RCI skid plate issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Feb 8, 2020.
  1. Feb 8, 2020 at 4:34 PM
    Genuine Cooling Systems [OP] New Member Vendor
    Nick
    19 Tundra TRD Sport
    Anyone have the rci skid plate? I'm trying to secure my front fender to the skid plate but the holes do not line up. Anyone have this issue?
    Rica25 likes this.
  2. Feb 8, 2020 at 6:42 PM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    2013 Rock warrior double cab
    2-1/2” front leveling kit, spider trex wheel spacers, line-x bed liner, change all lights over to led bulbs interior, exterior, and headlights. All bulbs are from headlight revolutions, RCI skid plates. RCI running boards
    They should have sent a bolt kit for that. Looks likes your missing the long bolts that connect to your bumper.
    Inquiringone and 15whtrd like this.
  3. Feb 8, 2020 at 6:47 PM
    Nick
    19 Tundra TRD Sport
    Yeah I'm not sure its designed for the 2019 fender. There website says 2007 to present.
    BTBAKER likes this.
  4. Feb 8, 2020 at 6:50 PM
    AzureNightmare
    AzureNightmare ASCM#1 Douchebag formerly known as 50 Buck
    Wyoming
    2019 Cavalry Blue SR5 Crewmax
    RCI Skids and Sliders SCS Ray10 Wheels in Gunmetal Grey Falcon Tow/Haul Shocks by Terraflex Jomax ABS Sensor Guards
    I have a 2019 and did the engine, trans, and fuel tank RCI skids. No issues at all. Others have had some missing hardware before, so I would touch base with @RCIoffroad to see what they say.
  5. Feb 8, 2020 at 6:53 PM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    C3856802-408A-473F-8E7D-213D416A7453.jpg Here’s a picture of mine. This is what it should look like buddy
  6. Feb 8, 2020 at 6:56 PM
    SM 2018 1794
    SM 2018 1794 New Member
    I just installed all three of the RCI skids on my 2018 1794. They did leave out the smaller bolts and washers to attach the front bumper tabs to the engine skid.
    Other then a trip to Home Depot the install went great.
    Ely010606 likes this.
  7. Feb 8, 2020 at 6:57 PM
    SM 2018 1794
    Yes HVAC24 pic is what mine looks like as well.
  8. Feb 8, 2020 at 6:57 PM
    AzureNightmare
    Wyoming
    Just a thought, if you've already tightened everything down, then that might be the issue. IIRC the directions recommended getting all the bolts started before tightening any of them down you might have enough play to align that one if you loosen everything up.
  9. Feb 8, 2020 at 6:58 PM
    AzureNightmare
    Wyoming
    I thought They tell you to reuse the original bolts for the very front in the instructions. Been months, so I might be remembering incorrectly.
    rmvcard0303 and Ely010606 like this.
  10. Feb 8, 2020 at 7:05 PM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    no I installed mine two years ago. And they send you new bolts that are about 1” long with lock nuts because the factory ones thread into the plastic bumper.
    HbbTundra08 and AzureNightmare like this.
  11. Feb 8, 2020 at 7:06 PM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    Sorry Azure not calling you out, I just now remembered installing mine lol
    AzureNightmare and Ely010606 like this.
  12. Feb 8, 2020 at 7:09 PM
    AzureNightmare
    Wyoming
    No worries at all. Best to have accurate info. I really wasn't positive about it. Once I installed it I forgot all about it.
    Pinay and Ely010606 like this.
  13. Feb 8, 2020 at 7:24 PM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    Thanks brother, we’re all here just trying to hopefully help someone else out
    Pinay, AzureNightmare and Ely010606 like this.
  14. Feb 8, 2020 at 7:42 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Tagging, im planning on ordering my skid also, just in case i run into any issues.
    Thanks for all the info.
    Pinay likes this.
  15. Feb 8, 2020 at 8:20 PM
    Nick
    19 Tundra TRD Sport
    I do have those small bolts. I just didn't see a way to put them on. If I put them through the top and thread down the pan wont be flush with the bar above due to the bolt head. Any help is appreciated.
  16. Feb 8, 2020 at 8:24 PM
    Nick
    19 Tundra TRD Sport
    Here are the instructions. It say to put the bolt through the top which doesnt make sense because when I tighten the bolts that secure the skid plate the bolt heads will be in the way.
    Rica25 likes this.
  17. Feb 8, 2020 at 8:27 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I had some washers missing. I know, some will say check bolts n washers before starting install, I guess too much to expect but not first I’ve heard of missing parts. They will send missing parts out to you, but you’re installing right there and messes the flow...
  18. Feb 8, 2020 at 8:52 PM
    Ely010606
    SPARKS, NV
    Thanks @Pinay , i will definitely do that first.
    Pinay likes this.
  19. Feb 8, 2020 at 8:56 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    The one I had missing was the half moon washer. We end up getting a reg round washer that fit fine :notsure:
    Rica25, 15whtrd and Ely010606 like this.
  20. Feb 8, 2020 at 9:15 PM
    mofferman
    mofferman New Member
    Windsor, CO
    2019 double cab
    I believe that I installed a bolt and nylon washer onto the skid plate as stated in step 3, then in step 7, you put the bumper tabs on those bolts and put another nylon washer on it.
    Tibetan Nomad likes this.
  21. Feb 8, 2020 at 9:16 PM
    mofferman
    Windsor, CO
    2019 double cab
    Forgot to attach the photo!
  22. Feb 8, 2020 at 9:20 PM
    Nick
    19 Tundra TRD Sport
    I got that part. Where does the bolt head go that secures your fender. Your plate looks flush, if I bolt mine down to will put pressure on the bolt heads.
    Rica25 and Ely010606 like this.
  23. Feb 8, 2020 at 9:23 PM
    Nick
    19 Tundra TRD Sport
    I circles where my issue is. If there is no gap between the frame of the truck and skid plate how does the bolt head not get in the way.
  24. Feb 8, 2020 at 9:49 PM
    mofferman
    Windsor, CO
    2019 double cab
    Looks like it is a flat head bolt that is just smashed between the skid plate and the frame. I did have to put these bolts on before installing the skid plate to the truck.
    Tibetan Nomad and Ely010606 like this.
  25. Feb 8, 2020 at 10:13 PM
    Ely010606
    SPARKS, NV
    This pics are very helpful
  26. Feb 9, 2020 at 3:53 AM
    Nick
    19 Tundra TRD Sport
    Thanks man, that helps. From what I see there is pressure on those bolt heads from the frame bolts. They could have thought of a better design in my opinion.
  27. Feb 9, 2020 at 9:03 PM
    mofferman
    Windsor, CO
    2019 double cab
    Great, glad to help! Did you get it working?
  28. Feb 9, 2020 at 9:09 PM
    browntundra77
    browntundra77 New Member
    Devon
    DMV
    2017 SBM Tundra Platinum CM
    following this thread in hopes that I receive the right hardware when i order.
  29. Feb 10, 2020 at 4:41 AM
    Nick
    19 Tundra TRD Sport
    I have all the hardware, I just dont want to bolt down the plate with pressure being on the 3 bolt head points that are used to secure the fender. I am still trying to think of a better solution. Right now I just have the fender tabs dangling. I will probably end up buying the bolts in the picture since they have a flat head.
    Tibetan Nomad and Tundradrenalin like this.
  30. Feb 10, 2020 at 5:42 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I changed all those non-structural hardware parts to stainless steel.
    15whtrd and MotoTundra like this.
