RCI Skids and Oil Change
Discussion in 'General Tundra Discussion' started by mww982, Jan 8, 2020.
  1. Jan 8, 2020 at 11:00 AM
    mww982
    mww982 [OP] New Member
    2018 Tundra SRD 4x4
    How many of you with RCI skids have installed a Fumoto valve? If you have not, do you remove the skid plate to drain the oil or have any issues with a mess when changing your oil?
  2. Jan 8, 2020 at 11:41 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I have and I do have the fumoto.
  3. Jan 8, 2020 at 11:55 AM
    crolison
    crolison New Member
    The skid goes around where the pan drain bolt is, so it shouldn’t be in the way of the main pan.
  4. Jan 8, 2020 at 12:01 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I have the F103SX installed with an RCI skid. Works great. Even though the skid is shaped around the oil pan drain somewhat, I still got a too much oil dripping on top of the skid. You could probably get around it by rigging up a funnel.
  5. Jan 8, 2020 at 12:20 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    You don't use a piece of tubing?
    Tundradrenalin likes this.
  6. Jan 8, 2020 at 12:23 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I do use a piece of tubing with the Fumoto. I meant to say that prior to using the Fumoto, I would get oil all over the skid even though it's shaped around the drain bolt somewhat.
  7. Jan 9, 2020 at 9:57 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Works great
