RCI skid plate group buy?-CLOSED
Discussion in 'Deals & Group Buys' started by Rica25, Oct 6, 2018.
Thread Status:
Not open for further replies.
  1. Nov 12, 2018 at 3:57 PM
    #691
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Also on the three tabs did you guys install the bolts with the thread facing downwards or upwards
  2. Nov 12, 2018 at 3:58 PM
    #692
    Rica25
    Ricardo
    Tulare
    Most pictures that I see online have thread going up
  3. Nov 12, 2018 at 4:00 PM
    #693
    Sharpienads
    Sharpienads New Member
    2018 Tundra SR5 TRD O/R
    Sounds like you got extra nuts. I just got the 6 for the bumper tabs and two for the cross member.
  4. Nov 12, 2018 at 4:01 PM
    #694
    Sharpienads
    I went down towards the ground.
    InfernoPRO likes this.
  5. Nov 12, 2018 at 5:09 PM
    #695
    typeone
    typeone about time I realized you could change this...
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Boom. Too cold out for this shit. Bloody knuckles. But got it done. Fairly easy but was hard with one person and two hands. Used a jack to help keep it in place.
    Solid built stuff. However that 38 gallon skid doesn’t not want to line up
    Black Wolf, MotoTundra and Rica25[OP] like this.
  6. Nov 12, 2018 at 5:19 PM
    #696
    Rica25
    Ricardo
    Tulare
    Did not send me lock washers for the rear carriage but I guess I can go get some at lowes
  7. Nov 12, 2018 at 5:56 PM
    #697
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Mine came in today! Super stoked
    Black Wolf and Rica25[OP] like this.
  8. Nov 12, 2018 at 6:00 PM
    #698
    Rica25
    Ricardo
    Tulare
    So to get this right is you put a bolt thru the top down and a lock nut then at the end u put another washer with another lock nut to hold the bumper tabs.......so each carriage bolt for bumper tabs takes 2 lock nuts?
  9. Nov 12, 2018 at 6:05 PM
    #699
    typeone
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    I didn’t get lock nuts either. Seems fine.
  10. Nov 12, 2018 at 6:10 PM
    #700
    Rica25
    Ricardo
    Tulare
    I installed it with out also but I'll head to lowes tomorrow and get 2
  11. Nov 12, 2018 at 6:17 PM
    #701
    typeone
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Where are they supposed to go?
    Rica25[OP] likes this.
  12. Nov 12, 2018 at 6:19 PM
    #702
    Rica25
    Ricardo
    Tulare
    The two long rear carriage bolts for the cross memeber
  13. Nov 12, 2018 at 6:33 PM
    #703
    typeone
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Oh I think they meant those lock because they have a square base at the bottom head to allow them to “lock” (fit snugly?) into place.
    That’s how I took it at least
  14. Nov 13, 2018 at 12:43 AM
    #704
    Sunnier
    Sunny
    San Diego, CA
    Finally :yes:
  15. Nov 13, 2018 at 12:45 AM
    #705
    Sunnier
    Sunny
    San Diego, CA
    Picture? Anyone....
  16. Nov 13, 2018 at 6:19 AM
    #706
    Rica25
    Ricardo
    Tulare
    Well the parts included sheet said it suppose to have 2 lock washers
  17. Nov 13, 2018 at 7:43 AM
    #707
    MotoTundra
    MotoTundra The Ocho
    Don
    I haven't had the chance to install mine yet but I will try to do a DIY unless someone beats me to it.
    This is what my schedule is looking like though...
  18. Nov 13, 2018 at 7:57 AM
    #708
    Sharpienads
    I didn't get any lock washers. I think the nylon locking nuts negate the requirement for lock washers. Right?
  19. Nov 13, 2018 at 8:18 AM
    #709
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    yeah I'm pretty sure they switched to nylon lock nuts to get rid of the lock washers and nuts.
  20. Nov 13, 2018 at 8:40 AM
    #710
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    Came into work today and these were waiting for me..
    ABDACDD1-B179-4798-AB26-E020CCC9B55A.jpg 3B210B73-E584-4C6B-AB28-A974A8AF8521.jpg
  21. Nov 13, 2018 at 11:36 AM
    #711
    Rica25
    Ricardo
    Tulare
    Makes sense
  22. Nov 14, 2018 at 9:02 AM
    #712
    MotoTundra
    MotoTundra The Ocho
    Don
    Well due to some snow in the forecast I had to spray the underside of my truck with fluid film this morning.
    While I had it up on the ramps I figured I would change the skid plate quick. It was 30 degrees out so I didn't do a DIY, plus my gloved hands were a mess from the FF.
    I thought the install was very straightforward with the instructions provided. If you don't have one, I would get a ratcheting 14 mm box wrench to make the job easier. I used a lift with a block of wood to support the skid plate while I lined up the first few bolts.
    The only thing I wasn't sure about was the direction of the half moon washers. The top of that crossmember seem pretty flat to me so I used the cut side on the outsides as it seems the crossmember may rise towards the outsides.
    The fit was perfect. I am looking forward to using the access door next oil change.
    Thanks again @RCIoffroad
    aperezsh, T-Rex266 and Black Wolf like this.
  23. Nov 15, 2018 at 12:50 PM
    #713
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    Hooked them up!
    5F5A25EE-2B64-40D4-9F8D-5C69CC4A1AF6.jpg 5607C288-A4C6-4BD4-A25F-97DA7E5E5B10.jpg
  24. Nov 15, 2018 at 1:42 PM
    #714
    Lot a members here running with decent skids now for sure!
    T-Rex266 and MotoTundra like this.
  25. Nov 15, 2018 at 5:57 PM
    #715
  26. Nov 15, 2018 at 6:51 PM
    #716
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    It looks like the original pan covers more per the photo vs the new one. Am I missing something?
    Sunnier likes this.
  27. Nov 15, 2018 at 6:52 PM
    #717
    Sharpienads
    It's wider, but so thin it's pretty much useless
  28. Nov 15, 2018 at 7:04 PM
    #718
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Useless indeed, crumpled mine first time i took the truck off road. Subsequently found itself in the trash can for the next pick up.
    WAtundra4x4 and Sunnier like this.
  29. Nov 15, 2018 at 8:16 PM
    #719
    Zoren Tundra
    Zoren Tundra New Member
    Eric
    2012 TRD off road 4x4
    Is this only for 3rd Gen Tundra?
  30. Nov 15, 2018 at 8:31 PM
    #720
    MotoTundra
    MotoTundra The Ocho
    Don
    The OEM "skid plate" is wider but it is also shorter and thinner (weaker). It is very thin and easily bendable, suitable for small road debris. The RCI skid is much stronger and has an access door for your oil filter. I went with an engine skid only due to funds and after installing it, now I want to pick up the transmission skid ASAP.
Thread Status:
