RC Cars
Discussion in 'Sports, Hobbies & Interests' started by cmb46, Sep 20, 2019.
  1. Mar 13, 2024 at 6:57 PM
    #961
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is that 6s?
  2. Mar 13, 2024 at 7:35 PM
    #962
    3S. This is from the project Slash that I am working on.
  3. Mar 13, 2024 at 8:10 PM
    #963
    Anyone with Traxxas UDR experience?
    I noticed 3 holes for the front part of the lower rear trailing arms, what do these do? Currently the arms are set in the middle
    Hbjeff likes this.
  4. Mar 14, 2024 at 3:35 AM
    #964
    IIonPilgrimg
    IIonPilgrimg New Member
    2008 Tundra Limited Double Cab 4x4 5.7 6-speed Red Rock
    Thanks for that! While I was at it, I also ordered a 45T crawler motor and the Integy boat trailer for my Great Planes Stinger: Current configuration is pictured.
    Stock dual motors are size RS-550. The aft motor has a dual output shaft. Two 7.2V NiMH batteries attach with hook/loop tape to the port and starboard gunnels inside the deck and the control board / servos are inside a box that could be waterproofed. (Length 24" Beam 9")
    What motor / ESC / Battery upgrade would you recommend? Why?
    Be technical. I can solder PC boards: Could switch from series to parallel wiring with a servo or switch and the motor cooling system in Traxxas Blast is interesting. It uses a 540 motor and the beam is a meager 5.75" but if/when available I might get one.
    GNTundra likes this.
  5. Mar 14, 2024 at 3:54 AM
    #965
    They are for adjusting the tilt angle of the dampers.
  6. Mar 14, 2024 at 5:03 AM
    #966
    centex
    centex New Member
    Done that a few times on 3s. Finally switched to a metal gear and that fixed that problem. Until the pinion gear walked and took it out.
  7. Mar 14, 2024 at 5:46 AM
    #967
    Yep.....I'm going to the hobby shop this afternoon to see if they have one. That's probably why most of the new stuff has all metal gears. I need to look at all of my Arrmas to see what they have. I know the Kraton is a metal spur gear, but I don't remember what the Infraction and Senton has. Slow at work so I'll pull the part numbers from the diagrams and google away.
  8. Mar 14, 2024 at 5:44 PM
    #968
    Tried trimming the SC body on the Senton 3S for tire clearance. The adjustable body post wasn't going to work on the front and I would end up trimming alot off of the wheel wells to get it right. I ended up going with a different body all together.
  9. Mar 15, 2024 at 5:42 PM
    #969
  10. Mar 16, 2024 at 7:20 AM
    #970
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
  11. Mar 16, 2024 at 7:28 AM
    #971
    Yeah either way it has to be replaced. I'm hoping that I can get the parts. This is in my 6S XMaxx. The 8S uses a cush drive setup.
  12. Mar 16, 2024 at 7:33 AM
    #972
    Retroboy1989
    Northern Utah
    Traxxas parts should be easy....
  13. Mar 18, 2024 at 9:39 AM
    #973
    It appears to be a bad bearing. It has a wobble to it.
    Retroboy1989[QUOTED] likes this.
  14. Mar 19, 2024 at 11:30 AM
    #974
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Bearings go all the time.
    But ..
    If I spray everything with WD-40 after almost all driving sessions (wet or dry). I'll spray it heavy on the bearings and then hit it up with compressed air for blowing off the excess. This will keep the bearings smooth and extend their life much longer. Also "wets" the look of the plastic for a bonus newbie shine.
    Only takes 5-10 minutes and my trucks always look and run like brand new.
  15. Mar 19, 2024 at 1:06 PM
    #975
    Went to the shop today to get some pinions for my son's truck. I also ended up with an RPM product for the rear of the Kraton, a new body for the Maxx, and a new SCT. The addiction is real but I should be good for a while lol.
  16. Mar 20, 2024 at 5:43 PM
    #976
    @Black@Blue19 I picked up another toy yesterday lol. I need to slow down lol.
    IIonPilgrimg and Black@Blue19 like this.
  17. Mar 21, 2024 at 2:11 PM
    #977
  18. Mar 21, 2024 at 7:35 PM
    #978
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is that the 1/7? Damn i saw that i want one bad
    Black@Blue19 likes this.
  19. Mar 21, 2024 at 7:55 PM
    #979
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  20. Mar 22, 2024 at 4:36 AM
    #980
    Its the 4S that was released back around October. If you watch Arrmas trend, they are releasing updated 4S vehicles even though they have 6S and 8S vehicles. For example, the Kraton 6S handles better than their 8S version. The Mojave 4S was actually rated by a few sites as the top release for 2023. https://www.arrma-rc.com/en/product/1-8-mojave-4x4-4s-blx-desert-truck-rtr/ARA4404.html
    Hbjeff[QUOTED] and Black@Blue19 like this.
  21. Mar 26, 2024 at 5:02 PM
    #981
    Ran the Mojave 4S for the first time today. Holy crap that thing has some serious body roll and rear end droop. Going to look into stiffer springs.
  22. Mar 26, 2024 at 10:30 PM
    #982
    tundznoff
    tundznoff New Member
    blk limited tundra
    TRD red axel swap Satin black wrapped fender flares Satin black wrapped bumper insert Icon stage 5 Icon 1.25 rear spring Drkdss panhard bracket Rave trd pro grill & lights 37” K02 17” 0 offset Nomad Sahara
    Put some laps in
  23. Mar 29, 2024 at 9:13 PM
    #983
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    So when do Traxxas lipos go on sale?? All my bats are long gone :(
  24. Mar 29, 2024 at 10:33 PM
    #984
    I have never seen a sale on them.
  25. Mar 30, 2024 at 5:23 AM
    #985
    IIonPilgrimg
    Ditto! New lawnmower in the garage for two weeks. I've not even unboxed it. I'm glad the west coast spring hasn't really arrived yet, although the apple tree thinks it has. I'll have to get outside and do something with myself other than RC modelling -- eventually.
    This thread has been very helpful with much needed info on advances within the hobby. My Lego / Erector / Revell youth has revived, full scale. Like riding a bike or roller skating again.
    Cleaned up the Stinger and installed a 12T brushed motor and ESC. Also changed the Tundra High Lift motor to a 45T. I think both were the right choice for how I'll use them, and they can share 5200 NiMH battery packs - have 6 now. Displeased with the look of the Tundra roll bar, I obtained the 'K' parts for the other Toyota High Lift - a double black chrome tube roll bar. Fitment required cutting exactly 1/2" from the rear braces and 3/4" from the front bars. Rears are screwed from under the bed with 2mm screws. The forward bars are hollow for LED wires and had to be tacked with CA glue.
    This is the www.Tundras.com website. So, I'll describe the Tundra High Lift parts used to modify the Great Planes Stinger into something like a scale Malibu Wakesetter LSV 23.
    Step 1: Tundra High Lift roll bar is flipped 180 degrees, backward. A Tundra servo pivot ball is centered above it - a hook for the tow rope.
    Step 2: I have chosen Violet/UV LEDs to act as black lights for seeing the deck and/or any bioluminescent plankton and possibly (for the very brave) night skiing / wakeboarding.
    Step 3: Wakeboards will be crafted from Tundra High Lift snowboard accessories and mounted to the outside edges of the tower with bits of Tundra kit sprue material and/or a modified roof rack.
    Step 4: LED Lighting: It's USCG approved with a fire extinguisher, horn and flares (or gun). The anchor/running light mast is Tundra High Lift clear lens sprue material: 3mm diameter. Flatten the butt-end and also the top of a white 3mm LED and glue them together with CA. (Be sure to round the top and polish both well... it's brightest when not opaque. Nav lights are covered with clear roof lenses from the Tundra kit.
    Step 5: It's not a wakeboard boat without Boomin' Tunes:
    Since buying my 'real' Tundra, I also resuscitated my passion for audio and high fidelity. I've been studying Class D amplifiers, Bluetooth and SD card-reader tech. I've successfully built a functional 3.7 watt stereo amp (part# MAX98306) driving two 1" dome tweeters. Aux-in is an MP3 player weighing only 138g. Although BT capable, the range is only 60 feet. So, it can't stay ashore. Additional BT amps and some speakers are in the design phase. I've gone deep on research: With the NiMH batteries, I'm limited to about 12-15 watts. However, there are two in the boat and I could run the Tunes at 14V for closer to 30 watts. That seems a bit more than necessary, especially because I want to pilot the boat too!
    Step 6: For realism, it will want a teak swim platform at the stern, spandex wetsuits and a cooler on the deck: useful in the Tundra bed also.
    Progress:
  26. Mar 30, 2024 at 7:29 AM
    #986
    Black@Blue19
    Ken
    SE Texas
    ^^^ very nice!!!!
  27. Mar 30, 2024 at 8:02 AM
    #987
    centex
    centex New Member
    RobertD likes this.
  28. Mar 30, 2024 at 10:43 AM
    #988
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    I need to charge some lipos and take some rigs out. I was trying to get out of the hobby over the past few months but hardly sold anything. Now the bug hit me again. I didn’t need it but I found it locally on fb marketplace for a deal I couldn’t pass up. Came with a nice castle brushless setup as well.
    GNTundra, Wallygator and Black@Blue19 like this.
  29. Apr 2, 2024 at 9:02 AM
    #989
    yel911
    yel911 New Member
    NH
    2018 Crew Limited
    I just saw this thread.... not good.
    Resized_20230610_170005.jpg IMG_7158.jpg IMG_7014.jpg IMG_6636.jpg IMG_6640.jpg
  30. Apr 2, 2024 at 9:03 AM
    #990
    yel911
    yel911 New Member
    NH
    2018 Crew Limited
