RCV Axle Group Buy
Discussion in 'Suspension' started by jc153, May 24, 2019.
  1. May 29, 2019 at 6:28 AM
    jc153
    jc153 [OP] Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Will do.
  2. Jun 7, 2019 at 6:12 PM
    jc153
    San Diego
    We have 4 confirmed now, 5 if you’re in Kris. @Spvrtan
    osidepunker and Sunnier like this.
  3. Jun 19, 2019 at 11:13 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Money well spent; these are +2.5 for LT..
  4. Jun 21, 2019 at 5:12 PM
    Spvrtan
    Kris
    San Diego, CA
    Anyone interested in one long-travel shaft for a trail spare axle? It's brand new and was only on the truck for a month. Camburg sells the set for $700. I'll let one go for $300. I can throw in an OEM axle for additional $150. You'll just need to swap the shaft to it yourself.
  5. Jun 25, 2019 at 9:23 AM
    Raider0311
    Raider0311 New Member
    Jeff
    Oklahoma City, OK
    2014 Tundra 1794
    Roll n Lock bed cover, Icon Stage 8, RXT leaf pk, 18" XD Bully's, Nitto 35's, Billet UCA's
    :thumbsup: yum
  6. Jan 8, 2020 at 8:35 PM
    boatzNhoez
    boatzNhoez Owner / Operator of MS MOTORSPORTS
    Cypress, CA
    2019 Platinum CMSB LT
    Too many hahahaha
    sorry to resurrect this...but can we get this going again?
  7. Jan 11, 2020 at 10:29 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
  8. Jan 11, 2020 at 11:49 AM
    jc153
    San Diego
    Hey man sorry just I saw this.
    The group buy was already done. There wasn’t much interest on here so we just barely made the required 5 people.
    I just reached out to rcv and asked about doing a group buy. Maybe you can do the same. They were receptive and easy to work with when I inquired.
    Sunnier likes this.
  9. Jan 11, 2020 at 12:03 PM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    I don’t mind reaching out to them. I’m just trying to see if anyone on here is interested.
    jc153[QUOTED][OP] likes this.
  10. Jan 12, 2020 at 6:54 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    I got another person in so far. So as of this post that’s two. Need three more. I will confirm with RCV this week if 5 or more will score us 25% off. Again this will apply to stock length or LT
  11. Jan 13, 2020 at 9:59 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    There are fitment issues with LT depending on your setup so make sure you know what you're getting into
  12. Jan 13, 2020 at 10:08 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    Fitment issues as in? I thought these LT axles were essentially a drop in replacement
  13. Jan 13, 2020 at 10:10 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    They're bigger. They can interfere the shocks or whatever. I dont have them so I cant say precisely, but I have some friends that had issues.
  14. Jan 13, 2020 at 10:18 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    I’m gonna try and verify this. These axles are on my list of parts needed for my build regardless.
  15. Jan 13, 2020 at 11:34 AM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    Ok fellas...they’re up for doing another group buy. LT, stock or whatever length you need. As far as the LT guys like myself they said bolt on and bolt on for stock replacements. I’m sure if you swap out to bigger C/O’s or use maybe some aftermarket tie rods there might be an issue.
  16. Jan 13, 2020 at 11:53 AM
    jc153
    San Diego
    Good point @osidepunker
    He is correct, I had to make a couple adjustments so the RCV axles would work with my Total Chaos LT setup.
    First you can’t use 3.75” ID coilover springs as they will contact the axle. Use 3” ID springs.
    Second you need to locate the limit strap in a different spot or it will rub on the CV boot and wear a hole in it. I just had the tab welded on the frame more to the rear than the recommended spot.
    Also it’s probably smart to relocate the OE brake line mount closer to the spot TC recommends.
    Sunnier likes this.
  17. Jan 13, 2020 at 12:11 PM
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    I specified when I asked about the Camburg kit and using the recommended C/O’s that Camburg recommends and RCV said complete bolt on. I can’t speak for TC or the other LT manufacturers.
  18. Jan 13, 2020 at 12:32 PM
    jc153
    San Diego
    They said the same thing to me about the TC kit. Time will tell.
    Sunnier likes this.
  19. Jan 13, 2020 at 12:34 PM
    #49
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    I’m just not a fan of having to rebuild the stock CV’s. A pain in the rear. Not to mention a supposedly bolt on option and stronger than stock unit makes this very appealing.
  20. Jan 13, 2020 at 12:39 PM
    #50
    jc153
    San Diego
    I hear ya, those reasons and the lifetime warranty are also why I went with RCV.
  21. Jan 13, 2020 at 12:50 PM
    #51
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    So far two on board for this.
  22. Jan 15, 2020 at 3:07 PM
    #52
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    need 3 more for this...hoping a few members jump on this
  23. Jan 22, 2020 at 9:03 PM
    #53
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    Any new interests by anyone?
  24. Jan 30, 2020 at 7:07 AM
    #54
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    :popcorn:
  25. Jan 30, 2020 at 8:14 AM
    #55
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
  26. Jan 30, 2020 at 9:17 AM
    #56
    boatzNhoez
    Cypress, CA
    Too many hahahaha
  27. Feb 3, 2020 at 3:02 PM
    #57
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    :popcorn:looking for 2 more peeps
  28. Feb 7, 2020 at 5:06 PM
    #58
    Emptypockets
    Emptypockets New Member
    2012 CM Platinum
    I'm definitely still in. So, we have 3 now is that correct?
    TG705 likes this.
  29. Feb 7, 2020 at 5:21 PM
    #59
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    Yes sir 3 definitely. Looking for 2 more. I’m ready to pull the trigger when we get them on board.
    TG705 likes this.
  30. Feb 13, 2020 at 11:08 AM
    #60
    boatzNhoez
    Cypress, CA
    Too many hahahaha
    :popcorn:
