RCI skid plate group buy?-CLOSED
Discussion in 'Deals & Group Buys' started by Rica25, Oct 6, 2018.
Thread Status:
Not open for further replies.
  1. Nov 12, 2018 at 2:25 PM
    #661
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    yes.
  2. Nov 12, 2018 at 2:26 PM
    #662
    nuclearlemon
    wyoming
    2012 dc
    i'm going to guess the midwest
  3. Nov 12, 2018 at 2:28 PM
    #663
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    I didn’t get fumoto, pretty sure dealership guys wouldn’t know how to use it o_O
  4. Nov 12, 2018 at 2:58 PM
    #664
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Does anyone have pics of install just received mine 10 minutes ago
  5. Nov 12, 2018 at 3:03 PM
    #665
    Sharpienads
    Sharpienads New Member
    2018 Tundra SR5 TRD O/R
    What kinda pics are you looking for? I installed mine already but can take some pics real quick.
    Rica25[OP] likes this.
  6. Nov 12, 2018 at 3:21 PM
    #666
    Rica25
    Ricardo
    Tulare
    Where do the the long as bolts go?
  7. Nov 12, 2018 at 3:24 PM
    #667
    Sharpienads
    In the back of the skid all the way through the cross member.
    Black Wolf likes this.
  8. Nov 12, 2018 at 3:24 PM
    #668
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I think the long bolts go in the back (been awhile since I installed mine). I got the center bolt in place and then I was able to attach the the side bolts, then the front, and I did back last.
    dcsleeper408 and MotoTundra like this.
  9. Nov 12, 2018 at 3:25 PM
    #669
    Rica25
    Ricardo
    Tulare
    Ok......and the other 5 is what holds the skid down so the what are the six lock nuts for
  10. Nov 12, 2018 at 3:26 PM
    #670
    Sharpienads
    The 6 smaller ones are for the bumber tabs.
  11. Nov 12, 2018 at 3:27 PM
    #671
    Rica25
    Ricardo
    Tulare
    Mine only has 3 tabs
  12. Nov 12, 2018 at 3:30 PM
    #672
    Sharpienads
    It really depends how you attach them, but the general consensus seems to be put the bolt through the skid facing down, nut, washer, bumper tab, washer, nut.
  13. Nov 12, 2018 at 3:33 PM
    #673
    Rica25
    Ricardo
    Tulare
    So 3rd gen has 6 tabs
  14. Nov 12, 2018 at 3:36 PM
    #674
    Sharpienads
    No, just 3 tabs, but two nuts per bolt.
    MotoTundra, Black Wolf and Rica25[OP] like this.
  15. Nov 12, 2018 at 3:37 PM
    #675
    Rica25
    Ricardo
    Tulare
    Lol....this more complicated than Sway bar
  16. Nov 12, 2018 at 3:37 PM
    #676
    Sharpienads
    Sorry, I said bolt when I should've said nut in my post above. Dumb.
  17. Nov 12, 2018 at 3:40 PM
    #677
    Sharpienads
    You don't have to do it that way, but if you do, the bolts that go through the bumper tabs are secured to the plate if you need to remove the plate.
    Don't feel bad, it took me about 3 tries to get it right even after somebody else posted how to do it.
  18. Nov 12, 2018 at 3:40 PM
    #678
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah it is. It's pretty ridiculous these don't come with instructions. Turns a 30 minute job into an hour and a half job. It's not fun crawling under the truck 10-15 times with a skid plate on top of you, just to try to figure it out.
    TheBeast and Sunnier like this.
  19. Nov 12, 2018 at 3:41 PM
    #679
    Hey @Rica25......that RCI skid is a bit beefier than the OEM skid huh!
  20. Nov 12, 2018 at 3:43 PM
    #680
    Sharpienads
    @Rica25 did yours not come with instructions at all?
  21. Nov 12, 2018 at 3:43 PM
    #681
    Gorilla glued my diff drop spacers in place on the skid. I used my floor jack to position skid in place. Took maybe 30 minutes to bolt into place while drinking one beer.
  22. Nov 12, 2018 at 3:44 PM
    #682
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    I used floor jack to help with install, made it much easier to get everything lined up properly
  23. Nov 12, 2018 at 3:45 PM
    #683
    Exactly!!! Thinking outside the box does have it's advantages...……...:drunk:
    hi_rawb and Rica25[OP] like this.
  24. Nov 12, 2018 at 3:46 PM
    #684
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Did you get the new one piece up front? The older design with 2 pieces is impossible to install in 30 minutes without any instructions. It took over 30 minutes just to figure out what went where and what order to install it.
    Inquiringone and Rica25[OP] like this.
  25. Nov 12, 2018 at 3:46 PM
    #685
    Sharpienads
    Samesies
    Rica25[OP] and Black Wolf like this.
  26. Nov 12, 2018 at 3:46 PM
    #686
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Yup, more beer time :yes:
  27. Nov 12, 2018 at 3:48 PM
    #687
    One piece.. Yeah, the first version looked like lots of fun to install...heh..heh..I would have killed a sixer just thinking about it....
    Inquiringone and joonbug[QUOTED] like this.
  28. Nov 12, 2018 at 3:48 PM
    #688
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Mine was one piece
    joonbug[QUOTED] likes this.
  29. Nov 12, 2018 at 3:49 PM
    #689
    Sharpienads
    Just in case anybody got a skid without instructions...
  30. Nov 12, 2018 at 3:56 PM
    #690
    Rica25
    Ricardo
    Tulare
    Yeah I got instructions just not very detailed and I seem to have got a lot of nuts for I don't know what I got the three silver ones for the tabs on the original bumper also got five of the M8 by 30 mm are for the five locations to hold it down also got the two really long carriage bolts for the rear crossmember but I seem to have got quite a bit of nuts
Thread Status:
