01 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Excactly, not the proper spacer for our Tundras
    I've got Fuel Nutz D251 2 piece wheels ... They don't have any cut outs on the back side of the wheels so I either have to cut my studs (not happening) or exchange my rear set of spacers for 1.25".
    Interesting ... I haven't noticed any alignment issues with either the Spidertrax or Bora spacers. But need an alignment just the same from my level.
  6. May 11, 2017 at 7:03 PM
    Voyagermike
    Voyagermike New Member
    California
    I installed them correctly. It's probably a combination of new tires and the spacers.
    I took the spacers off for now. And did another test drive. It's still slightly pulling out not as bad. I will reinstall again and have it realigned next weekend.
    Jsena likes this.
  7. May 11, 2017 at 7:06 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    The spacers bolt to the hub, just like a wheel. If it were true that the spacers cause you to need an alignment, wouldn't you have to get one when you rotate the tires?
    Jsena likes this.
  8. May 11, 2017 at 7:10 PM
    r4z0r51o
    Dave
    Not 100% sure you would or wouldn't, but I agreed with you that I didn't think and haven't ever had alignment issues due to wheel spacers. Leveling spacers ... Yes, I would suggest an alignment for sure.
    Jsena and Voyagermike like this.
  9. May 11, 2017 at 7:46 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    So, maybe you already needed to get it aligned. That would make sense, the spacers and bigger, I'm guessing, tires would make it more noticeable.
  10. May 11, 2017 at 7:48 PM
    Voyagermike
    California
    Yeah I will definitely get it realigned. Thanks guys!
    Jsena and r4z0r51o like this.
  11. May 11, 2017 at 8:05 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I was talking to@lotsoftoys and he said that trimming the studs is no big deal and that if you need to put new stock ones on later that it's not very hard. Just take the rotor off and beat the studs out with a bfh. I'd rather not but if you like the offset and plan on keeping it that way it is an option.
    Jsena and r4z0r51o[QUOTED] like this.
  12. May 11, 2017 at 8:06 PM
    Warreng
    Warreng New Member
    A bit of heat will help loosen red loctite
  13. May 12, 2017 at 5:59 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Yeah I know. I did take a torch to them. But its hard to heat up the lugs because the hub soaks the heat. If you apply too much heat, you compromise the lugs. Anyways, I got them off, but it was a lot of work and I almost snapped a few lugs.
    Now I use blue and they never need to be re-tightened. I torque them like I described and they are good to go.
  14. May 12, 2017 at 7:46 PM
    r4z0r51o
    Dave
    So got home from work this evening and quickly checked the torque on the spacers I installed yesterday. Using blue loctite I found none that came loose severally but maybe only a few pounds. I can tell you that the blue wasn't as hard to work with compared to the red. Don't be lazy, check your spacers!
  15. Feb 8, 2019 at 6:48 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Anyone on 275/55/20 (stock) with 2” spacer?
