RCI Offroad Tundra Rock Sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by RCIoffroad, Apr 22, 2019.
Which Slider Design Do You Prefer
  1. Full Coverage Main Rail, Wheel to Wheel (As seen in pictures)
    85 vote(s)
    88.5%
  2. Symetrical Main Rail Front and Rear (5" Shorter on Back, less pointed)
    8 vote(s)
    8.3%
  3. Same as our Tacoma Sliders, 45 Degree Mitered Main Rail (Covers Cab Only, About 10" Shorter Overall)
    3 vote(s)
    3.1%
  1. Jul 26, 2019 at 12:10 PM
    kevine0001
    kevine0001 New Member
    Kevin
    Good looking sliders. I'll be fabricating my own but I'm noticing that several have similar bolt on mounts, where there's much of the slider extending back without direct perpendicular support to the frame. Two questions:
    1. Since you're using what looks like 1/4 plate for the ladder, are these going to be prone to bending backwards towards the bed, if the front of the slider takes the initial hit? Any way to gusset these to prevent that?
    2. Since many want the wheel to wheel option, if that cannot be done due to structural issues to the frame, any way to add an inner gusset to the ends? Even a small one may help with an upward bend on the back end should you actually land on that back end. I also like the prior post about adding kick out, which it appears to have, but a small one. What about extending the kick out back another inch or two?
    dscharf1 likes this.
  2. Jul 26, 2019 at 4:54 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I am 6'3" and would make use of that feature.
  3. Apr 30, 2020 at 12:15 AM
    dscharf1
    dscharf1 New Member
    David
    2008 Tundra Crewmax Overland Conversion
    OME 2.5 heavy lift, Expedition One F/R Bumpers, Rhino top racks, ARE shell, camper setup (custom) inside.
    Totally interested in these. I like the top plate. Very definitely interested in a group buy.
  4. Apr 30, 2020 at 12:47 AM
    ryanw4x4
    ryanw4x4 New Member
    Ryan
    South West Washigton State.
    2011 SR5 Trd OFF-ROAD
    Those look pretty sharp. I like it.
